Question about Brother GX-6750 Typewriter
Daisy wheel J, is there a starting point that the daisy wheel needs to be set in order for correct letters to be typed
  • gecko69 Jun 12, 2008
    nevermind the daisy wheel now, but i've opened up the top cover and looked to the right and I don't see any switch with 3 settings...????
  • Anonymous Mar 27, 2014
    Can you help me with this?
This is a piece of **** typewriter, and just throw it out.
Posted on Aug 17, 2008
When typing with my brother gx-6750 it types weird lingo is the type set messed up or can I reset them?
Your daisy wheel letters are bended not straight.
Switchoff just remove your daisy wheel & remove the daisy wheel from its cover & see all the letters should be straight.If any of them is bended jst make them straight by your fingers dont press too hard & then fix the daisy wheel back & switch on typewriter.
Jul 20, 2010 | Brother ML-100 Typewriter
My typewriter (Brother GX-6750) does not print correct letters
look for bent or broken spokes on daisy wheel .turning unit off for 20 seconds and back on should reset the daisy wheel home position. probably the daisy wheel.
Oct 26, 2009 | Brother ML-100 Typewriter
Its not typing the correct letter. When you type. U can hit letter ''t'' and may type a ? mark.
if turning off for 20 seconds doesn't fix it look closely at the spokes and letters on the daisy wheel for bent or broken spokes or letters. replace daisy wheel if bent or broken about $35.00.
Sep 24, 2009 | Brother GX-6750 Typewriter
The keys will not type the letters they are labeled with.
Do you have the daisy wheel cartridge inserted correctly? The "ear" on the daisy wheel cartridge should always be on the upper right.
If that doesn't fix it .....Try doing a daisy wheel reset by Pressing [CODE] + [RESET]. This will properly index the daisy wheel.
Mar 25, 2009 | Brother SX-4000 Typewriter
HELP..BROTHER DAISY WHEEL TYPING RANDOM LETTERS AND SYMBOLS
Press the Code button and the Q/Reset button at the same time and the wheel will spin and go back to the correct place.
Feb 06, 2009 | Brother SX-4000 Typewriter
I have a Brother WP-2000 word processor and when I changed the Daisy Wheel the letter typed is not printed and another letter or symbol is printed. How do I align the daisy wheel so this does not happen
Turn the typewriter off, remove the daisy wheel.
USUALLY there is a small rectangular slot in the daisy wheel that points up.
Insert wheel and turn on.
Make sure your spacing is NOT set to PROPORTIOAL SPACING
Nov 20, 2008 | Brother Office Equipment & Supplies
Brother GX-6750 Daisy Wheel
Install wheel, turn machine on and off this resets the printer and home timing. If it still does not correctly, adjustments needed..
Apr 23, 2008 | Brother GX-6750 Typewriter
Wrong letters typing
it sounds like you were using a non-brother correction tape,one that was too sticky and consequently too "slow" and during the correction sequence the fingers of the daisy-wheel got entangled with the tape. Make sure that the correction tape is of a "non-sticky" nature and then take off the correction and printing tapes. That way you will see better how the daisy-wheel is fitted . I will assume that you have an instruction book to show how this is done. before fitting the daisy wheel examine the fingers to see that none are bent or crossed over each other. If this is the case it is better to buy another one. bring your typewriter to the shop if this is the case and they will possibly re-fit the wheel for you. good luck.....
Mar 19, 2008 | Brother ML-300 Typewriter
GX6750 Typing wrong letters
Linda,first of all,does the daisy wheel spin when the typewriter is first turned on? if it does,then you will feel assured that it is installed properly. Next, refer to your manual to key board settings. It will indicate that there are settings for normal standard English keyboard and somehow that setting may have been changed. It would be also be important to check the daisy wheel to see if it is compatible with standard English keyboard...Cheers, John
Oct 21, 2007 | Brother GX-6750 Typewriter
Not typing the correct letters
The ML-300 needs to be reset each time the Daisy Wheel is removed or replaced or if the Keyboard Switch changes position. According to Brother, if this is not done the typewriter will print incorrect characters. Try these steps: 1) Open the Top Cover. There is a lever directly behind the Daisy Wheel. Pull the lever back towards you. Remove the Daisy Wheel by pulling it up and out. 2) Verify that it is the Standard Daisy Wheel that came with your machine and not a Symbol or International Daisey Wheel. Write down the Pitch (10, 12, or dual pitch 1012) printed on the wheel. 3) Reinstall the Daisy Wheel (the plastic top ear goes to your right.) Push the lever (step 1) forward. 4) Press the ALT key plus the PITCH key and the number 1 key simultaneously. Verify the Pitch setting is the same as is printed on the Daisy Wheel. 5) Press the CODE key plus the RESET key and the letter Q key simultaneously. This will reset the typewriter mechanism and align (or time, in technical terms) the carriage mechanism. Check if the typewriter prints correctly now. If still incorrect, perform these additional steps. 6) Verify the three position Keyboard Switch (inside the top cover, on the right side, at the bottom) is in the I=Standard position. The other positions are: II=International and III=Symbol. 7) If the Keyboard Switch is in the correct position, slide it to position III and then back to I. (This will clean the switch contacts in case they are dirty and not making good electrical contact. 8) Press the CODE key plus the RESET key and the letter Q key combination again to reset the typewriter mechanism. Check if the typewriter prints correctly now. If still incorrect, the only other things I can think of is that: 1) an incorrect Daisy Wheel is installed that does not work in the ML-300. Brother sell a "B type" Daisy Wheel with two plastic ridges/raised slots below the center of the Daisy Wheel (viewed with the raised top tab on your left.) The B type are incompatible with your machine. 2) the typewriter has failed and needs repair.
Sep 28, 2007 | Brother ML-300 Typewriter
Brother GX-6750 Typewriter Logo
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
