Question about Maytag PAV5158A Top Load Washer
Washing Machine leaks intermittantly
I have a Maytag Performa top leader Model # PAV5000AWW that leaks intermittantly. When it leaks it does not leak allot, roughly the equivelant of a glass of water or 2.
I have taken the back pannel off and run it though several cycles. None of the discharge hoses leak, nor can I find any evidence that leaking has taken place there. I have leveled the washing machine so it is perfectly level in both directions. I replaced all the incoming hoses with new ones as well as new washers. Since replacing the hoses there is still an intermittent leak, but not from the hose area.
I have noticed that occationally that the timer will show that the load is finshed, but when I open the lid there is still 1/4 to 1/3 of a tubfull of water left. last night I ran a load and wathched it the entire time, everything worked smothly with no leaks.
Any suggestions?
  • 734 Answers
It leaksYour washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
During drain and spin only
All the time
During fill only
If the washer leaks only during the fill cycle, check these:
Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
All the time
If the washer leaks all the time, check these:
Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Posted on Dec 12, 2008
Hello - we have a top loading Maytag Performa washing machine that leaks water during the spin cycle when my wife is washing heavy items that she has placed on center spindal to avoid an unbalanced load....
Maytag Epic is leaking water from the bottom about 8 or 9 inches from the front door back on the right side. Is there and thing i can do. It only about 2 years old or less.
Oct 13, 2009 | Maytag Performa PAV2200
Washer overflowed, water all over the floor, any
you have a leaking pump and need to replace it.
Sep 14, 2009 | Maytag Performa PAV2200
Maytag performa mod#pav2200aww leaking between rinse and spin cyc
My Performa started leaking from the Drain Pump rubber gasket. It had dryrotted. However, Maytag doesn't make a replacement O-ring gasket. You have to buy the whole new pump! Thanks Maytag.
Jul 05, 2009 | Maytag PAV2300 Top Load Washer
Water leaks into washing macine tub even when it
Your inlet valve is defective, can be easily changed. Approach your dealer with your model number he will direct you to the spares shop, or tell you where you can get it. Or google 'roper washing machine spares' RepairClinic.com (which is good)
espares.co.uk
AppliancePartsPros.com
Try these sites.
Feb 23, 2009 | Maytag Performa PAV2200
Maytag Performa PAV2300 washer leaks
Hi hindsr
I dont know for sure what it is but i would guess that the tub is going off balance during the spin just befor the rinse and the tub is not centered. so what happens is watter hits the top of the tub and runs down the back (inside) and thats where the water is comming from.
brent
Sep 22, 2008 | Maytag Performa PAV2200
Maytag Performa washer
Hi jamac74
The leak could be comming from one of 2 places, either the pump or the main seal. the best way to find wherer the leak is comming from is to take the front panel off. you can do this by poping the top up there is 2 clips that hold the top down. use a putty knife to pop the top up then there is 2 screws holding the front on.
Sep 16, 2008 | Maytag Performa PAV2200
I have a Maytag (Performa) Top loader. The washing machine is leaking water from the pump. It appears that the rubber seal is causing the leak. Where can I get such a rubber seal?
Searspartdirect.com carries all the major brand names. Just type in your model number in the search menu and use the exploded view diagrams under the various parts headings on the next page. If you do not wish to order on line, or wish to use another website, use the part number provided on the Sears website. Maytag identifies some of their parts by different series. If the part you need is listed this way and you are confused, please post back and I can assist. Make sure you provide your model number for me. I hope this helps you.
Aug 11, 2008 | Maytag Washing Machines
MAYTAG PERFORMA is leaking
the bearing and seal are worn and leaking. if the machine is a good oe and the repair cost is reasonable, i would have it repaired. contact your local repairshop and determione the cost vs replacement of machine
Nov 16, 2007 | Washing Machines
Washing machine
Try replacing the rubber washer inside the female side of the hoses
Aug 29, 2007 | Maytag Performa PAV2200
Maytag Performa Washer
when you put the drain hose on the floor the water will ALWAYS drain out. When the drain is in the proper location (above the height of the tub) and the water is still leaking, if its leaking as it fills you might have a loose hose,or a cracked water inlet valve. If after the water is in the tub and its still leaking you have a bad seal.
Jul 03, 2007 | Maytag Performa PAV2200
Maytag PAV5158A Top Load Washer Logo
265 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
