Question about Ruud UAMB Air Conditioner
Ruud air conditioner unit
The unit works fine until it is shutting off. There is a loud scraping noise. Have checked the motor and that works fine. Please tell me what could be the problem. The model is UAND-636JAJ
    Champion:
  • 254 Answers
Sounds like you have a fan blade out of balance or one that is bent which when the unit winds down it becomes out of balance use a straight edge across the blades to see if any are bent.
Posted on Jun 13, 2008
Loud clunking noise when the A/C shuts off
Mine just started doing the same thing. I took the panel off tonight and 2 of the 4 brackets holding tthe fan in place are cracked. Guess I'll be calling the Ruud guy tomorrow.
Jul 20, 2011 | Ruud UBHC Air Conditioner
Carrier Air V unit with loud noise
If it sounds like a scraping noise it could be the motor bracket ah broken and the squirrel cage (fan assembly) is hitting the fan housing, if it is more of a squeal than it very well could be a bearing. Very hard to guess without seeing or hearing it.
Nov 02, 2009 | Carrier Heating & Cooling
Our air conditioner unit makes a tremendous amount
Sometimes we need to just replace our old equipment.
Jun 30, 2009 | Heating & Cooling
RUUD 13 SEER HEAT PUMP MALFUNCTION 2009 MODEL
I sell Rudd equipment. You have air in the system or faulty TXV. Replace TXV and evauate system. No more problem. Rusty
May 27, 2009 | Heating & Cooling
Compressor of the Ruud A/C outside unit is making unusal loud continuous noise. I open the case, its not the fan or fan motor, loud noise is coming from the compressor, and it is also heating up a lot....
OK, you will need to replace this compressor. the internal seals have ruptured, causing the loud noises. the heat is from the metal to metal friction. the compressor can be rebuilt but, it will be more costly than just replacing it with a new compressor.
May 27, 2009 | Ruud Handle Air Conditioner
RUUD 14 seer heat pump makes loud squeeking noise after cycling.
Your problem is the TXV. I just had person with the same problem. Replace TXV no problem Rusty
May 01, 2009 | Ruud UAMB Air Conditioner
New 14 seer split ruud heat pump makes very loud knocking noise
Well you may want to have a tech come out and check the freon level, but mostly when going into defrost, some units make alot of noise, the freon is reversed in the unit by way of the reversing valve, it makes a whooshing sound like freon is draining off, as far as the knocking noise, could be as I said in the beginning, might be low on freon, but it could be that, this particular unit does this, I have had units make some really strange noises in the past but functioned perfectly, hope this helped, please let us know, thanks again,
mr.grzz
Jan 24, 2009 | Ruud UAMB Air Conditioner
Making a loud noise...
I requested clarification for your problem and did not receive a response. Please re-post your question if you would like help. Thank You
Jun 12, 2008 | Ruud UAMB Air Conditioner
Ruud achiever 10 seer air conditioner
It sounds like your condenser fan motor may be locked up or the capacitor that helps give the condenser fan motor a kick to get it started may be defective. Try turning your system on and using a long screwdriver try to push the fan blade on the condenser fan motor to see if it will run normally if you give it the starting boost it needs.If it does run at full speed and doesn't over heat or start and then slow down then you probably only need to replace a simple 10-12$ capacitor. If it barely turns, makes an odd humming sound or overheats etc. then you will have to replace the condenser fan motor. This is assuming that the outdoor condenser has the 220v supplied and the 24v supplied to the compressor relay, that the compressor relay is engaged and suppling 220v to the condenser fan motor.
May 28, 2008 | Ruud Matching Split Air Conditioner
Ruud UAMB Air Conditioner Logo
115 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
