Question about Whirlpool Duet GHW9150P Front Load Washer
Washer filling with water after cycle
I'm following your instructions. I have removed the top cover and see the valves and 4 wires. How do you take them out or apart to clean them?
  • 246 Answers
My oppinion, if it is filling with water after the cycle, replace the valve. The screens are to prevent sediment in the water from getting into the valves. If you try to remove the screens, you will likely dammage them and allow more sediment in. Enough sediment will allow the valve to stay open far enough to over flow the machine.
Posted on Jun 15, 2008
Whirlpool duet washer LF error
LF error means "Long Fill". Whirlpool uses a flow meter that detects the flow of water entering the washer. If this flow meter does not detect the correct amount of water entering the washer it will sound the LF error code. Often this repair can be made with out calling an appliance repairman and without ordering parts. Start by removing the washer fill hoses; both the cold and the hot water hoses. Check for proper water pressure from the house. To do so, turn the water on and put the hose inside the washer or a bucket.
If water pressure is good, check the water valve inlet screens. Most residential washing machines have inlet screens. The screens prevent minerals from clogging the solenoid. With the hoses removed, you can visually inspect the water inlet screens. If the water valve screens are clear the inlet valve with the screens itself will need to be replaced. To replace the water valve, remove the top of the washing machine. Three screws hold the top down. The screws that hold the top down are on the back of the top panel. Once removed the top will slide back and off. Now remove the wire harness that connects to the valve. One screw holds the valve to the washers cabinet. Removing the screw and sliding the valve over will release the valve from the back panel enabling you to complete your repair.
One last thing to check is the fill hoses. These front load washers call for a lot of water quickly. So if you have stainless steel braided flood-safe hoses, they will trip for no reason at all. Replace these flood safe hoses with more traditional hoses. If the hoses are good and you haven't found anything slowing down the flow of the water, your electronic inlet water valve is just faulty on the back of your washer and will need to be replaced because it's just not allowing water flow into the washer correctly.
Nov 24, 2012 | Washing Machines
Water leaks (drips ) into tub after cycle/spin is complete
You have a bad pressure switch or the small hose connecting to the pressure switch may be bad
If the washer leaks water when is filling only, check the following: 1.Fill hoses
2.The water mixing valve
3.Filling injector ( If your washer uses one )
4.Filling spout
If the washing machine leaks during the wash cycle, check the following:
1.The pump
2.The tub stem & seal
3.Tub to pump hose
4.The drain hose
5.Tub (rusted holes)
6.The drum support bolts
If the washing machine leaks during the spin cycle, check the following:
1.The drain hose
2.The tub cover seal
3.The pump
4.The pump hoses
5.The stem & seal
Feb 10, 2008 | Maytag LAT2300 Top Load Washer
Ge toploader whse5240D1WW will not fill with water
please the causes and remedies: God bless you
f your Top Load Washer Has No Water Entering Check The Following
Water Inlet Valve
First check the hoses that connect to the water inlet valve. Remove these completely there should be a screen in at least one end and maybe both ends. Clean these screens. Next check the back of the water inlet valve screens and remove and clean. If cleaning these out does not correct the problem you will need to check to make sure you have power going to the water inlet valve. Most top loaders will have 120 volts going to the valve. Check each solenoid on the valve. You will need to have the washer on and turned to a fill cycle when checking. If you have power and still no water replace the water inlet valve. No power replace the control.
Control / Timer
This is less likely the problem but can fail. If you have no power going to the water inlet valve when selecting a fill cycle the timer/ control has failed and you will need to replace the timer.
Jul 18, 2012 | GE WHSE5240D Top Load Washer
Im trying to replace the fill valve on a Kenmore washer model # 110.28812790 serial # CG4186264. I am having trouble getting the back off to get to the valve. Do you know how to do this? Thanks
I just replaced the fill valve on my front load Kenmore Elite HE4T it is actually a very easy fix.
