Question about Epson Perfection 4990 Flatbed Scanner
SCAN STOPS MIDWAY
THE SCANNER IS CONNECTED VIA FIREWIRE. ONE PROBLEM IS AFTER ONE OR 2 SCANS, THE COMPUTER THINKS THE SCANNER IS NO LONGER CONNECTED. I HEED TO UNPLUG AND REPLUG THE SCANNER. THE OTHER PROBLEM IS THAT DURING A PREVIEW OR SCAN, THE SCANNER FREEZES.
HELP!
  • editvideo Jun 15, 2008
    Thanks to all for answering. Looks like it was a bad firewire.
  • Johann Toledo
    Johann Toledo May 11, 2010
    What operating system are you using? Mac or Windows? Please post the complete information for your computer.
    Windows Xp 32bit or 64bit
    Windows Vista 32bit or 64bit
    Macintosh 10.5.x - intel processor or powerpc
    Macintosh os 10.4.x intel processor or powerpc
    Have you tried a different firewire cable or try to use the usb connectivity of your scanner?
  • 54 Answers
10.9.3 or 10.3.9?
Since you are running on a Macintosh environment, lets try to use the generic application by macintosh and it usually is embedded already when you install or get a mac computer.
From you desktop, double click mac hd > go to applications folder then look for Image capture, try to scan from there one by one. This will verify if the connectivity is intermittent or if its a bad cable. If the issue persist when you are scanning from that generic app then you may want to try to use a different cable.
Posted on Jun 12, 2008
Usong Mac OS 10.9.3 G4 dual gig. Firewire hookup was working fine until now. No error light. Green light on scanner blinks. Lamp returns, but import stops about half way, and rainbow circle spins on computer. Using Photoshop CS to import from. Thanks.
    Genius:
  • 1,447 Answers
Are you getting an error/ red light on the scanner button when its on? when scanning from Paint ( File, then from scanners and cameras) does it freeze as well? or only when using epson scan? make sure cable is directly connected from the scanner to your computer, no hubs or anything.. keep me posted.
Have a nice day!!
In spite of the fact that I properly downloaded and installed my ION Film 2 SD Plus Slide and Film Scanner into my Toshiba Laptop computer, I cannot scan anything into it. I repeated the downloading a
i am surprised that it is not a stand alone scanner. for almost the same price i have a wolverine which basically works on mains power, or powered from laptop. it scans and stores the images in the unit. those can be later transferred to the laptop while connected via usb. one question, does the scanner lcd show the scanned image? if not may be something is wrong with the unit itself.
Nov 25, 2014 | ION Audio Film 2 SD Plus Slide and...
How do I download program for wolverine pass 200 portable scanner?
The Wolverine Data Pass-200 portable scanner uses a micro-sd or sdhc memory card to store scans. After you scan something, you can remove the memory card and plug it into a memory card reader connected to your computer and view/download the scans.
Alternately, you can connect the Pass-200 scanner to your computer via a USB cable and access the scans like you would with a digital camera. Look for a new removable storage drive to appear on your computer once you connect the Pass-200. On the new drive, look for a DCIM folder and 100DEDIA folder for the scans.
As far as I can determine, the Pass-200 does not conform to any scanner interface or API standards such as Scanner Access Now Easy (SANE),TWAIN, Windows Image Acquisition (WIA), Image and Scanner Interface Specification (ISIS) so there is no driver or software to install to scan using the computer.
Oct 13, 2014 | Computers & Internet
Connected older firewire cable with adapter to my 9950f via mac mini?
Your connections sound confusing, but you are correct about connectivity being your problem. The more wire and connections between any device and your computer, the worse the results. I have few devices requiring a firewire. Scanners have to transfer a lot of data very quickly. Printers too but they will usually function, just slowly. Your best bet is to simplify it somehow. A long time ago firewires were going to be the big thing by 2000. It never happened and few pc's come with a firewire. I have an old pc I drag out when I need the firewire and it's a big pain. What you are trying is experimental and I guess I'd be trying the same thing. Good luck finding simplicity because it's your best bet.
Jul 10, 2014 | Canon CanoScan 9950F Flatbed Scanner
Dear Sirs/Madams, I have a Muratec MFX-1930 network multimachine (printer,scanner,copier,fax). Everything is working fine i can print, fax, copy and scan. My problem is the scanner scans to internal...
Unless your machine is connected via ethernet cable.( NOT USB.!!) you will not be able to scan directly to a Network folder.
Anotherwords..you can scan to a Network folder if its an RJ45 cable but NOT if your using USB.
If you are using ethernet the machine should have come with the appropriate software...if you have lost it you can get it at www.muratec.com .
**If you are using USB...installing the Network software will NOT make it scan to folder.
Apr 01, 2011 | Muratec Copier
Adf does not scan all pages
Try cleaning the rubber rollers in the ADF
S. Mohan
Sep 29, 2009 | Ricoh IS 450DE VRS Flatbed Scanner
Kodak AiO 5500 scanning problems.
If you are running Vista, you can still scan and copy by using Windows Photo Gallery.
1. Click on files tab at the top in Window Photo Gallery.
2. Click on import from camera or scanner.
3. Highlight your scanner icon (eg Kodak 5500) then click import.
4. New scan window will popup, now you can preview or scan using this basic looking Vista utility.
Hope that helps.
Chris (ziraffa)
Jan 11, 2009 | HP Photosmart C4280 All-in-One InkJet...
Canon mp610 scanning problem
The readme says that some USB hubs have an issue.
I was having problems and was connected via a hub. I removed the hub and connected the printer directly to the back of the PC and voila scanning is all good.
ALex.
Apr 20, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Does HP LJ 3055 printer scan over the wireless network?
Scan over wireless network is not supported with this printer. You can try set it up and get scanner to work with usb and then change port from usb to HP standard TCP/IP for the device, but I don't think it will work.
Apr 08, 2008 | HP LaserJet 3055 All-In-One Printer
Scanner or PC?
Neither is it a prob with the computer nor with the scanner.
Let me guess,
either is your usb connection cable longer than 2m or you have connected the usb printer/scanner cable to a usb hub.
Do use a cable no longer than a max of 3m and do connect the usb cable directly to the computer usb slot.
Oct 18, 2007 | Brother DCP-110C All-In-One InkJet Printer
UMAX PowerLook 1000 Scanner
try resetting your nvram file (requires restart into command line mode) Follow the instructions on this page: http://support.apple.com/kb/HT1379
I had a hellacious problem with my firewire on my previous mac with a powerlook 1100 - and NOTHING I did seemed to fix it... but this worked in a snap!
Jan 24, 2007 | Umax POWERLOCK 1000 Flatbed Scanner
Epson Perfection 4990 Flatbed Scanner Logo
464 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
