Question about Nikon Coolscan III Film Scanner
Nikon Coolscan III LS-30 repairs
I have just experienced a problem with my scanner. I recieve a message stating the staging screw needs to be removed. The screw is not installed and the scanner ran fine a day ago. Nikon no longer supports the older model. What is your advice? Is there a company that will service it?
  • dickieact Aug 21, 2008
    Nikon Coolscan 3. When switching on ticking noise and no movement.
  • Paul Ferrante Mar 24, 2013
    Service and repair of Nikon LS-2000 and LS-30 scanners is provided by eBay member pjferrante2. Performance is backed for 12 months. ...Very reasonably priced.
I had the same problem. You must remove the cover on the scanner. The reading unit shuld be moving on two metalleaders. It was the oil on them that was dry so i had some oil on and helpt it moving with my finger. Now its working again!
Good luck! Bjarne
Posted on Jul 27, 2008
Scanner will not focus Nikon Coolscan IV
http://www.sebsgarage.com/2005/11/cleaning-nikon-coolscan-iv-ed-ls-40-film-scanner
Jul 06, 2011 | Nikon COOLSCAN IV ED LS40
The Nikon LS 2000 Film Scanner says the stage locking screw is still in place but it was removed 10 years ago when I bought it. I tried to put the negative film adapter in, it didn't work. Then I put the...
The lubricant has become sticky and is acting more like adhesive than lubricant. This is the most common cause of malfunction in the LS-2000 and LS-30 scanners. It's a quite curable condition.
Nikon LS-2000 and LS-30 film scanner service and repair is available. Check seller pjferrante2 on eBay. Scanner performance backed for 12 months. Very reasonable price.
Dec 19, 2010 | Nikon LS 2000 Film Scanner
My Nikon CoolScan 4000 is not working properly. All images come with a green shade
I had the same problem with coolscan LS 50 ed, but the chromatic dominant was blue instead. What you have to do is to perform a p.o.s.t. procedure: 1) swith off the scanner and unplug it from the PC; 2) switch off the PC; 3) remove the film-holder from the scanner; 4) switch on the scanner; 6) plug it back to the PC; 7) switch on the PC; 8) insert the slide/film holder. It should work now...
Oct 02, 2010 | Nikon Super Coolscan 4000 ED Film Scanner...
Need a new driver for coolscan 4000 ED for Vista.
You can download the Vista Driver at this link: 4.0.3 full version - Vista only
If this information was helpful, please give me a big thumbs up when you rate my answer.
Feb 03, 2010 | Nikon Super Coolscan 4000 ED Film Scanner...
I would like to connect my old SCSI coolscan iii
If your macbook doesn't have the correct SCSI card (SCSI II - d-sub mini 50 pin x2 connector) installed, you aren't going to be able to do this. You will need to find this SCSI card and install it in a computer that will accept it.
Rich
Dec 16, 2009 | Nikon Coolscan III Film Scanner
My LS-2000 film scanner has just stopped working
I read this forum entry and it solved my problem also:
http://www.pcreview.co.uk/forums/thread-1936922.php
Dec 03, 2009 | Nikon LS 2000 Film Scanner
Coolscan 3 and Windows XP
Try a good scanner program called vuescan. Much better than Nikon software. I have been using on XP for a long time and no problems
Mar 25, 2009 | Nikon Coolscan III Film Scanner
Need driver for Nikon super coolscan LS 5000 ED
Go to Nikon's official website, then search for support. You'll be able to download all the drivers and Nikon Scan software. Hope this helps.
Jan 15, 2009 | Nikon Super Coolscan 5000 ED Film Scanner
Nikon Coolscan 9000 not recognized by XP computer anymore....
I read and would like to thank, the person who mentioned this as a solution. It was stated that if you have more than one firewire on your computer, when you open the Nikon, both signals, or whatever happens in computerland, don't connect. Upon removing the drive in the other firewire, Nikon clicks in everytime. Answer: have only ONE active firewire at a time. You may need to unplug the cable to the scanner and reconnect. But that's it. I've not had any problems since
Jun 09, 2008 | Nikon CoolScan 9000 ED Film Scanner
Nikon LS 2000 hardware problem
Here's what you need to do (carefully!!):
www.vad1.com/photo/dirty-scanner/ls2000-cleaning/
Dec 08, 2007 | Nikon LS 2000 Film Scanner
Open Questions:
Nikon Coolscan III Film Scanner Logo
721 people viewed this question
Top Nikon Office Equipment & Supplies Experts
Doberman
Jerry Greenberg
Jerry Greenberg
Tanvi Thakur
Are you a Nikon Office Equipment and Supply Expert? Answer questions, earn points and help others
