Question about Kitchen Ranges
Whirlpool oven # 84800
The element seems to have died - shorted out, but I can be sure because I have not removed it yet. the oven simply does not heat up properly, and the top element is working fine?
  • 868 Answers
It sounds like its bad.Replace it with the power OFF/
Posted on Jun 14, 2008
  • Archie Ferrarini
    Archie Ferrarini Jun 14, 2008
    model number boobo45 would have helped here.
How do you remove the moulded Hidden Bake Element from the inside whirlpool ceramic range accubake system
first, remove power from the unit before doing ANYTHING! second, remove the back cover of the machine, this will expose another smaller panel with 4-6 screws in it running along the bottom edge across the back. after removing the screws you will have to gently BEND the panel down until you can see the wiring leading to the hidden bake element. cut the insulation covering the back of the element... be sure new element is placed in the exact location of the old one to avoid shorting the bake terminals to the metal cover, then reverse the removal process...
Apr 26, 2016 | Whirlpool 30" Self-Cleaning Freestanding...
RBD305PDQ12 WHIRLPOOL
I would remove the element .seems you might have pushed in to far, perhaps hitting side wall id check there first for a grounded wire you just near. why was element cahnged in the first place???
Mar 15, 2008 | Whirlpool RBD305PD Electric Double Oven
How do I replace the lower oven heating element?
Hello. Your oven has the hidden bake element. Are you SURE it's the problem--Many things can mimic a bad element. A thermal fuse might have opened, the main oven control board might have a stuck relay that turns on the bake element. TURN OFF THE POWER NOW. To *verify* that the element is indeed bad, you will have to pull the oven out and remove the back cover. Near the bottom you should see the 2 wires connected to the terminals at the end of the element. *Carefully* remove one of the connectors(it doesn't matter which one) and, using a VOM(digital volt meter) set to continuity(it beeps when the leads are shorted together), put each lead on a terminal of the bake element. If the element is good, your meter will beep(there is almost no resistance in the element). If you hear nothing, it means that the element has opened somewhere(just like a broken wire). At this point I highly recommend getting a pro to further troubleshoot the unit. If the element has opened, it can be really tricky to remove and then insert a new one--depending on the model oven you have.
Aug 15, 2015 | Whirlpool GR478LXP Electric Kitchen Range
Whirlpool Self Cleaning Oven - Model RF360BXXW Serial # FA4005915 Turned oven on bake - bottom element is not heating however top element is. Tried to change setting to 'timed bake', 'broil' and 'clean'...
Your lower element may be burned out. Generally you can firmly grasp and pull it out. Take it to a repair shop and get a replacement unit. Then simply snap it back into the same outlet where you remove the first one. It sound as if you've tried everything else so it must be the unit that is bad.
Nov 04, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
The oven does'nt seem to be able to heat up above 150, the fan is working, the bottem half of the oven does'nt seem to heating up. Is this fixable or do i need a new oven?
Hi.
If the part that is not heating is only the bottom element, and the top element is heating regularly, then you may need to replace the lower element.
Before replacement the element can be tested removing it from the cavity and reading Ohms at the element terminals, with a multimeter set at Rx1. Disconnect power before removing the element.
If both baking and broiling element do not heath above a certain temperature instead, then the part to be replaced is the temperature probe, still located inside the oven cavity.
Regards.
Mar 04, 2010 | Whirlpool RBS275PD Electric Single Oven
I have a Whirlpool AKZ161/ix/03 double oven in which the bottom oven will no longer heat up to the required temp. I suggest it is the heating element. As a novice will I be able to change the element and...
If it is fan assisted, and the fan is working o/k, then the chances are it is the element.
This is usually located at the rear of the oven compartment behind a removeable cover.
Normally a straightforward repair
MAKE SURE POWER IS OFF !!!!
Please rate my solution.
Thankyou.
Jan 27, 2010 | Ovens
Ihave a whirlpool oven model gbs277pdo1 that will
this could be the timer is set to auto this data sheet might help For all Free appliance repair videos visit our VIDEO TUTORIALS 1, If the fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
To gain access to the element you will have to remove the back plate from inside the oven. Once removed you will see the fan and element, if you look closely at the element you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
2, If your fan oven is getting warm but takes a very long time to cook or is burning the food more on one side than the other, then you need to check if your oven fan motor is working you will see the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then you need To replace the oven fan motor is a little more expensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heating and burning everything then you will need to replace your oven thermostat
4, A quite common and easily overlooked answer is if your oven is not working at all ie: no heat and no fan then the chances are that someone has put the oven timer into AUTO mode, simply put oven back to MANUAL mode and all should be working again.
Jan 13, 2010 | Whirlpool GBS277PD Electric Single Oven
How do i change the element on a whirlpool akz452?
Turn the power OFF to the oven. Remove the oven racks. Unscrew the element where it enters the back wall of the oven from inside the oven. Carefully pull the element leads out of their respective holes. Carefully because the wires will be short.
Remove the wires from the element terminals. Place the wires on the replacement element. Reinsert the terminals into the holes and replace the mounting screws. Turn the power back on and bake me a dozen cookies.
Oct 31, 2009 | Whirlpool AKZ159IX Oven
Kitchen Ranges Logo
64 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
