Question about Toshiba Satellite P35-S6292 Notebook
I have a toshiba satellite p35-s611 and works good with the software but some times this turn off, when i try to turn on again doesn't start, i check the batery (remove) and change the memory (simm), and the problem persist, the fans try to works but doesn't works, and i hear some tick tick inside, when i wait for more of 3 o 4 hours, my computer works normaly, can you talk me wat happend with my laptop? thanks Luis Gomez
eagle338
  • 4889 Answers
SOURCE: Troubleshooting Toshiba Satellite P35-S611
This can be due to 3 reasons.Check these out and report back so that i can help you out
1.The AC power cord is damaged:Try connecting another chord to see if its the problem is with this
2.Damaged Battery
3.This is slightly tougher..you will need to open your laptop check if the DC powerjack is damaged..If you dont know how to check this come back and ask..I will guide you
Posted on Oct 21, 2007
SOURCE: toshiba laptop fan
there is more to it than that, if you just remove the screws on the bottom , youll crack the case... first remove the battery, ram and hard disk., and wifi card. then just above the keyboard, theres a strip of plastic about 1.25 inches wide that spans the whole bottom of the screen... pry this up and put it to the side. then remove the screws holding the keyboard down. remove the keyboard being careful not to damage the cable. now remove the screws holding the screen down(top and bottom of case). unplug the screen and put it in a safe place. now remove all the screws on the bottom of the laptop, MAKE SURE YOU TAKE THE 2 BOLT/NUT/SCREW THINGS OFF THE VGA OUT PORT ON THE BACK! it should be fairly easy to get the top of the case off now. leaving you with the mainboard sitting in the bottom of the case. Now flip over your board, it may take a little maneuvering to get the board out of the case. be careful not to bend the board too far. be careful not to damage the buttons on your PCM CIA card slots. You may have to bend the case a bit to get the VGA ot port out of the case. Now look at the screw locations on the fans. the screws are on the opposite side of the board. unplug fans, and swap them out. now put it all back together! NOTE: if you get several beeps and or blank screen after trying to startup, you probably didnt discharge the static from your body before touching the RAM and it could be either burnt out or you may have to take one of the sticks out and let it sit for awhile.
P.S. if youre replacing the fans because it overheats... its probably not the fans! its the heatsink which requires taking it apart anyhow, but where the fans blow through the heatsink lots of crud gets built up in there and blowing compressed air into it usually does not help. if you do all this, be careful taking the heatsink off the board! and dont damage your chip! if you take heatsink off and chip pulls out with it, youll have to remove chip from heatsink as it is a ZIF socket and dont forget to replace the silver heat compound on the chip! i found it was helpful to pull the heatsink off and run it under some hot water, then dry it with your wifes blowdryer, use some compressed air and q tips to clean your fans out really nice (dont take them apart, theyll never work again) and reassemble.. presto! like new!.. any questions?> give me a holler!
Posted on Nov 09, 2007
SOURCE: Missing P35-S611 Restore CDROM
Boy some of you guys are just plain idiots? A restore disc is not illegal.
Posted on Jan 19, 2008
Pyrhyc
  • 2028 Answers
SOURCE: DC JACK FOR Toshiba Satellite P35-S611
You will need a small set of screwdrivers, flathead and phillips, a pair of pliers or nut drivers, and a soldiering iron. A magnetic screw tray is also handy with all the small screws. You will need to completely disassemble the machine and remove the motherboard. If replacing with a new jack you will then need to heat up the soldier holding the jack in place to remove the old jack, then heat and clean out the old soldier from the hole the jack pins fit into. Soldier the new jack into place and put it all back together. I believe the P30 and P35 are basically the same machine, here's a link to disassembly instructions for the P30.
http://www.irisvista.com/tech/laptops/ToshibaP30/SatelliteP30_disassemble_laptop_1.htm
Posted on Jul 24, 2008
cirocpatel
  • 524 Answers
SOURCE: My Toshiba P35-S611 shuts down without warning.
Indications of laptop overheating problem:
  1. The keyboard and the bottom of your laptop are very hot when the laptop is working.
  2. The CPU fans are working all the time at maximum rotation speed and operate much louder than before.
  3. The laptop suddenly shuts down by itself without warning. When it just started, the laptop was shutting down after 1-2 hours and how it shuts down after 5-10 minutes of operation.
  4. The laptop works fine when it runs idle, but shuts down as soon as you start using any memory demanding applications (DVD player, image editing software, video editing software, etc.).
Solution:
If the CPU heatsink is not clogged with dust and lint completely, you can use canned air and just blow it inside the laptop through the openings on the bottom and on the sides. It’s nice as a precaution measure, but it might not work if your laptop already has a problem and the heatsink is completely clogged.
  1. Open the laptop case, so you can access the CPU fan and the heatsink. In some cases you can access the heatsink through the latch on the bottom of the laptop. Sometimes (for example Toshiba Satellite A70/A75) you have to open the laptop case all the way down.
  2. Carefully disconnect the fan cables on the system board and remove the fan. If the fan makes unusual sound when it spins (grinding sound), I would recommend to replace the fan.
  3. Clean the fan and the heatsink with compressed air.
  4. I would also recommend removing old thermal grease from the CPU and applying new grease for better heat conductivity.
Posted on May 11, 2010
Bios password locked toshiba satellite m30-s350
you can try software flashing or removing cmos battery, here you must be familier with hardware fixing else take it to apro
Oct 27, 2010 | Toshiba Satellite P35-S611 Notebook
Laptop shows Toshiba Logo, then Bios option, and then goes black
yes its very possible maybe the one u replaced was faulty?
Apr 08, 2010 | Toshiba Satellite P35-S611 Notebook
How do I start over with my computer toshiba p35 s611 do I have a restore on this model or do I need to format HD and reload XP? I dont have any restore disks.
if you go to "computer" and there is a partition or hard drive showing as "recovery" then you should be able to take your lappy back to its original state.
if not then you will need to format, depending on how old your system is anyway, a format might do some good.
Jan 02, 2010 | Toshiba Satellite P35-S611 Notebook
Toshiba satellite p35-2611 2 inch(1
the worse thing it could be is the lcd going out in a very bad way. Yes likely to get wrose over time, No not the video card because it happends on every screen, boot,preboot,and windows so guess what? If you have the lcd replaced you will be looking at a good laptop once again. Price aroung $75-100 bucks where? Ebay of all sources. Thanks I hope this was Very Helpful to you if so lay ing your ratings.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Dec 13, 2009 | Toshiba Satellite P35-S611 Notebook
Toshiba Satellite P35-S611, power up failure.
Open the processor area located under your laptop. You can detached and re attached the processor, some sort of lose contact on pins. If same problem occur, your processor may burnt out. pm me caligayanstep@yahoo.com i will assist you remotely.
Oct 21, 2009 | Toshiba Satellite P35-S611 Notebook
Satellite P35-S611 has trouble charging
If you have to wiggle the power cord it is most likely the DC jack on the motherboard. It is usually the center pin in the the jack that breaks the solder point and the small tension band inside the jack housing weakens.
Sep 26, 2009 | Toshiba Satellite P35-S611 Notebook
Slow Hard drive
That model is only IDE capable and has no SATA ports on the motherboard. You should get a faster IDE harddrive OR an external USB harddrive .
May 08, 2009 | Toshiba Satellite P35-S611 Notebook
Lines on screen
usually when you have lines on your screen then you have to buy a new one
Apr 22, 2009 | Toshiba Satellite P35-S611 Notebook
Toshiba Satellite P35-S6292 Notebook Logo
41 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
