Question about Canon PIXMA MP750 All-In-One InkJet Printer
Need drivers for Canon MP530 on Kubuntu I have an alarm light on and the in use/memory light keeps flashing. Also I hear a clicking noise constantly
  • Anonymous Mar 24, 2014
    memory, alarm and copy light flashing
  • 2,012 Answers
The clicking noise is because your telephone line cord (from the wall) should be plugged into the "L:" port on the machine -- not the port with the icon of a phone next to it.
If you're not using a telephone cord, make sure your USB cord is not plugged into the telephone jack on the machine (it has been known to happen).
Don't know of any sources for Linux drivers.
Posted on Jun 12, 2008
I have a Canon PIXMA MP530 printer and showing an Service Error 5C10. What is that error? It will not print and the Alarm light flashes.
disconnect it from power for 10 minutes and also check for jammed paper. That should do the trick
Rob
Ps. Thanks for ratings.
Mar 02, 2011 | Canon PIXMA MP530 All-In-One InkJet...
The orange "Alarm" light keeps
AP position error will trigger a 6A00 error code. An error occurred in the AP motor during purging operation. According to the service manual you will need to replace the sheet feed unit, logic board assy, purge unit.
Feb 22, 2011 | Canon PIXMA MP530 All-In-One InkJet...
I turn on my canon mx310 and hear a constant clicking noise that lasts for 2 mintues, the alarm button flashes/blinks, and says "scanner error"... what could be causing that? and how can I fix this?
Issue: A grinding noise is heard from the device.
Solution: Press ON/OFF switch to reset the multifunction device
Reset the device when it is not functioning properly. If the device is not functioning properly or to clear memory, reset it.
  1. On the operator panel, press and hold the <ON/OFF> button for one second. (The display will go blank.)
  2. Wait approximately ten seconds and then press the <ON/OFF> button again.
  3. Wait until the device has completed its cycling process before submitting another job request.
ALSO:
Make sure that the protective cover is removed from the FINE cartridge holder.
Jun 29, 2010 | Canon PIXMA MX310 All-In-One Printer
This is a canon mp530 fax printer machine, cannot print either will it function. flashing sign keeps on poppin out is "check printer" but couldn't find and physically wrong with it. check the connection is...
Hi there
Ok I have put a MP-Tools in my website for you to try out this tools are for reseting your inks plus it can do much more.
Click on the link to download it.
Click Link = http://www.4all2sell.com/reset-tools/MPTool.exe
All I ask is please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
All files on my website are only there for a limited time
Feb 26, 2010 | Canon PIXMA MP530 All-In-One InkJet...
Alarm light and fax light flashing screen shows printing fax data
The alarm light is flashing and the screen indicates read maintenance chapter in the user's guide.
Feb 08, 2010 | Canon PIXMA MP530 All-In-One InkJet...
5 bk was low. changed it now light does not even come on. alarm light blinking, can't do anything. other inks are good but flashing
are u sure have reset your ink tank.... please go to print properties ->click maintenance->click ink counter reset->check colour box an reset.
Sep 09, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Alarm button Flashing, will not perform any function
Turn your printer on. On your computer, go to:
Start
Printers and Faxes (or Control Panel - Printers & faxes)
right click on your printer icon
click on "Printing Preferences"
in the dialog box, click on "Maintenance" tab
click on "View Printer Status"
in the dialog box, click on "Options"
then deselect the "Enable Status Monitor" option (remove check mark)
When the alarm light on the printer blinks and the printer won't do anything not even scan, you can press the reset button (on the printer) for 10 seconds and then, while holding the Reset button down, you simultaneously press the OK button (on the printer) for a few more seconds. For some reason, I sometimes need to do it several times before the alarm light goes off but so far, it always unblocked the printer in the end.
At that point, do the "Enable Status Monitor" as explained above. (put check mark back)
When you need to check the levels, you can either look at the cartridges physically or enable the status monitor (if you are still using 'legal' cartridges in one or more slots).
Google for "Chip resetter for MP530" or go on Ebay for this product.
Jan 31, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Mp530 check ink alarm won't go off with reset button- want to bypass alarms.
Reset Printer Canon MP140, MP160, MP180, MP210, MP220, MP460, MP470, MP500, MP510, MP530, MP600, MP610, MP800, MP820, MP810, MP830, MP960, MP970
  1. Turn off the printer
  2. Hold the Resume Button (red circle in the triangle), add a printer (click “Power”) an indicator light green.
  3. Hold the Power Button, release the Resume Button.
  4. Not releasing the Power Button, double click “Resume” and release Both Buttons.
  5. Click “Resume” for Four times
  6. Once you click “Power”, to confirm the selected action (reset counter absorber). To disable the printer “Power” button to click again.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Dec 14, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Can I sovle this problem without a hard drive in hand
Apr 06, 2008 | Office Equipment & Supplies
Canon PIXMA MP750 All-In-One InkJet Printer Logo
283 people viewed this question
old marine
old marine
