Question about Refrigerators
Hi On a GE fridge bottom mount freezer--cooling coils icing up-- defrost thermostat & heater are okay--main control board has been replaced twice.Fresh food side is too warm--electronic temp. board says 33 degrees f. but thermometer showed 50.Damper control is letting air flow in.Model # of fridge is PDS22MBPBBB.Also comp- ressor is cycling on & off.Even when fridge was de-iced--fresh food never gets colder than 50 degrees F. Rene
  • 1 more comment
  • Rene Matz Nov 02, 2010
    Hi
    Sorry, I forgot to mention the sensor was replaced.Yes it seems like two problems with this
    fridge.I,m wondering whether or not the air damper isn,t working right And yes--best to solve one
    problem at a time.Harder to do in this case--I,m 60 miles away.I,ll keep at it.
    Thanks'' Rene
    Hi
    I talked to the guy,s wife this morning--she thinks her husband didn,t do a complete de-icing
    with the fridge before he had me check it.Its probably the reason for such a high temp.in fresh
    food section--leads back to problem with defrost cycle.Service tech from store they bought
    fridge from(5 yrs. ago) checked fridge a few weeks ago--he replaced main control boards
    twice plus the temp. sensor.I referred couple back to him as parts should be on warranty.
    Also I don,t believe he had the back panel off in freezer section to check heater & defrost
    thermostat.Its quite a job on that model--I unplugged fridge--disconnected defrost connector
    from main control board & checked with ohm meter between it & prongs on service cord.
    I,ve picked up bad heaters that way.I prefer to get right to heaters themselves.
    Thanks. Rene
  • Rene Matz Nov 03, 2010
    Yes I will check the fridge again if store,s service tech doesn,..t find the problem.Thanks again for your help. Rene
  • Refrigerators Master
  • 43,501 Answers
I don't see where you have changes the temperature sensor.
They do go bad and when that happens the board can get a false reading and think the fridge is colder then it really is. Then it does just what you are describing...
I would change it and see what happens...
I am still a bit concerned about the icing problem though... seems like you may have two problems...but I would get them one at a time and do the sensor first...
Here is the sensor for you unit
heatman101
Posted on Nov 02, 2010
  • D. Floyd Kolb
    D. Floyd Kolb Nov 02, 2010
    That does throw a wrench in things... It is not right that a new sensor and new board are that far off temperature wise...this unit cannot be that old... I would call the GE and scream till they got it fixed for nothing!!! Tell me that you will tell every friend you have and everyone that will listen not to buy their products.... that will sometimes get their attention...sometimes you will have to ask for a supervisor because the people you get first are just the peons doing the dirty work...
    With different furnace problems I have often had people call the factory directly and get things that I as a dealer could never get....they seem to listen to the consumer when they threaten to bad mouth their products...
    I hate to say this.... but you have a lemon there and you should have some type of recourse....
    Keep pushing!! There are some really funny things going on there that have no rhyme or reason to them...
  • D. Floyd Kolb
    D. Floyd Kolb Nov 03, 2010
    I would make sure to get a complete defrost on that and then I woudl pull the back and check the heater. I believe that the heater on that is an infrared light... we both know how dependable that can be....
    I also think that you can jumper that light at the main control board also...makes it much easier to check it.
    Also some of the GE models do not run a long enough defrost cycle to completely defrost most of the time and they slowly build up...nothing you can do the timing is built into the board...
    heatman101
GE pss26lgrb defrost mode Freezers
There is a problem with your self defrosting system which has 3 different parts. You need an ohm meter to test 2 of them. The defrost heater and safety thermostat are mounted to the cooling coils in the freezer behind the back wall panel. The safety is a round disk at the coil top with 2 wires coming out of it. When it is cold the reading across the 2 wires should be like a closed switch. The heaters are in a glass tube near the bottom and should read around 20 ohms. If no reading from end to end of the heater it is burned out. The main mother computer board in mounted on the outside back wall under a square cover panel. Any one of these parts will cause a freezer ice build up. The main board is the most expensive average price $150.
Mar 02, 2015 | GE Refrigerators
Refrigerator stopped cooling. As close as I can tell the fan in the freezer part was frosted up for a length of time and has possibly ruined the fridges cooling fan? Kenmore model 106 freezer on top.
