Question about HP Color LaserJet 2600n Printer
HP LaserJet 2600n
The printing is very inconsistent. It prints all the colors lighter than needed, and prints even lighter streaks across the page. Is it the transfer?
  • 300 Answers
It sounds like it, but before you replace it you might want to troubleshoot this through the HP Toolbox (the software would have come with the printer) if you haven't got it, download it from www.hp.com (it's straight forward and easy to use)
Posted on Jun 12, 2008
Streaks or lines
Vertical streaks:
Check,which color/s streaks are appearing on print out,remove that cartridge/s check on drum surface for streaks.. if found replace that cartridge/s..check.
Horizontal streaks:
This problem appears when the cartridge/s image drum not rotating properly. Resit the cartridges properly, print 20nos of blank pages, then check.... replace the cartridge..
Dec 29, 2012 | HP Color LaserJet 2600n Printer
I have a HP laser 2600n and it is streaking magenta horizontally.
Sounds like the red cartridge was removed or tilted and leaked toner on the drum. Just do a self clean and it will clear up. It in the maintenance menu.
Mar 07, 2010 | HP Color LaserJet 2600n Printer
On printing, cyan leaks streak marks down pages
our printer at the fire dept is leaving streak marks on the pages we are printing. Can you tell me what the proplem is
Jan 10, 2010 | HP Color LaserJet 2600n Printer
Dull colors on half the page
I would replace the transfer belt see if that makes a diffrence hope this helps
Nov 20, 2009 | HP Color LaserJet 2600n Printer
Hp color laserjet 2600 n it will not let me print
There is an override sequence and it works well. Press the select button (checkmark) to indicate Main menu. Press right-arrow (RA) to select System Setup. Press Select , then RA to Print Quality, Hit select. RA to Replace supplies and hit Select. Now, RA to Override Out and Select. Confirm with Select again. Your 2600n will now run even with an empty toner cartridge.
Jul 08, 2009 | HP Color LaserJet 2600n Printer
Double printing, especially down the left hand side of page
replace fuser,if still happening replace transfer belt
Apr 30, 2009 | HP Color LaserJet 2600n Printer
HP 2600n will not except print jobs.
just reset the printer to factory settings , use the menu to find factory settings .
Feb 03, 2009 | HP Color LaserJet 2600n Printer
Every page covered in magenta and black won't print across the page
This is caused by toner contamination in the laser scanner unit, it is quite a complex job removing and cleaning the laser scanner. I would suggest you contact HP regarding the repair.
Sep 04, 2008 | HP Color LaserJet 2600n Printer
Uneven color in a document
check out ur drum or try out blowing the dust in between teflon n pressure roller
May 27, 2008 | HP Color LaserJet 2600n Printer
HP Color LaserJet 2600n Printer Logo
460 people viewed this question
Ben Johnson