1. Turn off the hot/cold water supply to the washer. 2. Remove the top cover of the washer by removing the three screws located at the top of the back panel. 3. Lift up the rear of the top cover about 1" and pull toward the rear of the washer. The top cover should pop off. 4. Remove the water supply hoses if they are not marked "H" and "C" mark them so that when you reconnect they are not reversed. 5. On the back - left side of the inlet valve is a spring clamp holding the black water supply hose to the inlet valve. Using a pair of pliers loosen and slide the clamp an inch away from the hose end. 6. Using your fingers and a flat tip screwdriver pry the inlet hose off of the inlet valve. 7. Place the new valve near the defective valve and remove the wires attached to the "H" and "C" inlet relays (they are two square blocks with two wire terminals on each). As you remove each wire attach it to the corresponding terminal on the replacement valve. I found it was best to pry off the plastic connectors with a screwdriver from the top while pulling them off. 8. There is one screw holding the valve to the back panel of the washer, remove it and remove the defective valve. 9. Attach the water black water supply hose to the new valve and slide the spring clamp back over the nipple of the inlet valve making sure it is near the end of the hose, but not over the edge. 10. Install the new valve by lining up the single screw hole and reinstalling the screw. 11. Reconnect the "H" and "C" supply hose paying attention that the "H" is connected to the inside and the "C" is connected to the outside inlet. 12. Turn on the water supply and run the washer through a fill cycle checking for leaks at the supply hose connections and the black hose at the outlet of the fill valve. 13. If everything is still dry reinstall the top cover by putting it in place and sliding it forward. Replace the three screws that hold the top panel.
The entire repair should take you less than 30 minutes. If you have enough room between the back of the washer and the wall you really don't even need to move the washer.
Jul 04, 2010 | Washing Machines
Tub completed cycle and wouldn't shut off the water
Is your machine a FAV6800A or FAV9800A? Can you confirm the Model Number and the first two digits Serial Number?
Does water flow into the machine with the 120VAC power plug pulled from the machine?
If it does you have a stuck water valve. If it doesn’t you could have a stuck pressure switch and I can walk you thru how to check in diag mode for that condition.
I know you are frustrated but with some basic troubleshooting we can determine if the issue is a stuck open Water Inlet Valve or a defective Pressure Switch. Because this board doesn’t ask for the Model Number or Serial Number we need to start there.
Here is where the Model and Serial number info is located on the back of your machine.
Jan 24, 2010 | Maytag Neptune FAV6800AW Top Load Washer
My Whirlpool Duet Washer that is 5 years old all is having a problem......after a was cycle the tub continues to slow fill with water. I have noticed that there is a slow to medium drip coming from the...
The problem is commonly caused by either a pressure switch malfunction, or a bad water inlet valve. The way you can tell is to leave the water turned on and unplug the washer. If the water continues to flow, the problem is the water inlet valve. If the water stops, the pressure switch.
To access either component, you need to remove the top panel of the washer. Locate the three screws that hold the top panel in place and remove. With the screws removed, the panel will slide back, then lift off. The water inlet valve will be loacted in the left rear of the washer (as viewed from the front). The pressure switch will be in the rear on the right.
To replace the water inlet valve, follow these steps:
1. UNPLUG the washer.
2. Turn off the water source and disconnect the fill hoses from the back of the washer.
3. With the top panel removed, disconnect the dispenser hose(s) and electrical connections to the valve.
4. Remove any mounting screws holding the valve in place and reinstall with a replacement valve.
The pressure switch is even easier. One connector plug and an air hose is the only thing attached to the switch. The switch is usually snapped in place along the interior cabinet wall with no screws holding it in place.
If the model number you have this listed under is correct, the part numbers are as follows:
Water Inlet Valve: 8181694
Pressure Switch: 8181695
I hope I've given you enough ideas to work with in narrowing down the cause of your symptoms. This is generally a very simple repair, that isn't very expensive. Any replacement parts can be purchased on line at the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
All these sites offer great service with competitive pricing, so shop all of them for the best price.
If you have any questions, or require additional assistance, please let me know. I hope this helps you.
NOTE: Running a clean cycle will not correct this problem as the source of the problem is BEFORE the washer. The clean cycle will cure many problems in the washer drum, front dispenser and drainage system.
Oct 01, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer continues to leak fresh water into washer tub
This video will show you how to find that leak on any front loading washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Jan 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
How to access filter for kenmore elite front load washer
To access the pump drain filter, follow the instructions in the link provided:
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
It is recommended by the manufacturer that if the pump still does not operate correctly after cleaning, to replace it. It does not take much to damage the motor and impeller of these small drain pumps.
