Question about Magic Chef Refrigerators
Fridge, lights went out and is no longer working
  • 77 Answers
Be sure there is power to the outlet and check the cord where it enters the back of refrige and see if any wire burnt or frayed. unusual for everything to go out.
Posted on Jun 13, 2008
The fridge is not working, the light has gone off and the temp dial is having no effect, the freezer appears to still be working.
The light switch in fridge the door has died & needs 2 b replaced!!! Maybe can be replaced by a generic switch??
Jun 29, 2014 | Smeg Refrigerators
Rl41WGIH fan on but no light and fridge isn't very cold
Bad news for you. I've had the same symptom. The problem was compressor. It seem it will not work longer as about 5 years. To buy another one and repair was expensive. I have now new fridge similar to this but I hav for compressor 10 years waranty.
Mar 29, 2014 | Samsung RL41WGIH Bottom Freezer...
The "water" light on the display panel went dim for a couple days and is now out. everything else seems to work ok. What's the problem? K
i have the same problem except mine is on a samsung RF26X side by side french door fridge and the cubed ice light went out. same as yours, the light was dim for 2 days and then went completely out. i've had the fridge since july 2010. did you get help with a solution?
Sep 20, 2010 | Samsung RM255LASH Side by Side...
Our power went out tonight for 20min and after it came back on, the light and temp displays in our Frigidaire fridge/freezer does not come on. The freezer light appears to be working and it sounds like the...
Your display panel went out and needs to be replaced. This is a fairly easy part to replace. Just call us and we'll ship your part out asap!! We look forward to working with you!
Oct 18, 2009 | Frigidaire FEB27S5A Electric Single Oven
After moving coldspot, quit cooling
I may need you ask you to do or answer a few question as we try to resolve the problem with your refrigerator. After trying to move fridge a few feet did you lay it down on side? Are lights on interior working? Is receptacle that you plugged the fridge into working properly? Have you changed the t-stat settings? Please check your model number again because I am unable to pull it up. Thanks, Sea Breeze
Mar 25, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Fridge smell
check the pipes at the back of the fridge, it could be that one of the pipes has a crack and is leaking gas or oil. If not check the inside of the fride for a brown oily residue. This indicates a leak. Don't turn the fridge back on becasue if the oil and gas mix then the fridge will no longer be usable. If you find either of these get an engineer to fix the problem.
Oct 25, 2008 | Frigidaire FRS26R4A Side by Side...
Not cooling
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jun 03, 2008 | Frigidaire FRT18G4A Top Freezer...
Fridge stopped working, freezer still works
Light going out is a separate problem. If the freezer is still working and the fan in the freezer operating check for frost on the back wall. If there is frost on the back wall you have a defrost system problem.
Possible open heater, bad timer, or defrost thermostat. If the freezer is not working check for power to it. Reset the breaker if necessary.
If the light went out because of some power loss the freezer would not be working.
May 26, 2008 | Frigidaire FRS26ZSG
Whirlpool gold refridgerator light not working and is making funny noise
Had the identical symptoms with my Whirlpool Gold GS6SHEXNB00 side-by-side refrigerator. Had a technician come on site, indicated it was the "circuit board/ timer" (Whirlpool part # 1394052). Board is accessible from behind fridge (lower left side in a white plastic housing to left of compressor).
Swapped the board out (noticed a scorched circuit on the old circuit board). Lightbulbs now work, temperature readouts also good to go.
Mar 03, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerators Logo
48 people viewed this question
Top Magic Chef Refrigerators Experts
evans_lloyd
Level 1 Expert
John Tripp
John Tripp
vince
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
