HI
A Code 10 error is generated when Device Manager can't start the hardware
device, a situation usually caused by outdated or corrupted driver A device may
also receive a Code 10error if a driver generates an error that Device Manager
doesn't understand. In other words, a Code 10 error can sometimes be a very
generic message indicating some kind of unspecified driver or hardware problem.
Uninstalling and then reinstalling the drivers for the device is a likely
solution to a Code 10 error. If reinstalling driver is not working than try to
rollback the driver or restore the system on previous date..
regards
sandy fixya
Click the link "hp: Modem Driver Installer for Microsoft Windows XP (32-bit)" listed in Resources if you run the Windows XP operating system on an HP computer; for Windows installed on a Toshiba computer, go to Step 3. For all other types of computers running Windows, go to Step 4.
Click "Download" from the HP website and click "Run" to install the high-definition audio (HDA) modem driver package. If the modem device does not work properly after the driver has been installed on your Windows XP computer, go to Step 9.
Click the link "Toshiba Audio Drivers" if you run Windows and use a Toshiba computer. Find your operating system, click the appropriate driver listed and then read the installation instructions on the screen to download the driver. If the modem device does not work properly after the driver has been installed, go to Step 9.
Click the "Start" button and click "Control Panel."
Click "System and Security" and click "Device Manager" under "System."
Click "System Devices" and right-click the "Microsoft UAA Bus Driver for High Definition Audio" device.
Click "Update Driver."
Update the "PCI" description drivers (PCI bus and PCI device) and any modem device that displays an exclamation point to the left of it. If the modem device does not work properly after the driver has been updated, go to the next step.
Visit the computer hardware or operating system manufacturer's website for further support
