Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
02 sportster 1200 brake light not working
02 sportster 1200, tail light works but brake light wil not.. traced the wires from circuit board at tail light to the harness under seat. brake light pin on harness has constant power with switch on but no power at circuit board and brake light will not work
  • Anonymous Mar 21, 2014
    light stays on
If you have power at the harness pin but not the light then your problem could be a cut wire grounding to frame between connector and light. you did not say what kind of light you have. a regular filament light check the socket as they sometimes go bad due to vibration, if it is a led light, look for a bad componet on the circuit board like a open resistor or such. if you are handy with a soldering iron, you can repair it pretty cheaply.
Posted on Aug 27, 2008
Brakelight not working, tail running light works but not brake light, have replaced bulb and rear brake switch, no luck. XL1200L sportster. Is there a circuit breaker??? Where ?
there is a break pressure switch on the brake line with 2 wires plugged into it -- replace the switch and your brake light will work
Mar 17, 2015 | Harley Davidson Motorcycles
Brake lights saying on
I would suggest a circuit for the brake lights has shorted out somewhere causing the brake lights to have power constantly!
you will need to trace the wiring from the brake switch to the brake lights and check for shorting out.
Apr 21, 2017 | Jeep 2002 Grand Cherokee Limited
I have a 2000 sportster my front light does not work and my brake light does not stay lit but when brakes r applied brake light comes on and turn signals all work can someone help me?
Short to main accesories which is dash lights headlamp and tail Lamp not the break lamp it's prolly on the ground wire side since some lights still work ther getting juice but the ground that compleats the circuit to the break lights gets there through the break switch ok but the ground from the key on switch isn't getting to the constant on light start at the try to run new grounds to anyplace and if the lights com on its in the harness and u start tracing it down when the bike is striped of tank and sheetmetel it will be Easter to find look at the harness connectors for green oxidation and loos fitting wires
Mar 14, 2012 | 2004 Harley Davidson XL 883 Sportster
When i downshift or brake my headlight dims and speedo goes out now i have no taillight or brake light 97 1200 sportster
Sounds like you had a short circuit in your tail light/ brake light. When you depress the brake pedal, the short circuit loaded down your electrical system.
Jul 07, 2010 | Harley Davidson XL 1200 C Sportster Custom...
How to hookup tailight wires for an 05 harley davidson sportster xl 1200 c 5 wire hookup
Orange/white = 12 VDC
Blue = 12 VDC for tail light
Red/yellow = Power from brake light switch (to stop light)
Black = Ground(s)
Purple = Left Turn Signal
Brown = Right Turn Signal
Jun 22, 2010 | 2005 Harley Davidson XL 1200 C Sportster...
Brake lights don't work. Replaced bulbs, checked
Yes, you need to of course check the voltage coming into and going out of the brake light switch, if 12 Volts are there going out and coming in while pressing on the brake pedal, your brake lights aren't getting a good ground or there is a break in the circuit between that switch & the lights.
On occasion the tail lights will work with a weak ground circuit where the Brake lights won't. Best way to determine this is to just hook up the 12 volt tester to the Brake light hot wire & there at the bulb ground, then in an area away from the bulb that has a good possibility of contact/ground.
Really that's it, if the 12Volts is getting to the bulb but it isn't lighting, if you aren't getting the voltage there and the brake switch is hot on both sides when pressed, the break in voltage will have to be traced from that switch to the tail light to find the problem.
good luck.
Feb 22, 2010 | 1999 Chevrolet Silverado 1500
Left signal flashes right doesnot signals wont light up for night
Replace the bulb in the tail light. It's dual filament bulb. Brake light is separate from the running light.
Apr 24, 2009 | 2005 Harley Davidson XL 1200 C Sportster...
Lands Phones Logo
368 people viewed this question
Top Harley Davidson Lands Phones Experts
ted dux
Ronny Bennett Sr.
Ronny Bennett Sr.
David Payne
David Payne
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
