Question about Dell Inspiron 6000 Notebook
Power i recently noticed my computer was not saying it was charging when the adapter was plugged in. I thought the adapter was bad, so i got a new one, and it is still not charging. I can hold the power adapter a certain way sometimes and it says it is charging, but then it quits. Any suggestions?
    Genius:
  • 1,601 Answers
Your dell is known for the dc jack soldered on the circuit bord to break away.
I have repaired 1 a few weeks ago. I opened it up and took the board out resoldered and superglued the jack to the board.
My customer was very happy.
Posted on Jun 13, 2008
Won t charge new battery
Few options: either the connection is "hazy" (try moving the plug in the hole), battery is fake or battery has been abused and is empty...
Aug 16, 2013 | HP Mini Computers & Internet
Psp not detecting battery
Sounds like you might need a new power board. I know videogame911 does service PSP's your best bet might be to send it in to someone who can tell you exactly what the problem is, specially if you replaced the battery and still have the same issue.
Apr 23, 2013 | Sony PSP-3000 Black Console
Hp pavilion dv6 2117ax will not power up
Since you already got a new charger, then the problem could be the power jack of the laptop and/or the connections inside the laptop.
Try to plug the power adapter slowly and try to wiggle it. It you feel that the power jack is wiggling, then the problem is a loose power jack that is why it won't charge. And you need to have a tech tighten that up for you.
Replacement HP Pavilion DV6 AC Adapter 65Watt 18.5V 3.5A Option
Oct 28, 2012 | Computers & Internet
I have a Acer laptop and I just bought a new charger for it because I thought that the old had stopped working but the new one isnt working either. The computer says that it is plugged in but not...
Hello:
Maybe your battery is ruined. Batterries tend to lose their capacity after a year or two. It depends on its use and care. If your battery is too old, for sure, you need to replace it.
I hope this helps. Thanks.
Jan 31, 2011 | Computers & Internet
I bought a DELL INSPIRON 1525 in august 2008. it worked fine until recently. now the issue is, the battery is not charging. when i plug in, it says "plugged in, charging"...but my battery is stuck at 32%...
First of all, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether.
Aug 29, 2010 | Dell Inspiron 1525 Notebook
Acer Aspire 5520 Power Problems! :(
1. Actually the problem is not with the charger / adapter!
2. The plug-in port / jack of the laptop has become loose.
3. Don't try to work out the charging by adjusting the adapter plug with different angles. It will just damage the plug-in port (the wire inside the port will become loose and unaligned)!
4. Contact the Acer authorised service center for repair / replacement of that plug-in port / jack in the laptop! It'll just cost some bucks!
please rate this advice if it helps....tc! :)
Jan 14, 2010 | Acer Aspire 5520-5156 Laptop
Gateway laptop will not charge battery.
I have a new gateway laptop with windows 7 and today it said plugged in not charging 8%. I tried everything and nothing worked so I turned it off and unplugged it and took the battery out and put it back in and it started charging...hopefully this works.
Jan 09, 2010 | Gateway M675 Notebook
Dell latitude 810 will not power up and says low battery
if you plug in to charge your battery and its not charging replace the battery with a new one and a ac adaptor plug, just to avoid any more damage to your pc notebook, dont try to repair if you are unsure on what to do
Nov 23, 2009 | Dell Latitude D810 PC Notebook
Laptop Battery won't charge
The chances of getting two bad batteries is slim, so we'll have to assume it's not the battery. I suggest you flash your bios if that has not been done recently.
You can download and install the newest from support.dell.com
Sep 21, 2009 | Dell Inspiron 1501 Notebook
Laptop won't charge
the sucky thing with laptops is the electric plugs directly into the motherboard. then the electricity goes from the motherboard to the battery, so i'd have to say the motherboard is bad you could get a new one, but it costs alot of $. So I suggest bring it to your local computer shop and see what they can do.
Jun 05, 2008 | Compaq Armada E500 Notebook
Dell Inspiron 6000 Notebook Logo
43 people viewed this question
Alun Cox
