Question about ZT Group Cisnet T2060 Notebook Computer
Help system was malfunctining so couldn't power off so i remove the battery. and powered on but requested for password. it's a toshiba satellite A135.
My nascar laptop is shut off dead after i open some programs...
Posted on Apr 28, 2009
My cisnet [nascar] laptop wont opent to main icon screen it just stays blank with background showing
Posted on Aug 24, 2008
I am being asked for my "Built-In HDD1 User Passward" for my TOSHIBA Satellite A135-S4527. Please tell me what it is, or how I can bypass it. I can reload my operating system, that is not a...
Toshiba Notebook PC's in the A105 series, and A135 series, suffered a lot of issues with asking for a HarDDrive password.
[ BIOS
Basic Input/Output System.
A small program contained in the BIOS chipset.
{Chip and Chipset are slang terms for I.C.
Integrated Circuit,
http://en.wikipedia.org/wiki/Integrated_Circuit
A Processor is an I.C.
Ram Memory uses I.C.'s on the sides. They are DRAM chips.
Just two examples of I.C.'s used in a personal computer }
When you power on your computer the first chipset to receive power is the BIOS chipset.
BIOS looks to see what devices are installed, does a Ram Memory count, turns the Processor on, and hands the computer over to the Operating System.
{Simple explanation}
WinXP, and Win 7 are two examples of an O/S.
BIOS gave the harddrive in your laptop the moniker of HDD1.
If there was another harddrive installed also, it would be HDD2.
(HDD 1, HDD 2 ]
Reloading the O/S may, or May Not stop the request for the HDD1 password.
Most of the time? No.
Removing the CMOS battery (RTC Battery) will Not fix this issue.
{Real Time Clock}
It's a glitch in the BIOS program.
Toshiba is aware,
http://www.insidemylaptop.com/my-toshiba-laptop-displays-password-prompt-on-startup/
One solution (Besides Toshiba Support),
http://www.laptoprepair101.com/laptop/2006/02/10/remove-clear-toshiba-laptop-bios/
{ NOTE*
When you go to perform a BIOS update, make SURE the power will not go out.
If the power goes out during upgrading, you will wind up with an expensive doorstop, or an ornament for a table.
A battery backup device of some sort is recommended }
For additional questions, or comments, please post in a Comment.
(Believe upper right of your page. FixYa is constantly revamping in order to improve)
Regards,
joecoolvette
Sep 09, 2011 | Toshiba Satellite A135-S4527 Notebook
Tip
Resetting the bios password for Toshiba Laptop
It working with the Satellite A135
Power unit off. Disconnect AC power. Remove battery. Remove the memory cover screw, memory cover and the memory modules. Peel back the black lebel back from memory module 1, I soldered PAD500 solder pads (to short circuit them), install one memory memory in slot 2 and turned notebook on, it erase the password and boot without asking for one. Then power off desolder PAD500, replace mylar. Replace memory modules. Replace battery. Power up unit, replace memory cover and screw. Whalá!! the password gone, and you can enter to bios setup to set a new password if you want.
on Mar 15, 2008 | Toshiba Satellite A135-S2276 Notebook
I dont know my bios code for a Toshiba Satellite a135-s2356
This website will help you
http://www.technibble.com/how-to-bypass-or-remove-a-bios-password/
In summary, try typing in some backdoor passwords. Then try removing the battery that they were talking about.
To remove go here http://www.irisvista.com/tech/laptops/toshiba-satellite-a135/remove-mainboard-4.htm.
The battery is in some plastic blue outline.
Aug 11, 2010 | Toshiba Satellite A135-S2356 Notebook
I forgot my power on password for my Toshiba Labtop
The power-on password cannot be removed -- this is a "security" feature to prevent a thief from using your lappptop, after stealing it from you.
Find the original sales-receipt, to prove that you are the owner, and telephone Toshiba, and ask them for assistance.
Nov 13, 2009 | Toshiba Satellite A135 Notebook
I HAVE A TOSHIBA SATELLITE a135- S2246 SERIAL NO: 17203847k I NEED TO GET A PASSWORD BIOS. WHAT DO I NEED TO DO? THANK YOU ANNETTE DURAN
If you forgot bios passord
I have a Satellite A135-S2356 that had the same problem. I tried the solution from PCTServices above and it worked great.
"Power unit off. Disconnect AC power. Remove battery. Remove the memory cover screw, memory cover and the memory modules. Peel back mylar from JOPEN1 solder pad. Short JOPEN1 solder pads for 30 seconds. Replace mylar. Replace memory modules. Replace battery. Power up unit. If all is well, replace memory cover and screw."
Just short the two little solder pads and it worked great!
Jun 25, 2009 | Toshiba Satellite A135-S2246 Notebook
Default phoenixbios pasword
If you've lost the bios password, you'll probably have to 'flash' the bios. If you feel comfortable enough, you can dismantle the laptop and remove the motherboard battery for several minutes, then replace it and reassemble the system, see if the password has been cleared. (Note: The motherboard battery is NOT the laptop battery; you have to remove both!)
Feb 13, 2009 | Toshiba Satellite A135-S2276 Notebook
Need a password...
Found these instructions on another website...
Hope this helps
Regards
Aug 18, 2008 | Toshiba Satellite A135-S2276 Notebook
Toshiba satellite 310 series (china)
Aug 16, 2008 | Toshiba Satellite A135-S2276 Notebook
I cannot access my laptop (toshiba satellite A135-S2386...
welcome to fixya
If it is a default password try "admin" as the pass with out the ""
this should work
if it does not please let me know thank you have a good day
Jul 19, 2008 | Toshiba Satellite A135-S2386 Notebook
ZT Group Cisnet T2060 Notebook Computer Logo
99 people viewed this question
Top ZT Group Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Kyocera HP Expert
Are you a ZT Group Computer and Internet Expert? Answer questions, earn points and help others
