Question about Epson Stylus RX680 Color All-in-One InkJet Photo Printer
My black ink cartridge ran out and it was 2 weeks before I replaced it-the old cartridge was still in the printer. Now with all new cartridges it will not print solid black-only a grey color instead of black. The other colors print fine-Epson rep said the unit is malfunctioning after we tried head cleaning 8 times-also the head cleaning has now reduced brand new cartridges to 1/4 full!!! Epson said it would be cheaper to replace the entire printer than have it serviced. If this is true due to ink usage and reliability I will NEVER own another Epson printer.
  • 386 Answers
Hi Good day!!! if you try the head cleaning for 1 dozen of time and nothing has change, try this one method I'll give you, before you buy a new printer. all you need to have is a cleaning solution kit and a syringe.
1. remove the cartridge to expose the nozzle that feed the head
2. fill syringe with 2ml of your cleaning solution.
3. push end of tube over the nozzle that takes ink from the cartridge.
4.gently push the syringe allowing 1ml of cleaning solution to pass down the tube and into the head
5. leave the syringe in this position for couple of hours to allow the fluid to soak the dried ink particles.
6. after a couple of hours gentle push the rest of the fluid through the end
7. the next few prints may be contaminated with cleaning fluid and you are advised before carrying out any prints to do a full head clean using printer utility.
8. if after step 8 you still have a problem you can repeat the operation up to step 6, but instead of pushing the fluid through the head draw the fluid back into the syringe, and then back to the head, this causes fluid to move backward and forward in the head assembly, you should notice air bubbles and very small dried ink particles whist doing this. Please note while this product will remove stubborn dried ink particles it will not damage print head.
Don't forget to vote thanks!!!!
Posted on Nov 02, 2010
LaserJet 1010 Printer: I ran out of ink. But now with the new laserjet in...
First check with any other toner cartridge of same model.. if problem continues, probably ther is a problem with printer circuit board..
May 16, 2010 | HP LaserJet 1010 Printer
My ESP 7 printer will not accept that a new black ink cartridge has been inserted. I've tried 2 new ones, same with both.
Black ink cartridge is not recognized. I installed a new cartridge last week and had no problems printing till 2 days ago. What can I do to resolve this?
Sep 13, 2009 | Office Equipment & Supplies
Printing issues TX400
That is basically true. You have a clog. You can try to save the printer by continually running through the black ink cleaning process. Might as well, you already replaced the cartridge, and you won't be able to use the cartridge in another printer since cartridges are now electronically tagged.
Aug 25, 2009 | Epson Office Equipment & Supplies
Large black ink cartridge won't print
please send me your printer show any signal
Jul 22, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Have to clean black ink evrytime I print a page, otherwise black
remove all the cartridges and pour 2/3 drops of carbon tetra cloride [ctc] on the nozzles leave it for some time and switch on and off twice the printer
Feb 07, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Problem with new ink cartridge
More that likely the refilled ink cartridges are faulty and should be replaced. While some folks have pretty good luck with refilled cartridges, it is generally better to stick with the new ones.
As to the problem with old cartridges, keep in mind that the estimated ink levels are just that - estimates. However, if your printer has an option for cleaning the cartridges, try that before chunking them. Take them out, put them back in, and run the cleaning process. Sometimes the nozzles can get clogged up and running the cleaning process will clear them up. ( DO NOT TRY TO CLEAN THE CARTRIDGES MANUALLY!)
If none of this helps, you will more than likely just need to get some new cartridges. - Graye
Oct 29, 2008 | HP PSC 1410 All-In-One InkJet Printer
Not printing after color cartridge ran out - new black cartridge installed.
Yes, this printer has fixed printheads and must have ink in each color to prevent damage to the printheads. Even when printing black only each color is spit in the servicing area to keep the printhead unclogged.
Regards,
Bob Headrick, Microsoft MVP Printing/Imaging
Jul 18, 2008 | Epson Stylus C60 InkJet Printer
Lexmark X3480
There are 2 possible problems, or the cartridge is a refilled one or some problem by the cartridge itself. Try to change the cartridge.
Nov 10, 2007 | Lexmark P6250 All-In-One InkJet Photo...
Dell 922 All In One Printer wont print
did you remove the seal of new catridge. bye
Sep 24, 2007 | Dell 922 All-In-One InkJet Printer
Ip4200 stopped printing...help!
dear oceantracks maybe one of the black cartridge chip think that ink is running low or not ink is left in the cartrridge.
Nov 21, 2006 | Canon PIXMA iP4200 InkJet Photo Printer
Epson Stylus RX680 Color All-in-One InkJet Photo Printer Logo
141 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
