Question about Lands Phones
We have an older AT&T spirit phone system, sometimes line 1 will not work, I disconnect line 1 from the phone system box and plug back in, I then get a dial tone but the line will not disconnect, this happens on any of the 5 extensions.
  • martenstv Jun 13, 2008
    I swithched lines 1 and 2 and the problem remained on line 1. Probably a problem with the the control box
    Novelist:
  • 201 Answers
There is most likely a problem with your control unit and the CO line 1 will not disconnect. However, to absolutely eliminate all other possibilities, try swapping phone lines 1 & 2 and see if the problem stays at line 1 (which will now be a different phone number) or if the problem moves to line 2 which would indicate a problem with the wiring to the control unit.
Hopefully you do not use all the phone lines in your system and you can move them all down one slot. (line 1 becomes line 2, line 2 becomes line 3 etc...) and just stop using line 1. Otherwise you will need to find a replacement control unit.
Posted on Jun 13, 2008
Installing my answering machine to my phone
if there is a jack in the back of the box that you plugged into the wall , plug the phone line into it
Nov 20, 2017 | Bell Northwestern Phones - DigiMate...
My cheap vtech home phone says no line on display when i plugged in a chorded phone it worked what does it mean
Brent I bought my mom the same phone for her birthday plugged it in it had no dial tone. I read what you did and saw on the back of the Internet box PHONE LINE. That was were it was plugged then I saw the LINES 1 &2 this was the problem plugged it in LINES 1 & 2 and walla I had a a dial tone.
May 03, 2012 | Vtech Cordless 6041 Phone
1993 Dodge Spirit. Will start run till warmed up then quits. Unable to start again until it cools down. Then does the same thing What is the problem> Have replaced the fuel pump,injector,computer box,...
Hello thomas, next time it dies & fails to start, check to see if it's getting spark to the plugs. If no spark, the ignition module, sometimes called the pickup, could be breaking down when hot....Also a faulty ignition coil will cause the same conditions...Check the EGR, & the EGR pipe, make sure it not's clogged with carbon.... Cat converter and exhaust for excessive back pressure.
I hope this helps.
Aug 31, 2011 | 1993 Dodge Spirit
I have an old Comdial Executech 308B system. I ju...
Let me think. On the face of the cabinet, there are 10 or so modular jacks, one for every 2 lines and one for the 8 stations. If you plug the lines into a regular (not Comdial) phone, do you still get a dial tone?
You would get lines 1 and 3, as line 2 would be the second pair of the first jack.
If the box still lights up, I'm guessing that whatever fed dial tone into those lines got disconnected. Is this the part where you tell us you went to VoIP or cable dial tone and they disconnected the local phone company interface?
May 20, 2010 | Lands Phones
Comcast Digital Voice/ADT alam system
The 2 jacks on the back of the Arris modem are labeled "1/2" & "2". The first jack labeled "1/2" means that the jack is capable supporting 2 different phone numbers, a line 1 and a line 2. The second jack labeled "2" means that it is capable of supporting only a second phone number. Therefore your 1 phone number is working correctly from the port labeled "1/2".
There are different types of phone splitters. It is possible that the one you used may have been to split lines 1 & 2 on a single jack into two seperate jacks. Take a closer look at the splitter and see if the 2 ports are labeled differently.
Hope that helps.
Nov 03, 2009 | Arris Touchstone 450a (CM450) Modem
I can't dial out from my handsets
Here is something to try:
Disconnect or unplug the power supply (the small black box that is plugged into the wall outlet) wait for 30 seconds and then plug it in again. Sometimes the power supply needs to reset itself. It worked for me.
Thanks,
monotary
Nov 06, 2008 | Vtech 5.8GHz Cordless Phone with Digital...
AT&T Spirit Phone
You’ll need either a 6-button or a 24-button set SPIRIT CS administration.
First the control unit ADMIN switch must be ON, the administration overlay must be in place on station 10, and the set must be plugged into control unit jack 10 (call processing is interrupted only at station 10).
After moving the admin switch, and before dialing Ftr 7 -
From station 10 press intercom, Press speaker, Dial *0, Dial 1, Then Press Ftr 7.
Each line indicator light will show the current dialing type for that line. If the light is OFF, that line is set for touch tone dialing. If the light is ON, the line is set for dial pulse
dialing.
To change the dialing type for a line or lines, press the line button(s) and dial the appropriate digit from the table below. You may press more than one line button to make the change on more than one line. If you enter a digit without first pressing a line button you will hear the error tone.
Be sure to turn the admin switch back off when you’re finished.
Aug 05, 2008 | AT&T Spirit 6-Button Stard Misty Phone
There was a power surge, and now my phone is stuck on pulse dialing, how do I get it back to tone? I can use the star key to bypass the pulse and put the phone on tone, but it only works one call at a...
Press speaker,
Dial *0,
Dial 1,
Then Press Ftr 7.
dialing.
Mar 07, 2007 | AT&T Spirit 6-Button Stard Misty Phone
Lands Phones Logo
181 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
