Question about MTX X Thunder 702X Car Audio Amplifier
I bought a couple of mtx 702's from a guy as a project for school. They were both broken, from what he said. The first 1st one was labeled by the guy, having syptoms of only soft noises coming out of the speakers. I have not powered up the amp to check for myself, but inside there are a couple of solders loose on a capacitor, and there seems to be another capacitor blown. Do you know what the cause of this would be, or have any other ideas of what the problem could be. that is all that i can find inside that even looks close to being a problem.
techman
  • 3130 Answers
SOURCE: My amp light is on but no sound from speaker
If the amp light is one and the protector light wasent on then I bet you blew your speaker??? take an ohm meter, measure each speaker with nit disconnected from the amp.. If they all measure what there suppose to( like 4 to 8 ohms) then the amp blew out and unless you have training on solid state electronic repair, you should seek a pro to fix the amp for ya.. Good Luck
Posted on Jun 28, 2006
  • 631 Answers
SOURCE: mtx 1501d
There are a lot of problems that can cause the amp to apply DC to the speaker terminals.
Before we go any farther, you should know that this amp stores enough energy to kill. When power is applied, the transistors must be clamped to the sink. After removing power, you MUST wait for ALL LEDs to go COMPLETELY out.
You need to CAREFULLY measure the DC voltage from leg 1 to leg 3 of all of the output transistors (the ones you changed). Post a list of the voltages and circuit board designation (FETxyz) for any that read more than 1v.
Do NOT let the probes short to other pins or to the heatsink when measuring the voltage.
Remember... High voltage and lots of stored energy. Be careful.
Posted on Apr 17, 2008
  • 631 Answers
SOURCE: mtx 1501d no sound
There are a number of things that can cause it to act as you described. Have you pulled the covers off of it yet to see if you can see any problems?
If you do, disconnect power from it and don't touch ANYTHING on the board when ANY of the 3 LEDs (2 are not visible from the outside) are lit.
Posted on Aug 19, 2008
  • 5 Answers
SOURCE: Mtx TC-6001 Amps Problem
I had same problem with a TC6001 and get solution from MTX, not send to MTX instead MTX kindly sent a quotation for parts to be replaced, I can tell you what parts need to be replaced if you still need a solution.
Posted on Dec 29, 2008
SOURCE: my mtx thunder 1501d car amp making noise in the subwoofers
This is common with pioneer head units, the rca jacks are not properly grounded and this lets engine noise come through the rcs cables. This thread explains a fix http://www.caraudio.com/forum/showthread.php?t=337644.
Posted on Jan 03, 2009
Do you have a service manual for the Taylor Model 702?
being a fellow fixya guy, you will know that fixya does not have anything except advice
go google and type in --service manual for taylor model 702--and look for a pdf version
Oct 03, 2016 | Taylor Ice Cream Makers
How do I hook up 4 10 inch mtx old school?
you can put them in one box you will need a good port hole if you do.How to build subwoofer box
this link is on how to hook up speakers Subwoofer wiring diagrams \
good luck
Aug 11, 2015 | MTX Car Audio & Video
1996 Manual Nissan Pickup Jerking Problems. Help?
Deffently looks like the clutch is burn,t out on it, From the way you (Explain) It was doing.
Nov 06, 2012 | Cars & Trucks
I just bought 2 12 inch mtx thunder tc512 to replace my old school mtx blue thunders, everything worked great, but when i hooked up the new 12s i get nothing, zero, zip, nadda, there is nothing wrong
use a d cell battery and touch + of speaker to + of battery and hold it by doin the same with the -'s too if move they work if not there junk
Sep 09, 2012 | MTX Car Audio & Video
My mtx ts5510 stopped working while driving. Was hooked to an mtx thunder 81000 class d and its still working. ????
Inspect speaker for loose wires/broken wires. Check inside box for loose connection. Blown fuse on amp. Ive literally pulled the wires out of the speaker. The little mesh ones from the terminal to the cone. Look for that. If you do find something broken or bad. remember you can call MTX and fix for a flat rate on most evrything they carry. Ive sent several amps there. normally around $100
Mar 25, 2011 | MTX TS551022 Car Speaker
Sparkplugs under oil on 2006 suzuki
old school-- new school- sealant is sealant no 2 has advanced to a rtv silicone sealant the copper was probably the permatex -copper hi temp spray but u can still find and use no 2 there is no special just make sure everything is clean and dry and when using sealant let set up a bit and put in place
Jul 27, 2010 | 2006 Suzuki Forenza
Where is asus motherboard service center in kolkata
There isn't one, you will have to contact Asus main offce.
Apr 28, 2010 | Microsoft Windows XP Professional SP2
Mtx 7500 sub
what amp are u usin?What enclosure 4 speakers do u have?Might not have enouigh voltage 4 the amp.How big are the wire for power 2 amp?what ohm are you playing ,is it compatible to the woofers.Need more info.Model and makes please,but 1st a rating.
Jun 16, 2008 | MTX Car Audio & Video
Sony Wega 50" LCD Projection w/broken screen
Hello izitme,
You may posted it in the wrong forum, But since you are already here....How much do you want for the darn thing? Where are you located?
Thanks
Circuitcity
Dec 11, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
MTX X Thunder 702X Car Audio Amplifier Logo
Top MTX Car Audio & Video Experts
Mike Duncan
Mike Duncan
Philip Armitage
Marvin
Marvin
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