If the fan in the freezer stops, then coll air from freezer will not pass from freezer section to fridge section.In that case, the freezer section will get over frosted but fridge section will not get cold, because cool air will not pass from freezer to fridge.The fan is there for two things, 1) for cooling the heating evaporator coil and 2) For flowing the cool air from freezer to fridge.---------- If the frost is getting collected and fan is getting stuck up in frost, then this is the problem.The defrost cycle is not running, the cooling cycle is running.---------------
This problem is called defrost problem.-------------
So first thing you try is , perform, manual defrost reset procedure.---------
The manual defrost reset procedure is as follows : ----
First unplug the unit from main power outlet. Then empty whole unit completely. Then keep both the doors open. Wait for 24 hours. All the ice collected on the coils and in the freezer section will get melted. Clean the water from the sections. Then Connect the power cord of the unit to main power outlet after 24 hours/.Then set the temperature to normal in both fridge and freezer section. Then check,if same frost is getting collected, then its defrost problem,. If it's again building up ice that means the unit is not defrosting. It's starting the cooling procedure, and then while defrosting, it's not working. The defrost assembly consists of three main parts. The defrost thermostat, the defrost heater and defrost board. Any of the one is not functioning. When thermostat sense the maximum cooling, it triggers the defrost heater to start heating and this defrosts the ice collected on the coils and the system works. Both thermostat and heater are controlled by defrost board. First the thermostat and defrost heater to be checked, if both check ok by meter and visually, then its defrost board causing the problem. You can get required parts from from online sites like: --- www.repairclinic.com or from searspartsdirect online site. --------- This should help.Thanks.Helpmech.
Sep 18, 2011 | Kenmore Refrigerators
My freezer coils are completely iced over. How do i fix this?
Its defrost problem.You need to first try manual defrost procedure.This will completely defrost the ice.But if again after few hours or few days, same problem is noticed of coils getting iced, then its defrost problem.--------- In defrost problem, mostly fridge section section stops getting cool.It cools but not properly.----- And freezer section works properly. ------------
The manual defrost reset procedure. The procedure is as follows: ----
First unplug the unit from main power outlet. Then empty whole unit completely. Then keep both the doors open. Wait for 24 hours. All the ice collected on the coils and in the freezer section will get melted. Clean the water from the sections. Then Connect the power cord of the unit to main power outlet after 24 hours/.Then set the temperature to normal in both fridge and freezer section. It will take near to 4 hours to get run in its proper cooling cycle. Then check, if the problem returns again. Then its defrost board problem. -------------
Sep 11, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
We have A GE HSS25GFPAWW side by side and the freezer doesn't defrost so the fresh food side gets warm. We pulled the panel off and the coils are frozen, the fan works. Could it be the heater coil or the...
Yes very much possible that temperature sensor( defrost thermostat) or heater coils ( defrost heater) is faulty.. If you see, too much ice frost collected there, then its defrost related issue. First try manual defrost reset procedure. The procedure is as follows: ----
May 04, 2011 | Refrigerators
Freezer works refrigerator is warm
If the freezer is getting cold and working properly, but fridge section is not getting cold, then it can be defrost issue.------------------ The procedure of this unit is as follows: --- The compressor starts then it cools the freezer section. When the freezer reaches its cooling level the defrost cycle starts functioning. In this cycle the fan in the freezer section starts running and the cool air in the freezer section is passed to the fridge section and the fridge section gets cold. The air from freezer to refrigerator passes from the section, in that section the damper is located.--------- Try manual defrost reset procedure: ---- First unplug the unit from main power outlet. Then empty whole unit completely. Then keep both the doors open. Wait for 24 hours. All the ice collected on the coils and in the freezer section will get melted. Clean the water from the sections. Then Connect the power cord of the unit to main power outlet after 24 hours/.Then set the temperature to normal in both fridge and freezer section. It will take near to 4 hours to get run in its proper cooling cycle. Then check, if the problem returns again. If the same problem occurs then it's defrost problem. The defrost board and the defrost thermostat/heater is not functioning properly and it has to be checked and replaced. The defrost assembly consists of three main parts. The defrost thermostat, the defrost heater and defrost board. Any of the one is not functioning. When thermostat sense the maximum cooling, it triggers the defrost heater to start heating and this defrosts the ice collected on the coils and the system works. Both thermostat and heater are controlled by defrost board. First the thermostat and defrost heater to be checked, if both check ok by meter and visually, then its defrost board causing the problem. You can get required parts from online sites like: --- www.repairclinic.com or from searspartsdirect online site.This should help.Thanks.Helpmech.
