Question about Dell 3100cn Laser Printer
Close the front door problem.
I have a problem with my dell 3100cn printer.
For the last few weeks it has stopped working at all. The message it displays on screen is
  CLOSE THE FRONT DOOR
I have tried all options which I could. Front door is perfectly closed but message still does not disappear.
What I think is, that this is a door sensor problem which has stopped working.
Please help me in this regard.
RUCER
  • 1 more comment
  • tp1212 Jul 07, 2008
  • EKoziol Aug 07, 2008
    Close front door error. Front door is closed. Powered off and on and keep getting same error. Any suggestions before I call service?
  • Anonymous Apr 14, 2009
    same
    Scholar:
  • 148 Answers
Reset drum counter
I found this solution online for you:
Shut off the printer.
  • 2 Hold down the "Continue" button while opening the front door. Then turn on the printer.
  • 3 Keep the Continue button held down until only the "Error LED" is on then release the button. Close the door.
  • 4 The Continue button, Ready/Data, Toner Low, and Load Paper LEDs should all be lit up.
  • 5 Press "Cancel" a few times to cycle through the LEDs until just the "Toner Low LED" is lit.
  • 6 Press and hold the "Continue" button until the LEDs cycle through and release only when the LED stops at Toner Low.
  • 7 Turn the printer off and back on.
  • Mar 27, 2013 | Dell 3100cn Laser Printer
    We are getting error code 004-332 Restart Printer on our Dell 3100cn printer. We have tried unplugging and restarting print spooler but it still come up witht message when we try to print
    Hi
    This error code on Dell 3100CN occurs when toner cartridges are not seated properly and/or are not properly locked in. Turn off the printer and unplug it. Now, you need to open the front door and pull out the drum. Try moving the carousel and check if it moves freely. While moving the carousel back and forth try adjusting the cartridges. try to unlock the cartridges and lock them again.
    Now turn off the printer and turn it on after 1-2 min.s.
    Daniel Scott
    Jun 24, 2010 | Dell 3100cn Laser Printer
    Close front door message keep showing up every time I print and it will not print
    I've had this issue at our office. You need to perform a factory reset on the printer following the directions in the owners manual, or contacting Dell telephone support. (1.800.WWW.DELL)
    Jan 03, 2010 | Dell 3100cn Laser Printer
    Dell 3100cn
    the BTR cover is also called " Bias Transfer Roller " cover it should be that roller that seen when open the front cover most likely the Bias transfer roller door sensor in NOT detecting the dorr closed. make sure the tab isn't broken this will produce this error if it is.
    Jul 23, 2009 | Dell 3100cn Laser Printer
    How do I remove all the Dell 3100cn toner cartridges
    First open the top door, pulling out the drum. Leave the door open.Then open the front door.
    Then close it slowly. While doing this, move the carousel. The carrousel is free while the
    door closed and locked while it open.
    Mar 21, 2009 | Dell 3100cn Laser Printer
    Paper Jam Error on Dell 3100cn Laser Printer
    Push the side button and open the front cover
    Pull out the jammed paper from the duplexer. If jammed paper cannot be found, go to the next step.
    Pull up on the belt release levers and rotate the belt unit up
    Remove the jammed paper and close the belt unit
    Close the front cover
    Jan 03, 2009 | Dell 3100cn Laser Printer
    Error message, ''close BTR cover'' for Dell 3100cn
    The BTR cover is covered the fuser. If you open the rear door, it is located at the upper part, behind the metallic rod. The problem is the cover is installed unproperly: Its metal piece is not touched against the metal piece of the machine, so the machine does not "smell" the BTR cover.
    Nov 18, 2008 | Dell 3100cn Laser Printer
    Close reg cover
    After researching the error online, I solved my problem by simply pushing the back cover of the unit closed; I didn't even know it had come open after I removed my jam.
    Hope this helps!
    http://support.dell.com/support/edocs/systems/3100cn/en/UG/section20.html#638412
    Jul 18, 2008 | Dell 3100cn Laser Printer
    Dell 3100CN Error Message
    I am a publisher here in Seattle printing full color books with this machine and I have just gotten the same message- Does anyone have a solution- I have Googled and checked everything... Now, this happened to me a few months ago and I pulled out the drum and sprayed it with air, replaced it and it worked fine for about two months- now I get the error again- does this help in the problem solving?
    Jul 01, 2006 | Dell 3100cn Laser Printer
    Dell 3100cn Laser Printer Logo
    753 people viewed this question
    Top Dell Office Equipment & Supplies Experts
    jasbo
    jasbo
    Electro Med Services...
    Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
