Question about Canon PIXMA MP600 all-In-One InkJet Printer
Link status inactive
I had my printer set up in a wired LAN. Then I moved it to another location with another LAN-cable. Now I can not get it to communicate anymore. According to the troubleshooting Help, Link status should be active. It is now Inactive. I can not find anywhere how to change status. The problem is probably very simple to solve... but I am lost. Can anyone help me?
Thanks a lot!
Lotte68
5 Suggested Answers
  • 6 Answers
SOURCE: I can't scan anything from my MP 460
had probs with scanning at first
1.put doc in scanner
2.push scan
3.choose color or black
4.press scan again
thats what i did works ok
Posted on Dec 12, 2007
PA8558
  • 28 Answers
SOURCE: my cannon printer jams
This printer cannot use cheap paper. Make sure you use 20lb #92 paper. I had the same problem till I changed paper. Hope this helps
Posted on Dec 29, 2007
Bappa170873
  • 505 Answers
SOURCE: printer cable
You will get the cable from any Bestbuy shop. You can also contact some local tech shop. Make sure you mention the model no. of your printer while buying the printer cable.
Thanks
Posted on Oct 08, 2008
SOURCE: Printer not responding
I had the same problem after I accidentally pulled the power cord out of the printer - it turned out to be the firewall on my PC, when the printer reconnected to the wireless network it got a new IP address and the firewall was blocking incoming messages from it.
Posted on Feb 10, 2010
lyonzy1
  • 208 Answers
SOURCE: Canon Pixma IP1500 has been inactive for 2 months
Try changing the fuse
Posted on May 20, 2010
D-Link Dir-645
Try rebooting the router and your internet - modem power off for 10 seconds then back on. Make certain your modem is connected to the internet by directly connecting with it using a LAN cable. If it is OK check the LAN cable between the to units - try a new cable.
The final solution is a factory reset of your router. You can do a factory reset by logging into the router using you browser. Go to the settings and perform a factory reset
If you forgot the router password, you ill have to do a factory reset by locating a small hold on the back of the router and insert the tip of of paper clip for about 10 seconds while the power is on. The router will be reset to out of box status and then you can set-up form scratch.
Feb 28, 2013 | D-Link Computers & Internet
MY DLINK 2730B WILL NOT CONNECT TO THE INTERNET i hconect to the have configed it once worked moved it wouldnt work put it back reset it reconfiged it internet light is still red will not connect to...
First try replacing the LAN cable between the modem and router. Hard reboot bother devices (off 10 sec then back on). Connect to the modem with a LAN cable to make certain it is working correctly.
Feb 03, 2011 | D-Link Wireless N 150 Home Router 4Port...
Using DIR-655 as hub, DHCP disabled, 3 PCs connected with LAN cables, and LAN cable from modem which is DHCP server, all works fine, including HP wireless printer. But when 4th PC connects wirelessly,...
If you forgot the router password, you ill have to do a factory reset by locating a small hold on the back of the router and insert the tip of of paper clip for about 10 seconds while the power is on. The router will be reset to out of box status and then you can ssets-up form scratch.
Sep 18, 2010 | D-Link Xtreme N DIR-655 Wireless Router
Cannot install on my computer
what is the status of your LAN?
A. not Connected:
1. Check the LAN Cable make sure it is good.
B. Connected:
2. check the IP Address may be its not set Properly.
Aug 14, 2010 | D-Link DIR-600 Router
Up wirelessly with my home network.My printer is showing as offline on my computer, how can i get it back online. I have it set
The BRAdmin Professional utility for Windows® is designed to manage your Brother network connected devices such as network-ready Multifunction devices and /or network-ready printers in a Local Area Network (LAN) environment. For more information on BRAdmin Professional, visit us at http://solutions.brother.com.
Installing the BRAdmin Professional configuration utility
1 Put the supplied CD-ROM into your CD-ROM drive. The opening screen will appear automatically. Follow the on-screen instructions.
2 Click Install Other Drivers or Utilities on the menu screen.
3 Click BRAdmin Professional and follow the on-screen instructions.
Setting your IP address, Subnet Mask and Gateway using BRAdmin Professional
2 Click Devices, then Search Active Devices. BRAdmin searches for new devices automatically.
3 Double-click the new device.
4 Enter the IP Address, Subnet Mask and Gateway, and then click OK.
5 The address information will be saved to the machine.
You can use the BRAdmin Professional utility to set a password. (See the Network User’s Guide on the CD-ROM.)
Start BRAdmin Professional, and choose TCP/IP.
Note
49
For Network Users
BRAdmin Light configuration utility (For Mac OS® X users)
The Brother BRAdmin Light software is a JavaTM application that is designed for the Apple Mac OS® X environment. It supports some of the features of the Windows BRAdmin Professional software. For example, using the BRAdmin Light software, you can change some network settings on Brother’s network ready printers and multifunction devices. The BRAdmin Light software will be installed automatically when you install the MFL-Pro Suite. Please refer to installing the driver and software in this Quick Setup Guide if you have not yet installed the MFL-Pro Suite. For more information on BRAdmin Light, visit us at http://solutions.brother.com.
