Question about EliteGroup PT800CE-A Motherboard
No display i have a problem regarding with my pc...when i turn on my cpu i just encounter that it had no display and the red light is just turn on at all and nothing happens and there's no beep that i can hear..but sometimes i just turn it on easily..please help me..
  • enigma pulp Jun 29, 2008
    help me!!!!!!!!i want to try some more...........
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Champion:
  • 202 Answers
It means your system is not booting, check the memory module look for replacement, When you get a ne memory module and fix it and with this it should boot. Good luck
Posted on Jun 12, 2008
2 red lights on CPU board
I will assume that you have the first on/off switch turned on and the one for the element is not turned on. The machine is saying it is not ready to dispense hot water or steam.
Apr 20, 2014 | Rancilio Classe 10 Espresso Machine
When the PC on there is red light blinking and making warning sound have checked the ram and also all buses are well fixed and also not showing bios please help me. Thanks & regards Partha
friend hp this fault make from two reasons first of all voltage that you give low voltage to your cpu please diagnose it and make a powerfull voltage connection for your cpu and 2nd is definatly your ram so replace your ram. your old ram will run in another cpu but not in that one so you can replace it easly.
Jul 16, 2011 | HP Compaq dc5100 Small Form Factor PC...
Monitor does not turn on i have already unplugged it form the pc on rebooted the system no use
check the display card in side the cpu for any loos connection and use a blower inside the cpu to clean all the dust particales
Regards
reply
Sep 17, 2009 | Computers & Internet
Pc shut down. when resterted no graphics or
Hello
Regarding with this problem, when computer which is shutting down. It is the processor problem they can not reach the temperature. Be sure that the CPU fan is spinning so that it will control the CPU temperature. If the fan is not spinning it will cause overheating. Try to disassemble the unit specifically the CPU. Clean your unit remove the dust, when you assemble back your unit make sure that you will put a thermal paste between the CPU and the CPU heat sink so that the of the CPU will absorbed by the heat sink.
Regards
PCmania
Sep 04, 2009 | Computers & Internet
My desktop computer display black ,but CPU light is on -one yellow and one red , monitor light is on , keyboard light flashes on start and then stopped. Sometimes computer start after switch on , window...
you posted several problems and some are resulted in your trying to diagnose the problem. IF the monitor is black yet you can see the cpu lights meaning it is reading but does not power up all the hardware. In my years of experience in solving hundreds of computer. This is primarily cause by memory or video card. Just re-install or re-insert the memory or video card. This will likely solve the problem. IF just in case the problem still exist replace the memory (RAM) or the video card to check which of which has the defect.
In regards to your computer performing disk scan, this is part of windows utility to fix the hard drive. This is usually cause by pressing the reset button. This appears because when your computer does not power up you reset it. This is normal and nothing to worry about.
Have a nice day in cyberworld
Aug 28, 2009 | Computers & Internet
Won't turn on blinking red where green power lights should be.
plase open the cpu & plug in the ram in the right order.
Dec 10, 2008 | HP Compaq d530 PC Desktop
VISTA:The NTVDM CPU has encountered an illegal instruction
The link below is a step-by-step troubleshooter from the Microsoft website. You'll just need to follow all the instructions on the site and you should be able to fix it all by yourself. This seems to be a common error with windows.
Troubleshooting NTVDM and WOW Startup Errors
Sep 10, 2008 | Computers & Internet
Computer would not boot up, only showed red light
If the repair store said the CPU or MB is bad... buy a newer computer.
Jun 08, 2008 | AMD CISNET A7021 MT A/3000+ 512MB 80GB...
No signal on first boot
I think is a power supply problem,,
Mar 10, 2008 | Nokia 445 Pro 21" CRT Monitor
IBM ( Old ) NETVISTA DESKTOP PC No display
hi there, try to remove the video card and put it back again, turn it on and try to hear beeping sound or see if it is ok. if still same problem, identify if your monitor works or not and proceed to the system unit, may be the main board is mulfunctioning. do some test. ty
Dec 24, 2007 | IBM NetVista PC Desktop
EliteGroup PT800CE-A Motherboard Logo
55 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
