Hi!!! my Tv is a Panasonic HDTV 1080i BBE High definition this is not a flat screen, the problem that it has is that the screen is not working well it looks like bouble imagen, what can I do?
    Novelist:
  • 132 Answers
I have never heard anybody refer to their tv as looking like a "bubble image" in the 15 full-time years that I have been a television technician, but all I can assume, is that you have a convergence problem, and you will need to replace both convergence ic's, and possibly some resistors. Approx. cost to repair by proffesional would be around $300.oo.
Posted on Nov 02, 2010
How can I change the screen size on my emerson 55 in tv with my remote contrl
Try:
1. Open the Main Menu (which is by the way the left arrow)
2. Choose settings
3. Press ok
4. Choose Television and press the right arrow 6 times
5. Choose view all and press ok
6. Choose Screen Aspect Ratio and High Definition and press OK
for this step you will need to know what type of display you have:
If you have a...
4:3 standard definition for an ordinary TV
Widescreen standard definition for a widescreen TV (16:9 aspect ratio) that doesn't display HD
720p on high-definition screens for an HDTV with 1280 x 720 resolution
1080i on high-definition screens for an HDTV with 1920 x 1080 resolution
1080p on high-definition screens for an HDTV with 1920 x 1080 resolution and progressive scan (also known as "Full HD")
I can't really help you with this, try looking in the maunal, but you can test it by...
7. Choose continue and press ok
8. On screen instructions will be shown on how to test your resolution
I hope this helps!!
Mar 30, 2017 | Emerson Televison & Video
Do my panasonic hdtv 1080i need a converter box in order to work?
None of the newer style TV's need a converter box because all the tv channel tuners use a digital signal. The tv signal in the air is now digital when using a tv antenna.
Sep 13, 2015 | Panasonic Televison & Video
What is the picture quality setting for a panasonic 1080i HDTV
Adjust the video output settings on the devices connected to your Panasonic HDTV. To view 1080p programming, enter into the service menu on your external device and change "Video Output" to the appropriate resolution. By default, the Panasonic TV is always displaying content in the resolution provided for it by the external device. If your cable box is set to output in "1080i," for example, your TV will display content in 1080i.
Let me know if this fixes the issue.
Regards,Suhail
May 11, 2012 | Vizio VO37LHDTV10A 37 in. LCD TV
I have a Panasonic HDTV 1080i TAU BBE projection TV,I can't get a remote to work with it.
Check first to see if remote works---most shops or Radio shack have a remote tester---point remote at it and push a button and tester will indicate if remote works----some digital cameras will also work for this.
If remote is good either a problem with the remote receiver on front of set or the remote circuit inside the set.
Mar 18, 2012 | Panasonic Televison & Video
How big is hd?
High-definition television (or HDTV) is a standard with higher resolution than normal T.V.
High-definition refers to any video system of resolutions of 1280×720 (720p) or 1920×1080 (1080i or 1080p).
Your Dell Inspiron 1525 PC Notebook has a 15.4-inch WXGA (1280 x 800) CCFL TrueLife (glossy) screen.
You will be happy to know that your screen is a HD screen!
I will look forward to your feedback and positive rating.
Sep 10, 2010 | Dell Inspiron 1525 Notebook
Convergence panasonic HDTV 1080i bbe hi definition
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 17, 2010 | Panasonic PT-47WX53 47" Rear Projection...
How do i turn on an hdtv 1080i on?
You don't "turn on" 1080i, the TV receives a signal that is in that format and displays it. If the antenna or whatever you have is not giving a High Def input to TV, it can't display HD picture.
Dec 22, 2009 | Panasonic Televison & Video
I have a problem with using the HDMI
Please make sure that your receiver can display high definition signal, such as 720P, 1080P. As you know your HDTV is high definition source, it can only be displayed on the display machine that have ability to display high definition HDTV signal.
This will help. Thanks, please keep updated. please do rate the solution positively .thank you for using fixya
Dec 21, 2009 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Is the protron pltv32cm a high definition tv . I bought it in 2005.
Kind of. It is capable of 720p. So channels like FOX, the ESPN channels, SPEED, and other 720p broadcasts will look fantastic on that display. However, the 1080i broadcasts will be shrunk to fit your screen. They'll still look pretty good, though. Most people consider HDTV to be anything above & beyond 480p (so, 720p, 1080i, 1080p).
Apr 07, 2009 | Protron PLTV-32 Television
HD WONT WORK ON MY PS3!!!
Hi
Try This links and follow the instructions! CLICK HERE
Thanks!!
Nov 12, 2008 | Philips 27PT8302 27" TV
Televison & Video Logo
249 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
