Camerera turns on,but the screen will not turn on... i have tried new batteries and nothing also camera will not turn off?
[email protected]
Mary facemyer 1-440-310-1406
I really enjoy the camera so I hope you can help!
remove batteries. try and turn camera on, of course it wont work without batteries but this may clear any capacitors.now fit new batteries or just refit the old if you know they are good. and try again, does it work now?
1. Make sure you will install a new or fully charged battery/batteries into your camera.
2. Clean the battery contacts.
a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera
3. Without the memory card,turn on your camera.
If issue persists, call 1.800.235.6325 for repair.
You didn't provide a make or model for the camera, but if it's a Kodak, fixing your problem could be as simple as cleaning the battery contacts
in the camera, or the solution could be a lot more complex and
expensive. Here's a link to the Kodak Help Center - it provides a
simple Q&A format to diagnose the problem and propose a solution.
Clean battery contacts. Use "small" flat had screw driver, and pry up "GENTLY" on battery contacts. Replace battery. Hit a few times with knuckle "NOT HARD" next to lens. Turn camera on. Camera will work forever.
Daughter received camera as Christmas gift. Camera beeps three times and does nothing. I guess this camera is only good until the warranty runs out, 90 days. We have tried several new batteries and the expensive rechargeable type also. VERY UNHAPPY!!!!!
