Question about Protron PLTV-26 26 in. HD-Ready LCD Television
Dead set Checked the 470 mfd caps with esr meter and they checked good. Could they still be bad. Roger
  • Roger Birmingham Jun 12, 2008
    Thanks for the help.
    You were right.
    The caps were bad.
    Thanks again.
    ROger
  • 58 Answers
Yes
Posted on Jun 12, 2008
  • Guy Kelly Jun 16, 2008
    you are very welcom
    guy9
I have a panasonic fore75v DVD/but. Not powering up no display, dead.
I gather that you have a meter, check the output side of the transformer. Check the diodes for open circuit. You cannot always rely on the appearance of the caps. They can fail without any outward signs. You need an ESR meter to check them. ESR meters are not cheap unless you get an ESR meter kit and build it.
Jan 23, 2015 | Panasonic Televison & Video
I replaced the (2) 470 micro farad caps and have the same problem. the monitor still fades after a few secs.what is the next possible problem
Are they 25vdc caps, I just need to know if they are for the 16~18v dc power supply for backlights inverter circuits, or they are 10vdc for the 5vdc power supply.
You need to check the DC voltages for both logic board and the inverter circuits. I use lamps as the load to check the power supply (plug the monitor in but do not activate the power switch so the inverter circuits will not start up).
It can also be bad lamps problem, please look through my albums.
I always repalce the cap in a set, bad cap can look normal but can have high ESR.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
Jan 17, 2011 | KDS K92mdwb Monitor
Hey palaboy thanks for helping. 1. Could you be more specific with this: "there are ( might be ) to sets of 5V supply. one Direct from SMPS out one coming from the 12V supply " 2. I replaced the original...
Comon problem with this model are the 4 bad caps (100Uf) on the inverter board, they developem high ESR and you must replace them with FM/FC PANASONIC with low ESR type, the four bad one has 100uf value whaich checked out OK but the ESR was more than 3 Ohms, I replace them with one 470uf (they use the smaller but with four caps due to spacing requirement becuase this same inverter board is also used in the very low profile monitor they cannot use large body cap, but your monitor chassis has a lot of room for bigger body caps.
http://s807.photobucket.com/albums/yy352/budm/Gateway%20FPD1830/
F1 is the surface mounted fuse. and it should be less than 1 Ohm.
Aug 30, 2010 | Gateway FPD 1830 18.1" Flat Panel LCD...
I own a XG-91D monitor that the screen goes black after about 5 seconds. I found 2-470uF 25V capacitors on the power supply board that were leaky - replaced them but the problem still persists. There...
Replace thee 1000uf caps too. A capacitor meter will not test the ESR ( equivalent series resistance ) of the caps the cap meter will show them to be good but an ESR meter will show then to be bad. Also be sure to use low ESR caps. If you use general purpose aps like from Radio Shack it can damage the board board because of the ESR rating. The temp rating needs to be 105c or the new caps will blow out within a month because of the heat in the monitor case ( No fans ).
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Mar 17, 2010 | Xerox XG-91D 19" LCD Monitor
Nov 21, 2008 - I have a proview 19" LCD TV PA-19DK5. In the last few days when I turn on the tv the picture appears and disappears after 1 sec. audio is fine, when I use my xbox 360 through the component...
Please post the pictures, that will help. Do find any fuse in the inverter circuits, if you do have 5v (for logic) and 12v (for backlights), then may be the power supply is OK but I am not sure that the inverter is using 12vdc since you have some caps rated at 35vdc, Iwould expect the inverter to be using 24vdc for backlights. See some of the pictures I posted here: http://s807.photobucket.com/home/budm/allalbums
Jan 11, 2010 | Proview PL913S 19" Flat Panel LCD Monitor
No power ,dead, fuse good,polaroid tdx 03211c,
Is it about 2 years old? If you checked the fuse I presume you removed the back cover. A lot of these sets have problems with filter caps on the power board---easy to tell---follow the power cord to the power supply board----you will see a number of round parts with plastic on them--most are marked on the side plus and minus--and will have markings like 470 @ 16v; a 470 mfd at 16 volts, look carefully at the silver top of all of them-----it should be perfectly flat with two or three creases in it---IF YOU FIND ONE OR SEVERAL WHERE THE TOP LOOKS BULGED UP----you found your trouble---all the damaged caps(these sets vary from having 2 or 3 to 7 or more) need to be replaced with caps of the same value but WITH A HIGHER WORKING VOLTAGE--REPLACE 16 volt cap with 25 volt cap etc. If you find this is your trouble the parts should be less then 20 dollars. The reason this happens so often is many of the companies us the least expensive caps they can get---saves them money but most of these sets I have seen with this problem fail before 3 years.
if you need help or direct advice :
etower.766@netzero.net
I do this here for free so if this has helped you at all give me a vote here.
Aug 19, 2009 | Polaroid TDX-03211C LCD TV
P6IWP-Fe power up problem
Try to change RAM first..if not worked then the processor ...
Dec 09, 2008 | EliteGroup P6IWP-Fe Motherboard
Hitachi 27GX01B
Check c458; (100/16) c454; (220/35) c453; (470/35); c451 (2.2/50) all are electrolytic capacitors located near IC 451 (la7845) If you have an ESR meter it would help out greatly to identify the weak cap or caps.
Nov 22, 2007 | Televison & Video
Protron PLTV-26 26 in. HD-Ready LCD Television Logo
66 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
