Question about Ariston Technologies AW129NA 16 Lbs Front Load Washer
Ariston AVL82 can not open the door
I am using washing-machine Ariston (Model AVL82) and it can not open the door after washing. Could you please show me how to solve this problem.
I hope to receive your prompt reply at the soonest.
Thanks & Best regards
Nguyen Duc
vanduc.nguyen@vtc.vn
dazmaraz
  • 67 Answers
SOURCE: Washing Machine Door will not open
it is poss that you pressure system has not released, and this can keep the door closed. Unplugging it will not cure this fault. It is also poss that you have a blocked filter or waste. Unfortunatly has you are older people I would call an engineer
Posted on Jul 24, 2007
SOURCE: ariston margherita washing machine
I have the same problem. Was anyone able to fix?
Posted on Oct 28, 2008
  • 3 Answers
SOURCE: Ariston "Margarita 2000" Model AL129X [front load washing machine] - Clean sludge from door seal.
I don't think it is easy to remove it, but you can clean it with white spirit or something similar.
Posted on Oct 29, 2008
barkencoa
  • 3463 Answers
SOURCE: Ariston Front Loading Washing Machine error code F07
Error code F07 is indicating that the heater relay is stuck for one reason or another.
This could be a board problem, as this where the relay is located.
However, it would be worth checking that the heater is o/k before you do anything else., as this possibly could cause the relay to malfunction.
Plz rate my solution.
Thanks.
Posted on Jan 13, 2009
SOURCE: Ariston A1635 Margherita Control knob spinning
According to the instruction book - it appears the machine has been stopped mid cycle then re-started.
Switch machine off, turn control knob to a solid circle symbol (they are after every set cycle). Switch machine back on and lights will flash and program is reset. You can then select wash cycle as normal.
Posted on Jan 23, 2010
Can not open the door Ariston, 8.5kg,
HI THERE.
THIS IS ALL I COULD FIND ABOUT HOW TO OPEN A DOOR THAT IS STUCK.
how to open washing machine door that is stuck Google Search .
go to this link and have a look and see if it helps you out.
Nov 04, 2017 | Washing Machines
Cannot open Wash door
Here is a tip that I wrote about how to get your washing machine door opened...
Washing Machine Door Jammed
heatman101
Jan 24, 2011 | Ariston Technologies Ariston AWD12 Front...
Door handle on ariston awd12s has broken how i can i get the door open
open the table top of the machine and release the door switch by any flat screw driver
Jun 06, 2010 | Ariston Technologies Ariston AWD12 Front...
ARISTON WASHING MACHINE DOOR PROBLEM SO ON/OFF BUTTON DOESNT WORK
Well it depends on how old your machine is, if eveything else is fine then replace it. The cost will vary depending where you buy your part from. It could cost but worth it if machine is reliable. try
www.lpdlpd.co.uk
Aug 09, 2009 | Ariston Technologies AWD120 13 lb. Washer...
Cant open door of washing machine
I plugged it out. Left it for 15 minutes. When I went back the door could be opened and it also started to wash.
Jan 20, 2009 | Ariston Technologies AWD121WH
Door Stuck after wash completed
You will have remove top cover, and release door latch from inside the front, with a screw driver pushing against the latch to open door.
It does mean that you probably have a faulty door lock, or broken door handle.
Please rate my fixya solution.
Thanks
Jan 11, 2009 | Ariston Technologies Ariston AWD12 Front...
Jun 23, 2007 | Ariston Technologies AW129NA 16 Lbs Front...
Ariston Technologies AW129NA 16 Lbs Front Load Washer Logo
177 people viewed this question
Top Ariston Technologies Washing Machines Experts
Darren Moxam
Darren Moxam
Gerry Harvey
Gerry Harvey
Are you an Ariston Technologies Washing Machine Expert? Answer questions, earn points and help others