Setting your IP address, Subnet Mask and Gateway using BRAdmin Light
If you have a DHCP/BOOTP/RARP server in your network, you don’t have to do the following operation. The print server will automatically obtain its own IP address. Make sure that version 1.4.1_07 or later of JavaTM client software is installed on your computer.
1 Double-click the Macintosh HD icon on your desktop.
2 Choose Library, Printers, Brother and then Utilities.
3 Double-click the BRAdmin Light.jar file. Run the BRAdmin Light software. BRAdmin Light searches for new devices automatically.
4 Double-click the new device.
5 Enter the IP Address, Subnet Mask and Gateway, and then click OK.
6 The address information will be saved to the machine.
Note
50
For Network Users
How to set the machine’s network settings to wireless
Restoring the network settings to factory default
LAN or wired LAN
To connect your Brother machine to a wireless or wired network you must configure the machine from the machine’s control panel for the network type you are using.
For wireless LAN On your machine, press Menu. Press a or b to choose LAN and press OK. Press a or b to choose Network I/F and press OK. Press a or b to choose WLAN and press OK. The wired network interface will become inactive with this setting. Press Stop/Exit.
It will take about a minute for the LAN menu on the LCD to become available again.
For wired LAN On your machine, press Menu. Press a or b to choose LAN and press OK. Press a or b to choose Network I/F and press OK. Press a or b to choose Wired LAN and press OK. The wireless network interface will become inactive with this setting. Press Stop/Exit.
To restore all network settings of the internal Print/Scan server to factory default, please follow the steps below.
1 Make sure the machine is not operating, then disconnect all the cables from the machine (except power cable).
2 Press Menu. 3 Press a or b to choose LAN.
Press OK. 4 Press a or b to choose Factory Reset.
Press OK. 5 Press 1 to select Yes. 6 Press 1 to select Reboot.
7 The machine will restart, re-connect cables once this is complete.
Apr 29, 2010 | Brother MFC-665CW All-In-One InkJet...
Printer status remain offline how do i set it online again - all cables plugged in can see the printer in the network with status offline
make sure the lan cable is properly connected and you are able to acces the printer ip.
Go to printer and faxes option and choose the printer model which you installed just right click on it you will see the option of use printer online.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Mar 26, 2010 | Toshiba e-Studio 202L Copier
Epson sx510w prints using a cable but can't get it to print wireless
The specs for your model Epson allows you to connect the you network by wireless and by LAN cable.
The specs are as follows :-
Wi-Fi Wireless LAN IEEE 802.11b/g – compatible with 802.11n*
*Transmission rate will be limited to 802.11g and will operate in the 2.4 GHz frequency band
Ethernet Wired LAN IEEE 802.3 (100BASE-TX, 10BASE-T)
Other PictBridge
Wireless security
WEP – 64bit
WEP – 128bit
WPA – PSK (TKIP) – compliant with WPA2
WPA – PSK (AES) – compliant with WPA2
To connect the printer by a LAN cable you need to configure the Epson for an IP address that suits your network configuration and connect the LAN cable to your wireless router/hub.
The reason why you cannot print using wireless is because the wireless configuration in the Epson is not setup with the router's wireless configuration ie. SSID WPA encryption etc.
For instructions of setting up a LAN network printer, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3668797-setting_up_shared_network_printer
For instructions on setting up a wireless printer, the Epson wireless settings need to be configured with the router's wireless settings. Go into your router's wireless and note the SSID, and encryption settings etc and configure the Epson's wireless settings with the router's wireless settings. This will allow the Epson to connect to the wireless router. Please click on this link for instructions to secure your wireless network, configure the wireless router (if you have not already do so) and configure the wireless card in the computers and wireless printer (the instructions for configuring the wireless card in the printer is the same as for the wireless card in the computers via the printer's menu screen).
http://www.fixya.com/support/r3559128-wireless_router_security
Feb 07, 2010 | Epson Office Equipment & Supplies
Trying to connect a wired network wirelessly to a router
No. You'll need to run a "cross-over" Ethernet cable from one of the "LAN" ports on the "downstairs" router, connecting to the "WAN" port on another router that you will need to buy, and place "upstairs", and connect the 4 devices to the 4 "LAN" ports.
Or, run a long "straight-through" Ethernet cable from your DSL-modem (or cable-modem) that is "downstairs", and move your wireless router "upstairs", and connect the 4 devices to the router's "LAN" ports.
Your laptop "downstairs" should still be able to connect (wirelessly) to the wireless-router that is "upstairs".
Sep 16, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Dell Laser MFP 1815 wont print
The printer status showing offline is more then likely a computer issue then the printer. On the printer, use the menu to select "reports" and then select the printer settings report. If the printer prints the report, then the printer itself is working, and it is a communication issue between the printer and the computer. If you are connecting to the printer with a usb cable, then try moving the usb cable on the computer to another port. If this does not work, try deleting and reinstalling the printer.
Sep 25, 2008 | Dell 1815dn All-In-One Laser Printer
Canon PIXMA MP600 all-In-One InkJet Printer Logo
226 people viewed this question
old marine
old marine