The water fill problem is usually caused by a water inlet valve that is not shutting off properly. To access the fill valve solenoids follow these steps:
1. Unplug the washer.
2. Remove the top panel of the washer by removing the three screws that hold the panel in place in the rear of the washer. With the screws removed, the panel will slide back, and then off.
3. The inlet valve is located at the left rear of the washer (as viewed from the front). This is where the fill hoses attach.
4. A resistance reading of the valve solenoids should be between 750 and 850 ohms.
If you live in an area that has hard water, or if you use well water it is common for sediment and/or deposits to accumulate in the water inlet valve and cause problems with either filling or shutting off. you can attempt to remove the valve and clean it to see if this will correct the problem. Use white distilled vinegar to submerge the plastic portion of the valve in. DO NOT submerge the electrical contacts. Sometimes soaking in vinegar will dissolve and remove hard water deposits and sediment. If you wish to simply replace the valve, follow these steps:
1. Leave washer unplugged and remove electric connections to inlet valve.
2. Shut off water supply and remove fill hoses from the back of the washer.
3. Remove the dispenser hose from the inlet valve and remove mounting screw(s).
4. Install replacement valve in the reverse order of the steps provided.
Replacement parts can be purchased on line at searspartsdirect.com, repairclinic.com, or appliancepartspros.com. All three sites have great service and offer competitive pricing. I would recommend checking with all three sites for the best price. Use your model number to initiate your search.
Jan 05, 2009 | Kenmore Elite 45986 Front Load Washer
Washing machine slowly fills with water when off
Its likely the diaphragm on the water valve is clogged with hard water deposits and is leaking.
You can try to fix it by running some CLR cleaner through the water hose with it disconnected from the tap. or just replace the water valve.
a symptom of this issue is that water is always filling the machine. and you have hard water.
you can get to the water valves and take them out and replace/clean them by removing the top cover (3screws in top rear)
unplug the AC cord.
follow the water hose from the tap the first dual block you see has 4 wires and the hoses plastic connected to it. easy to remove.
But if the machine is not leaking all the time and the machine just wildly decides to activate the relays for water ( you will hear the solenoids click for more water flow then the issue could be the computer control unit.
Feb 07, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Maytag lse7806ace
After removing the power (easist was to shut breaker off), then replaced fuse just inside upper front left cover area by way of 2 white screws on bottom front panel. Clips secure the top into the horizontial lid panel (which you will also have to remove later if fuse keeps blowing) That worked for a coupe weeks as long as the Cycle Selector dial was always pushed in when you opened/closed the washer lid. Then the the problem returned. Only way out was to partially remove the unit from the wall and remove the lid assembly, which was much easier than first thought. Pictures attached. Tools needed are Phillips screwdriver and Nut drivers to remove the horizontial lid/panel from above the washer tub, and below the timer panel/dryer. Didn't need to remove the angled cover below dryer as Washer Door lid assembly is wholly below. Just push the dryer toward the rear, then remove two larger nuts from top left and top right corners. No nuts at rear, just clips that slide in/out. This allows lid cover to be pulled straight out (I had to remove the overflow tube on front right of tub, and one semi-rusted nut-driven screw from the Hot/Cold filler plate which is at the rear of the lid cover. That will make it easier to manipulate the cover and release the 4-pin plastic connector shown in pictures at the left rear corner. Then the entire cover/lid slides out easily as you may have to push the dryer top back to ease it out. Then flip it over and replace the switch and slide the 4 wire connector back under the plastic trip. and reverse the un-install. 4-pin connector is flat-keyed on one side, but it is tight to get to. My OEM part even included a new fuse (19.95 + shipping) Unit is now working fine for last 2 weeks.b88b41c.jpg8de8e68.jpg798b349.jpg49eb6d1.jpg6f06d50.jpg48c84c4.jpg
Nov 14, 2006 | Maytag LSE7806A Top Load Stacked...
Whirlpool Duet GHW9150P Front Load Washer Logo
47 people viewed this question
Dan Webster
Dan Webster
Sal De
