Usb 2.0 10 GB Flash drive hard drive not being found
    Sergeant:
  • 203 Answers
What kind of flash drive and computer are u working with? Let me know and I may be able to give u a more accurate answer. Try inserting another device in that USB port and check to see if ur computer is recognizing it in your device manager. Click on Start Tab then Go To Settings , Control Panel Then Click on System Icon , Then Click on the Hardware Tab and Click on Device Manager, scroll down to see if there are any yellow question marks or flags? Leave that Device manager window open and try to re insert your flash drive again and see what response u get?
Posted on Jun 12, 2008
How to remove write protection
How to tke write protection off a pny attahe? - Hard Drives ...
www.tomshardware.com > Forum > Storage
Tom's Hardware Guide
Sep 22, 2012 - 6 posts - ‎3 authors
Hello, I have a 64 gig attache 2.0 flashdrive. ... I could not see a write protect switch in the PNY product guide, but just ... I've been trying to do this for nearly a year and today found the tool to format my 64GB PNY flash drive. ... the Link you provided and downloaded the recovery tool for my PNY USB 64 Gb ... USB Flash Drive is write protected and shows up as ...
Nov 11, 2012
Remove write protect flash memory USB - Flash Media ...
Nov 30, 2009
More results from www.tomshardware.com
how do i take off my write protection off
Jan 16, 2016 | PNY Attache 64GB USB Flash Drive
How to use flash drive
you just need to plug in the usb hard drive to a usb port when the computer is turned on & you get the desktop. a message will appear "new hardware found" & then " installing driver for usb hard drive". when you get the finish installing driver message, you can use that drive.
Sep 22, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
I deleted all the memory in the flash drive, its a 2 gb, but it tells me that theres only 41mgb in it.
Try emptying you trash on the computer that you deleted the information on. Or recycling bin depending on the type of computer. When you "delete" the information from the flash drive, it does not permanently delete it until the "Trash" is emptied.
May 20, 2011 | Memorex Mini TravelDrive - USB flash drive...
I can't to format my 8 G flash(message:write protect) i used the Repair_v2.9.1.1.exe ,but it message that the usb flash not found. plz help me
Any time you see "write protect" it usually means there is a small switch on the device which prevents deleting data accidentally, even by writing over it.
Look for a small sliding switch and flip it to opposite position. That should fix it.
Dec 23, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
I am not recognising kigston data traveller
When the flash memory USB hard drive device appears to malfunction it maybe possible to restore it by reformatting it. Insert the flash or USB hard drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Then right click on Disk 1 removable drive and click Format. After the flash drive has been formatted it will indicate that it is Healthy.
NOTE Formating the USB flash drive will delete your data.
May 11, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Usb Drive Not Formating
Usualy particalar usb sticks are poor quality and may problematicate, especialy if in the middle of doing something and abruptly powered off.I have found one to not be able to format/reformat after situation mentioned above occured.Only solution is to clain guarantee...
May 27, 2009 | Computers & Internet
USB problem
I had the same kind of problem with my 32GB Transcend USB Flash drive. I tried all the things I found in the internet (Apacer software, Registry fixes, Kingston software, HP Flash Disk software, you name it!) but nothing worked. Always I got Write protected error. Finally I found the program called MiniRMATool which solved the problem. Search MiniRMATool_XP2K_v1.rar in Google, run it and then you will be able to format your drive.
Jun 20, 2008 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Flash drive not work at all and indicate buld is not flashing
Hi
When you plug the flash drive into the usb did it shows new hardware found like that in the task manager?
Jyo
Jun 19, 2008 | Kingston (SDCZ2-512-A10-KT)...
Computers & Internet Logo
49 people viewed this question
David Payne
David Payne
