Question about Whirlpool Kitchen Ranges
How to replace the bottom element (encased in the floor) of a Whirlpool Gold oven, model # GLP84800 Bob.
  • 868 Answers
Do you mean stuck by melted or shorted into the case?
Posted on Jun 12, 2008
Whirlpool gold double oven model #gbd307pdb. upper oven lower heating element burned out. replace lower element. it does not get hot. upper element heats up. control board works. is this the thermos
You will have to see if there is power to the element. It is possible that the relay contacts burned when the element burned out. There is a fusable link but this would shut down both the top and bottom elements. If the relay is burned out the control board will need replacing or rebuilding.
Oct 28, 2014 | Ovens
Whirlpool Gold Electric convection oven does not heat up.
Check for a broken wire or even broken element on top and bottom of unit. To do this, the unit must be unplugged or otherwise removed from power completely, then remove the screws that hold each heating element in place and gently pull out and inspect the wire connections. You should have just enough slack to check them. There should also be just enough slack to strip the wire clean to make the new connection to the heating element.
If the repair has been done before, you may need to fish a new lingth of high temp wire into the location.
Jul 13, 2012 | Whirlpool Ovens
The bottom element of my whirlpool gold is heating up when the oven of turned off
the contact which controls the element has burnt shut, The control for the oven should
be replaced.
Jul 17, 2011 | Whirlpool Ovens
Whirlpool oven model RDE6030A the bottom element
Unplug stove and remove screws holding element to oven cavity. Remove and take to nearest appliance shop and they will match up for you. Not an expensive repair. Hope this helps.
Feb 02, 2010 | Ovens
Need to replace hidden bottom element on whirlpool gold GJP84900 how do i get to it
Oct 25, 2009 | Kitchen Ranges
Oven broiler and auto clean not working.
if the oven broiler isnt working self clean wont either check the broiler element to see if its burned out pretty easy to replace most of the times you can replace it from inside the oven be sure to turn the power off then remove the two retainers from inside and pull element out
Jan 29, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool Gold Range Mod GLP84900
Hi I have a whirlpool gold range mdl GJSP 84902 and had replaced the bottom hidden element after finding out it wasn't getting any heat. So replacement took a little figuring out. it ws easy after a removal of screws and pulling out the whole oven casing out fron the front. Anyhow I still don't get enough heat generate from the bottom element, what other cause are there. checked fuses wiring all is connected HELP ME PLEASE !!!!! thank you Paul
Nov 02, 2008 | Whirlpool GR465LXLS Electric Kitchen Range
Kitchen Ranges Logo
287 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