Apr 28, 2011 | Amana Easy Reach 20.5 cu. ft. Bottom...
THe fridge on our fridge freezer isnt working
If the freezer is getting cold and working properly, but freezer is not the it can be defrost issue.------------------ The procedure of this unit is as follows: --- The compressor starts then it cools the freezer section. When the freezer reaches its cooling level the defrost cycle starts functioning. In this cycle the fan in the freezer section starts running and the cool air in the freezer section is passed to the fridge section and the fridge section gets cold. The air from freezer to refrigerator passes from the section, in that section the damper is located.--------- Try manual defrost reset procedure: ----
Apr 27, 2011 | Refrigerators
I hava a 2 door fridge, the front of the freezer has a little ice and the bottom really is not getting cold
It can be defrost issue.First try manual defrost reset procedure. The procedure is as follows: ----
First unplug the unit from main power outlet. Then empty whole unit completely. Then keep both the doors open. Wait for 24 hours. All the ice collected on the coils and in the freezer section will get melted. Clean the water from the sections. Then Connect the power cord of the unit to main power outlet after 24 hours/.Then set the temperature to normal in both fridge and freezer section. It will take near to 4 hours to get run in its proper cooling cycle. Then check, if the problem returns again. Then its defrost board problem. -------------The procedure of this unit is as follows: --- The compressor starts then it cools the freezer section. When the freezer reaches its cooling level the defrost cycle starts functioning. In this cycle the fan in the freezer section starts running and the cool air in the freezer section is passed to the fridge section and the fridge section gets cold. The air from freezer to refrigerator passes from the section, in that section the damper is located.----------- The defrost assembly consists of three main parts. The defrost thermostat, the defrost heater and defrost board. Any of the one is not functioning. When thermostat sense the maximum cooling, it triggers the defrost heater to start heating and this defrosts the ice collected on the coils and the system works. Both thermostat and heater are controlled by defrost board. First the thermostat and defrost heater to be checked, if both check ok by meter and visually, then its defrost board causing the problem. You can get required parts from online sites like: --- www.repairclinic.com or from searspartsdirect online site.
Apr 26, 2011 | Whirlpool ET1FHTXM Top Freezer...
Does not go into defrost mode. refrigerator section becomes hot
The defrost is not working.This happens due to the evaporator coil in the inner section of freezer is got blocked by ice .--------
The procedure of this unit is as follows: --- The compressor starts then it cools the freezer section. When the freezer reaches its cooling level the defrost cycle starts functioning. In this cycle the fan in the freezer section starts running and the cool air in the freezer section is passed to the refrigerator section and the refrigerator section gets cold. The air from freezer to refrigerator passes from the section, in that section the damper is located. Now this problem which you mentioned. In this problem the freezer thaws, this happens if the thermostat is not functioning or the heater is not heating. Then the ice starts getting collected on the evaporator coil. The evaporator coil is at the internal section of freezer. If too much ice gets collected then this ice blocks the fan in the freezer section from functioning and this blocks the damper section with ice getting collected there. This all procedure is controlled by the defrost board of the unit.
So first try reset procedure.If that is not helping then defrost assembly parts are to be checked and replaced.The defrost thermostat is located in the freezer section beside the evaporator coil.The defrost heater is located in the freezer section beside the evaporator coil.And the defrost control board is located in the fridge section.-------------
you can get the required parts from online sites like:---
www.repairclinic.com or from searspartsdirect online site.---------This will help.Thanks.Helpmech.
Feb 21, 2011 | Whirlpool GS6NBEXR Side by Side...
Top section not cooling on GE Side by Side
IF the evaporator is frozen then the defrost is not occuring. Probably the heater or the defrost thermostat.
Sep 10, 2009 | GE GSH22JFT Side by Side Refrigerator
Refrigerators Logo
100 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
