Question about HP LaserJet 3055 All-In-One Printer
Scanning Error I have just purchased the hp laserjet 3055 all in one. I have been trying all week to scan documents into my computer but I keep getting "Scanning Error Cannot Connect" What am I doing wrong?
    Scholar:
  • 148 Answers
"Automatic Scanning could not be completed."
you haven't a problem in your cable, you have a problem in he printer.
refer to your user manual
May 07, 2010 | HP LaserJet 3055 All-In-One Printer
When trying to copy papers do not feed but if you scan they will
HP LaserJet 3050z, 3050 All-in-one, 3052, 3055, 3390 and 3392 versatile printer - Error reported: Document Feeder Jam ISSUE: How to correct the HP LaserJet 3050z, 3050 All-In-One, 3052, 3055, 3390 and 3392 versatile printer if this error is reported: Document Feeder Jam SOLUTION:
  • Clear the jammed media from ADF (HP LaserJet 3050, 3050z).
  2. Remove any jammed media with care.Take out the page gently. NOTE: Take care not to tear the paper. c01075162.gif
  3. Close the ADF cover plate.
  • Clear the jammed media from ADF (HP LaserJet 3390, 3392, 3052 and 3055).
  1. Open the ADF cover plate. NOTE: Check whether all packaging straps inside the ADF are removed. c01075163.gif
  2. Unload the jam clearance component.Lift the two handles with both hands until the component clutch is released.Rotate and lift the jam clearance component, and then put it aside. c01075164.gif
  3. Lift the green handle, and rotate the paper picker until it is opened. c01075165.gif
  4. Gently remove the page without tearing it.If you feel resistance, go to the next step. c01075166.gif
  5. Open the ADF cover plate, and loosen the media gently with both hands. c01075167.gif
  6. When the media are stopped, pull the media out gently along the shown direction. c01075168.gif
  7. Close the cover plate of the flat scanner (HP LaserJet 3390, 3392, 3052, 3055). c01075169.gif
  9. Insert the jam clearance component to reinstall it.Press the two reeds until the component is properly engaged.Install the clearance component correctly. Otherwise, paper jams will continue to occur. c01075171.gif
Have a good day
Jun 22, 2009 | HP LaserJet 3055 All-In-One Printer
Not scanning or copying when using the ADF on HP laserjet 3055
Based on the assumption it's mechanically ok, check the cable connection between the document feeder and the base, if damaged or worked look it can cause errors. If it is a sensor error, check for a small bit of paper or even a staple from a prior jam.
Jun 18, 2009 | HP LaserJet 3055 All-In-One Printer
Printer Hp Laserjet 3055 giving error message 5
If you scanner error 5 or printer hangs at scanner bulb warming up than the issue is with Scanning Assembly inside the printer and it is hardware issue.
Apr 12, 2009 | HP LaserJet 3055 All-In-One Printer
HP 3055 model scaner problem
i want repair HP laserjet 3055
Scanner error 6
Sep 15, 2008 | HP LaserJet 3055 All-In-One Printer
Faint image on scans
REPLACE IN THIS ORDER.
CABEL(CHEAPEST)
IF THAT DOES NOT WORK
IT NEEDS A FORMATTER BOARD.
Jun 11, 2008 | HP LaserJet 3055 All-In-One Printer
Scanning Problem
first of all uninstall the software completely,reboot the system,install thesoftware n connect the the printer only when asked by the software
Jan 27, 2008 | HP LaserJet 3055 All-In-One Printer
HP LaserJet 3055 All-In-One Printer Logo
425 people viewed this question
Seeker5211
Seeker5211
