Question about EuroTech EWF172 Front Load Washer
Eurotech EWF172 front loader overflowing
I have narrowed down the problem on my washer. I believe that the machine is overflowing because it does not know that it is full. I have leveled the machine, I have turned down the water pressure, and it is still overflowing out of the detergent drawer area. Last time When it was overflowing I pulled out the drawer to get a better look and there was a pool of water waiting to drain into the machine. So in my non-mechanical mind that tells me that the washer has too much water in it. SO How do I fix this?
    Master:
  • 638 Answers
Try the hard reset to overcome this problem and the machine will come to its original state.
Posted on Jun 12, 2008
  • 1 more comment
  • hemant somaiya
    hemant somaiya Jun 12, 2008
    u can try this: remove drawer and clean out the spot going down inside dryer with some thing like a long skinney brush cut back on the amount of soap u use that will fix it
  • hemant somaiya
    assume this is a front load remove drawer ck for blockage into tub from inside at inlet and underneath drawer if you use powder detergent old detergent and clump and block line into tub
  • hemant somaiya
    at the very bottom of the washer inside is a pipe and in their is where it drains through there is somthing blocked could be fluff etc.
    try to clean thoroughly .rate this solution as FIXYA if it helped u understand n solve ur problem. feel free 4 any further assistance thanks bye
    Guru:
  • 1,894 Answers
I think the inlet valve has faulty
  • dewan nafees ahmed Jun 12, 2008
    inlet valve or the sensor is faulty now.
    this is why you are facing the problem.
Drum not draining water
you could check the drainage hose to see if there are any kinks or clogs. sometimes the water has no where to go because the hose has some material stuck inside of it.
Sep 22, 2012 | EuroTech EWF172 Front Load Washer
Gets very loud in spin cycle never did it before
If the clothes go to one side it will make that loud noise. open it up when it startes to make that noise, make sure clothes r even around and not push all to just one side.
Jan 05, 2011 | EuroTech EWF172 Front Load Washer
The washing machine (front Load) leaks water
hello you may have an hole in the door seal check the rubber seal around the door if this is ok then check rubber hose on the pump
regards
shaun
Sep 01, 2010 | EuroTech EWF172 Front Load Washer
My eurotech washer is making a horrible noise during the spin cycle...it wont drain or spin what do i do
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 28, 2010 | EuroTech EWF172 Front Load Washer
Will only spin slow speed will not spin at high speed. Everything else seems to be working fine.
Make certain that your selected wash cycle designates a higher spin speed. If so, then you may have an issue with the motor or motor control board. Contact an appliance service company.
Feb 22, 2010 | EuroTech EWF172 Front Load Washer
I have a Eurotech Washer EWF 172 Model # 20024321349 Front loading
hi
since u dint mention any specific question,i tried ti give u some generic answers along wth the manual of ur product
chek this link for the features of ur washin machine
http://www.dealtime.com/xPF-EuroTech-EWF172
OR
chek this file ffor the manual
http://dl.owneriq.net/6/65e593d3-7da5-4cfd-92dc-36e8365c1575.pdf
chek this link,for the all the generic probs related to washin machines...
http://www.repairclinic.com/0088_11_1.asp#Level1_3
OR
chek this link for more information
http://gowashingmachines.org/Washing-Machine-Drain.php
hope u will b helpfull
do let me kno,if u wanna kno more
regards
regards
Jun 20, 2009 | Washing Machines
Eurotech front loading washer, noisy on spin cycle with load.
Hi, could be one of at least two things - if the inner drum can be moved up and down by hand more than an inch when you grab it through the open door it could be the drum bearings that have failed - not good. Usually accompanied by a grinding noise and dirty specks on the clothes.
If the outer drum is really loose in the casing - check with machine unplugged and top removed - then one or more of the very strong springs at the top or the telescopic dampers at the bottom might have come off or broken from it's mounting.
Hope this helps!
If it doesn't, please hold off the rating button and add a comment with more details so I can try to help you further. Cheers, D
Mar 26, 2008 | EuroTech EWF172 Front Load Washer
EuroTech EWF172 Front Load Washer Logo
176 people viewed this question
Top EuroTech Washing Machines Experts
shaun taylor
richie46
Are you an EuroTech Washing Machine Expert? Answer questions, earn points and help others
