Question about NorStar M7324 Telephone
Changing names I cannot get into the administrator programming feature. i have tried everything in the book... I need to change the names on extensions. help!
  • 3 Answers
Http://www.phonserv.com/meridian_norstar_programming.htm
try this website. You need to first release all the calls, then do Feture **ADMIN or **23626 ... that should get you into the system, I'm just having trouble because my office phone won't let me enter the password once i'm in. The password should be ADMIN or 23646 as well.
If you have a different phone, try Feature **CONFIG or **266344 and play around with it from there.
if all else fails, here's another website with more information and codes.
http://www.telephonemagic.com/phone-support/norstar-feature-programming-code.htm
I hope this helps, let me know!!
Posted on Jun 17, 2008
How do i change who the administrator is on my a1502 mac book pro
You need to have the administrator password to manage administrators
Jan 31, 2016 | Speck SeeThru Satin Malachite Green 15 "...
For got parent contral i user name
There are 3 main user types in Mac OS
Administrator: Can do pretty much anything, including adding and managing other users, installing apps, and changing settings.
Standard: Created by an administrator. Standard users can install apps and change settings for their own account... can't add other users or change other users' settings.
Managed: Users who are managed with parental controls can access only the apps and content specified by the administrator managing the user.
Assuming that the parental account that you are referring to is indeed an administrator, there are a few possible solutions, some of which are version dependent. See here for details:
Five Ways to Reset a Lost Administrator Password
http://tidbits.com/article/14437
Jan 13, 2016 | Apple Mac Book Pro 15.4" 2.53 Core2Duo 4GB...
Can not reopen Cal Creator 10 On my new windows 7 computel please help
Make older programs run in this version of Windows (from help section in Windows 7)
Most programs written for Windows Vista also work in this version of Windows, but some older programs might run poorly or not at all. If a program written for an earlier version of Windows doesn't run correctly, you can try changing the compatibility settings for the program, either manually or by using the Program Compatibility troubleshooter.
getcontent.aspx?assetid=745c7204-cf9f-46fb-a86c-98d4b9c644cf&documentset=en-us&prod=win700&market=us Go to the Windows website to watch the video. (1:26)
If changing the settings doesn't fix the problem, go to the program manufacturer's website to see if there is an update for the program.
Warning
  • Do not use the Program Compatibility troubleshooter on older antivirus programs, disk utilities, or other system programs because it might cause data loss or create a security risk.
To run the Program Compatibility troubleshooter
  1. ?id=microsoft.windows.resources.shellexecutetopiciconClick to open the Program Compatibility troubleshooter.
  2. Follow the instructions in the troubleshooter.
If you cannot install a program, insert the installation disc for the program and, using the troubleshooter, browse to the program's setup file, usually called Setup.exe, Install.exe, or something similar. The troubleshooter is not designed to work on programs that have an .msi file name extension.
Tip
  • You can also open the Program Compatibility troubleshooter by right-clicking a program's icon or shortcut and then clicking Troubleshoot compatibility.
?id=microsoft.windows.resources.collapsearrow?id=microsoft.windows.resources.expandarrow To change compatibility settings manually
To change compatibility settings manually for a program, right-click the program icon, click Properties, and then click the Compatibility tab.
Setting
Description
Compatibility mode
Runs the program using settings from a previous version of Windows. Try this setting if you know the program is designed for (or worked in) a specific previous version of Windows.
Run in 256 colors
Uses a limited set of colors in the program. Some older programs are designed to use fewer colors.
Run in 640 × 480 screen resolution
Runs the program in a smaller-sized window. Try this setting if the graphical user interface appears jagged or is rendered improperly.
Disable visual themes
Disables themes on the program. Try this setting if you notice problems with the menus or buttons on the title bar of the program.
Disable desktop composition
Turns off transparency and other advanced display features. Choose this setting if window movement appears erratic or you notice other display problems.
Disable display scaling on high DPI settings
Turns off automatic resizing of programs if large-scale font size is in use. Try this setting if large-scale fonts are interfering with the appearance of the program. For more information, see Make the text on your screen larger or smaller.
Privilege level
Runs the program as an administrator. Some programs require administrator privileges to run properly. If you are not currently logged on as an administrator, this option is not available.
Change settings for all users
Lets you choose settings that will apply to all users on this computer.
Dec 18, 2010 | Broderbund Calendar Creator Deluxe 10 Full...
Change the inter callers name
To chane the name on the sets you'll need to enter telephone programming.
Programming is done on 7310, 7324 and 7316 type sets.
Enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the show key (top right arrow).
The display should now ask for an extension number.
Enter extension number you want to change the name on.
Press the show key (top right arrow)
The display should say LINE ACCESS
Press the next key (bottom right arrow) .
The display should say CAPABILITIES.
The display say Name.
press the Chng soft key.
use the dial pad to enter the name. advance using the arrow soft key to go to the next letter
ex. john = 5 -> 666 -> 44 -> 66
Press the next key (bottom right arrow) to enter the name.
Press the release key when finished
Jul 16, 2010 | NorStar M7324 Telephone
Changing the Administrator
sign in using his name and password if it is using one  then go to control panel/user accounts and change your name to administrator  then boot back to your user name
Nov 07, 2009 | HP Pavilion m7750n PC Desktop
I need to change the phone extension and I don't remember what feature to use. I tried feature **config, but i didn't find any option for changing the extension.
the change Dn program is under the system programming heading.
feature**266344>266344>system prgrming>change DNs> enter old dn>enter new dn>RLs
Sep 14, 2009 | NorStar T7316E Corded Phone
NEC Xen IPK
you need to be in program mode to change the names.
check out ldtsnj.com for help
Sep 01, 2008 | NEC Dterm DTP 16D-1 Corded Phone
We just got WindowsXP with Vista and it came with 2 accounts -- both of them set as the Administrator. Of course, I changed one of the accounts to "limited", set the other as the administrator...
if its windows XP, the administrator work was set to the very first user name created before you started changing it. just try to remember the user name you first used in doin the changes, it could administrator also, try typing that and leave the password blank see if this work...
allen "ally"
Jul 21, 2008 | Computers & Internet
Merlin Legend (Lucent) phone--changing vm list of extension
I do not fully understand you message but it sounds like you want to get into administrator programming of your voice mail.
I don't deal with voice mail programming. My only suggestion is to try and determine exactly which voice mail model you have and find the "administrator" or "programming" manual for the voice mail.
All manuals are available free at www.avaya.com
Apr 25, 2008 | Lucent PARTNER18 Corded Phone
Changing name in nortel T7316E handset
We would like to change the name displays on our phones
Mar 05, 2008 | Nortel Norstar 16-Line PBX Speakerphone
NorStar M7324 Telephone Logo
128 people viewed this question
Top NorStar Lands Phones Experts
george  peters
george peters
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
