Question about Whirlpool ED2FHEXN Side by Side Refrigerator
Whirlpool icemaker not working
I have a Whirlpool model # ed5shaxnq01 UltraEase 2 Icemaker that's not working. The line does not look like it's frozen and the red light is constant. The water at the door still works and the filter has been replaced. Any suggestions would be appreciated.
  • 2 more comments
  • spritc01 Jun 30, 2008
    Thanks for the suggestion. I replaced the water valve, but still no ice. I removed the whole ice maker and it found a broken gear with contacts underneath. So I ordered a new ice maker. Should be here in about a week.
  • Anonymous Jul 09, 2008
    icemaker does not work
  • Anonymous Jul 28, 2008
    light on but ice maker isn't filling
  • Anonymous Mar 16, 2014
    where is the water filter or the icemaker on the whirlpool fwrx735sdbm
  • 481 Answers
The refrigerator has a duel water valve, one for the ice-maker and one for the water dispenser. the valve that the ice-maker relies on may be bad, or it could be the ice-maker itself.
another thing that could cause it would be the temperatures in the freezer. the ice-maker will not call for water until it reaches under 15 degrees.
Posted on Jun 28, 2008
Whirlpool side by side with water and icemaker. My water works perfectly fine but my ice maker no longer produces ice. It runs but it's not getting any water to make ice. What can be done to fix this?
There are a couple reasons your icemaker will not fill with water.
First thing you want to check for is a frozen fill tube to the icemaker. The easiest way to check for a frozen line is to remove the icemaker. Once the icemaker is removed look for ice in the fill tube. If there is ice in the tube the (water valve) will need to be replaced. You can melt the ice by forcing hot water up the fill tube.
Another reason could be the icemaker is not sending voltage to the water valve. The fix for this issue is to replace the icemaker. Hope this helps you with your whirlpool fridge!
The reason to change the water valve with a frozen water line is because the solenoid is not closing all the way. This allows water to enter the fill tube of the icemaker and freeze based on the temperature.
May 04, 2017 | Whirlpool Refrigerators
How to remove icemaker from whrilpool ultraease refridgerator
I had a simular problem with my Whirlpool frig--First of all I would check 1/4 inch plastic line coming from water valve up to ice maker,loosen this line & try to blow thru it -if there is an obstruction it probably is frozen inside plastic fitting at top where it goes thru cabinet & into ice maker if so you can melt by by running a very warm metal object up & inside fitting be patient, you need to both inside & outside--If this the problem,your water valve is probaly bad because of not shutting off properly causing the "drip effect" you can purchase valve on line for aprox $10.00--$25.00 Good Luck--John Morris--
Feb 08, 2013 | Whirlpool ED2FHEXNS 21.8 Cu. Ft....
I have a Whirlpool refrige. side by side and the ice maker has stopped working. The infrared light keeps blinking. I have unplugged it a couple of times as well as turned the infrared off. Any advice?
The laser , is supposed to blink . This laser , tells the icemaker to stop making ice , when the bin is full . Pour about 2/3 cup of water into the icemaker . If it doesn't dump the cubes into the bin , the icemaker is bad . Or , if there is ice in the bin , which hasn't dumped , the icemaker is bad . If the icemaker dumps the ice ( from water pour ) , then look above the fill cup , and see if the black fill tube is frozen . If so , then replace the water valve and turn the freezer temp down slightly . It will take several days for this fill line inside freezer to thaw . If icemaker dumps , and black tube NOT frozen , replace the water valve . The valve , is where the wall water line connects to on the refrig .
Sep 05, 2009 | Whirlpool Refrigerators
Model #ed5lvaxvqoo; ice maker quite working, no water WHIRLPOOL
Due to your refrig having the ice bin on the door , it could be a little bit more difficult to diagnose . Pour about 1/2 cup of water into the icemaker . If it doesn't dump , then the problem is the icemaker . When you open the freezer door , does the laser lite flash 2 times then pause then 2 times etc.? If the lite does not flash , it means the icemaker is in the harvest mode (dumping) . If stuck in the harvest mode , replace the icemaker . If the icemaker dumps the frozen cubes , then the black fill tube above the fill cup , could be frozen , or the water inlet valve is bad . If you feel ice in the black tube ,(water valve bad due to slow drop leak ) you'll need to pull the fridge from the wall , and see if there is a plastic coupling on the tube going up to the icemaker . If not , you should get one in case of future problems . Cut the tube (or disconnect the fitting ) (if you can blow thru it , black tube is not stopped up with ice ) and turn the icemaker off . Turn the freezer setting down a number or two . Go by ocassionally to see if you can blow thru the line . This water line goes between the top of refrig and the inner liner . Bad design because if it freezes , no way to get to it . Can try hair dryer2.gif on top of refrig . I have known it to take several days for this line to thaw .
Aug 28, 2009 | Whirlpool Refrigerators
Whirlpool refrigerator, ice maker stopped working. Line is not crimped or frozen. Thanks for any help! Model ER2CHMXPL00
Is there ice frozen in the icemaker ? If not , pour about 1/2 cup of water into it . If it dumps , then the problem is the water valve . If not , then the icemaker is bad .
Jul 17, 2009 | Refrigerators
Icemaker not working/whirlpool ultraease
I'm sorry I don't have a solution...I am having the same problem, except the water has stopped in the ice machine. I have the same make and model refrigerator. Is it common for the water valve in the back of the frigerator to go bad? Is the valve easily replaced? Where can I buy the valve? Is there a trigger in the rear of the freezer where the icetray connects? I also took my ice tray out and it doesn't seem to fit back in correctly. I'd rather take the ice machine apart myself before I call a technician who will charge me an arm and a leg! Any further advice would be appreciated. Thank you
Jun 28, 2009 | Refrigerators
Icemaker not signalling for water.
cheek the condenser fan.if its opration is not correct.
May 23, 2009 | Whirlpool GD2SHGX Refrigerator
Whirlpool icemaker
Your unit has infered sensors on the frezzer left and right walls. There is a diagnostic test sheet brown in color in your kick plate.All you have to do is open frezzer door look on the right sensor it should blink twice followed by a 1-2 sec delay,if that is good press in flapper door on right sensor do not block path of infered beam you will not see a beam its invisable.Once you hold in flapper on right sensor the led should be solid.If solid optics are good if not solid led replace optic sensors
Jan 25, 2009 | Whirlpool ED5SHAXM Side by Side...
Whirlpool icemaker
Try using an hairdryer or defrosting the unit completely , this often get rid of blockage caused by frozen lines fixing the problem.
The water lines can also be unblocked from dirt using a thin flexible shaft. This after defrosting.
If all that does not fix the problem, then you may need to replace the water valve, the icemaker solenoid, or the whole icemaker assembly.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Jan 23, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool fridge model WF-NL300 ice maker not working. No water in icemaker. Black water supply tube that fills icemaker was frozed solid with ice. I thawed it in a cup of hot water. Unsure if line could...
Turn ice maker off for 24 hours to thaw out any additional frozen lines.
Make sure that you do have water from source to unit. Water valve grit screen may be clogged with debrie or water valve is bad.
Feb 29, 2008 | Refrigerators
Whirlpool ED2FHEXN Side by Side Refrigerator Logo
578 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
