Question about Toshiba Televison & Video
I have a toshiba rear projection TV, 43 inch i believe. There is a black box that appears at the bottom of the screen after about 5 seconds after a channel is selected.
  • 4,889 Answers
The black box you are seeing is because closed caption is enabled. Turn it off and the box will disappear.
Posted on Nov 02, 2010
Screen turn green tv is 57 rear projection
Good Day,
It appears that you may have a green drive issue. Try adjusting the Sreen Control it is located in the front of TV.
1) Remove Speaker Grill (it just pulls off) start at one end, 2) Remove cover (5-6 screws), 3) Adjust control. The control is located on lower right side towards bottom. A small black device with 2 rolls of controls, adjust the center control on bottom row counter clock wise, until you get a black and white picture.(adjust with color control to min).
If this does not work you light bulb (CRT) is bad about a $750.00 repair.
Good Luck, Big Irish.
Dec 07, 2009 | Toshiba 57H83 57" Rear Projection HDTV
The bottom 6in. is black no picture
i cleaned the dust, then tapped on the two little black boxes that have like a sparkplug wire going to the tv tube its been 3 weeks and still works fine.
Oct 03, 2009 | Toshiba TZ43V61 43" Rear Projection...
Toshiba 52 inch TV turns on then blacks out.
Unplug the power to the TV and HD cable box, wait 5 min. Plug TV and HD cable box back in.Everything is working like new. Go figure.
Sep 29, 2009 | Toshiba Televison & Video
Toshiba projection tv
Sounds like it blew an "Internal Fuse"
if you want to fix it..simply open rear of TV and look for the fuse.
here is link for a manual if you do not have one.
Mastersage
http://www.devicemanuals.com/guide/Television/Toshiba/Toshiba-43H70-User's-Guide-TVRNME9EUT.html
Feb 05, 2009 | Toshiba 43H70 43" Rear Projection...
1997 Toshiba 50 inch tv
Sounds as though you have a filter capacitor bad in the power supply. I strongly suggest you have it checked and repaired soon, before it burns up a transistor or regulator. The cost may be a bit high now, but will escalate to possibly a complete power supply board. If you can repair your own set, check the main power supply filter capacitors. Good luck. I hope this has helped.
Ed
NC Electronics
Mills, Wyoming
Feb 18, 2008 | Toshiba TP50G50 50" Rear Projection...
Black box appears on screen when using dvd player
On the TV menu check to see if the TEXT mode is activated if so deactivate it to clear the issue. This will be in the Closed Caption settings menu.
Mar 08, 2007 | Panasonic PT-43LC14 43" Rear Projection...
Toshiba 43 inch projection set
Possible bad solder connections in convergence circuit or vertical deflection circuit. This happens in alot of equipment. After warm up, expansion of joint pulls connections loose. Recommend not running like this, could cause component failure.
Dec 22, 2006 | Toshiba 57H83 57" Rear Projection HDTV
43 inch rear projection
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Nov 22, 2006 | Toshiba 53H71 53 in. Rear Projection...
Televison & Video Logo
20 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
