Question about Magellan Meridian Platinum GPS Receiver
Unit currently contains no map! initiating map upload. but it does nothing and no buttons makes anything happen. what do I do?
SOURCE: explorist 300
since the unit doesn't have a base map it needs to be loaded with the base map so send it for a service so that the base map could be added.
Posted on Jan 26, 2007
DanEz007
  • 86 Answers
SOURCE: error screen trouble shooting
If you have the USB cable and a dvd/cd that contains the software/maps, then it needs to be loaded. Install the software on your computer. With the unit off, plug it into USB, then turn on unit. run program installed from dvd/cd. you can also try resetting the unit by holding down the Menu and Nav key, hopefully a small box appears and you can use the stiff stick to change the numbers. if this does appear, change the numbers to read 32 then press the stiff stick in (pressing enter). _Daniel
Posted on May 05, 2007
  • 24 Answers
SOURCE: No functions work.
goto magellangps.com and report your problem. my 210 explorist came with the basemap already installed.im giving you the phone number for tech support also it is 1-800-707-9971 or by fax 1-909-394-7050(attn:tech.support) if that dont work e-mail me and i will send you the basemap in a email
Posted on Dec 13, 2007
pippokid
  • 14 Answers
SOURCE: Unit Map
You can download the US basemap for the 500 at
http://www.megaupload.com/it/?d=EJTNQH03
Rename it BASEMAP.MGI
Then copy it in the directory "background maps" in the SD card of your 500, by using a SD card reader/writer.
Insert the SD card in your 500 and connect it to your PC; then turn it on;it will turn on regularly, because the basemap in the card will be detected; turn it to USB file transfer mode, and copy the basemap from the SD card to the directory "background maps" of the 500.
Posted on Feb 17, 2008
  • 7 Answers
SOURCE: No map
Install the firmware again:
Go to: http://www.magellangps.com/support/product.asp?prodid=1114
Or, if this doesn´t work, go to www.magellangps.com, click on "support", click on "legacy products" (left) and click on "eXplorist 210 Europe" (do NOT click on "eXplorist 210 North America")
On this page click under Updates/Upgrades on "version 2.57", and follow the instructions. You will have to register your GPS, register it under a European country.
After you have installed the firmware you will have the basemap and some new windows on the GPS. Good luck and enjoy!
Posted on Sep 05, 2008
When you turn the unit on a message comes onto the screen that says. UNIT CURRENTLY CONTAINS NO MAP! INITIATING MAP UPLOAD. you cant do anything with the unit message stays on the screen.
when you turn the unit on a message comes onto the screen that says:
May 01, 2011 | Magellan eXplorist 400 GPS Receiver
Magellan Explorist 500
The necessary map software is not installed - did you buy the unit with software?
Mar 19, 2008 | Magellan eXplorist 500 GPS Receiver
Dead 210 GPS
Hi do you still have the software that came with the gps as it sounds like their is corrupt data on the gps.
You will need to reinstall all software and load up all the maps that you need.
Let me know how you get on ok
Dec 10, 2007 | Magellan eXplorist 210 GPS Receiver
UNIT CURRENTLY CONTAINS NO MAPS
You need to load maps into your device.
Apr 22, 2009 | GPS
NO MAPS
Follow these steps to fix the “UNIT CURRENTLY CONTAINS NO MAP! INITIATING MAP” ERROR.
Step 1: Download the firmware update for your Sportrak model from:
Magellan GPS. Extract the zip file to your desktop.
Step 2: Download the base map file, NA_B101.IMG. This one is hard to find but you might look
on the following yahoo group page for the file: m330 : The Map 330 Club . Look in their FILES folder for the file called, NA_B101.zip. You may have to join this group to gain access to this folder. Download the file and extract it to your desktop.
Step 3: Now that you have the files necessary to fix your unit, follow these step exactly to upload the base map file.
  1. Turn off the unit and connect it to your computer using the Magellan serial cable. If your computer does not have a serial port you can buy a, SERIAL to USB adaptor.
  2. Now simultaneously press and hold that button the looks like the world and the button with the man on it (GOTO button). While holding these buttons, press and release the power button. Two zeros will appear in the middle of the screen like this, 00. Using the central joystick, change the zeros to the number, 98. The press the enter button once.
  3. Go to the folder where you extracted the firmware update you downloaded first and look for the Magup.exe file and double click it to launch the Thales Navigation Firmware Uploader. Click NO on the UPLOAD pop up window. Now Click on EXPERT from the menu bar. The EXPERT SETUP window appears. On the EXPERT SETUP window choose your GPS model. Then choose the com port your GPS is connected to. Now check the box next to the word ON under EXPERT UPLOAD. Then click OK.
  4. [i]Note: If you do not know what your serial com port is, here is a way to find out. Click on START, and then on CONTROL PANEL. In the CONTROL PANEL, scroll down and double click on SYSTEM. Then click on DEVICE MANAGER. In the DEVICE MANAGER, look for PORTS (COM & LPT) and click in the + symbol to the left to expand the category. You should see your serial listed here and the com port it is on will be listed to next to it.
  5. On the Menu bar click on UPLOAD. Click OK on the reminder pop up window. On the SELECT UPLOAD TYPE window check the box next to BASE MAP ONLY. The SELECT BASE MAP FILE window appears. In this window Navigate to the folder on your desktop where the, NA_B101.IMG file is located (you should have already extracted it here earlier if you are following all the steps.) Select the NA_B101.IMG file and click OPEN. The window closes and the UPLOAD FILE window appears. Click on the box next to UPLOAD and the upload process begins automatically. The process may take several minutes. Once it is done, restart your unit and you are on your way.
Since you now have downloaded the latest firmware and your unit is now functioning properly, you might as well update your firmware if it needs it. Follow the instruction found on the page where you downloaded the firmware update for your unit in step one.cool.gif
Apr 10, 2009 | Magellan SporTrak Map GPS Receiver
CAN NOT GET MAP ON GPS MAGELLAN EXPLORIST 210
try updating the firmware from the magellan website that fixed mine.
Oct 29, 2008 | Magellan eXplorist 210 GPS Receiver
No map
Apr 13, 2008 | Magellan eXplorist 210 GPS Receiver
Explorist 300
Jan 04, 2007 | Magellan eXplorist 300 GPS Receiver
Magellan Meridian Platinum GPS Receiver Logo
189 people viewed this question
Top Magellan GPS Experts
Marvin
Marvin
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
