Question about Sony Handycam DCR-TR7000 Digital Camcorder
Camera mode video not working
My handycam wont record video. The screen and eye piece show no image when in camera mode. It does record the sound but with no image. Playback works fine.
Is there a solution or do i need a new camera?
  • 4,234 Answers
This could be as simple as the iris stuck closed or more expensive (ccd defective). Without taking the camera apart, it will be difficult to say with any confidence. Have you looked around to see what a repair estimate will cost? Perhaps you can get a detailed estimate from a local shop. We may be able to walk you through the repair?
Posted on Jun 12, 2008
Screen and eye piece show lines not clear images
Please make sure that you're using fully charged battery pack.
Remove the battery and reinsert after 1 minute.
Reset the camera by following the reset procedure from the manual of the Camera.
If the issue persists again, service is required
Dec 31, 2010 | Sony Handycam DCR-DVD101 DVD Camcorder
When recording, no picture thru viewfinder or lcd panel. Records sound. Was working fine, just started this, and the lens cap is off. Any assistance greatly appreciated.
It could be either aperture is stuck or ccd imager chip is defective in your camcorder that will be replaced.
In bright light, look into camera lens, turn ON in camera mode and observe does aperture open like an eye?
If you notice some thing opens right in center of camcorder lens then aperture is working and ccd imager chip is bad that will be replaced.
Let me know model number of your Sony camcorder to provide you ccd imager part number info.
Dec 09, 2009 | Sony Handycam DCR-TRV140 Digital Camcorder
Viewfinder and LCD screen only show black and record black
If camcorder shows old recorded tapes picture with correct colors in LCD but does not show live view in camera mode to record new movie then its ccd imager chip failure.
And if camcoder shows live view and old recorded tapes in its eye piece view finder but does not show any thing in LCD the its problem of broekn/ cracked flexible wire between lcd board and main board of camcorder.
Let me know your finding with bit detail to provide you solution/ helpful info.
Nov 18, 2009 | Sony Handycam DCR-HC30 Mini DV Digital...
Can't see anything that i record
been in contact with Sony, will send the camera back, and get a new one
Aug 15, 2009 | Sony Handycam DCR-HC30 Mini DV Digital...
Sony digital video camera mode no. DCR-HC14E not showing pictures/recording
If your Sony DCR-HC14E shows fine picture in playback of old tapes and does not give live view in camera mode to record then its CDD Imager problem that Sony will repair free of cost.
Click Sony CCD Imager Support for details.
Jun 10, 2009 | Sony Handycam DCR-HC14E Mini DV Digital...
My sony dcr-dvd105 handycam camcorder all of a sudden shows only
There is 2 possibilities, either aperture of camera jammed and doesn't open or CCD Imager got defective in your Sony DCR-DVD105 camcorder.
Let me know if you have little experience of camera repair to guide you further.
Nov 29, 2008 | Sony Handycam DCR-DVD105 DVD Camcorder
My screen
If the camera can record images, and they do not show in the viewfinder while the recording is being done, the fault may be the following:
My answer will be generic to almost all video cameras in general.
On the circuit board where the viewfinder control is done, there is an IC and some electronics for this process. It is possible that this IC or something in the related circuits is not working properly, or there is a bad ribbon cable, or a cold solder connection.
The first thing to do before bringing the camera for service, is to check the menus if you can see them. Make sure that there is no option turn on in order to use an external viewfinder while the camera is in the record mode. If you cannot view the camera setup menu check for a mechanical switch on the side, or back of the camera, or in a compartment for this option. If all else fails, then there is a fault condition.
Also read through the instruction manual, and through the fault sections.
Jerry G.
Mar 31, 2008 | Sony Handycam CCD-TRV318 Camcorder
Black Display Screen
first check the iris of the camera if it is opening,you will see this when you look inside the lens of the camera when you turn on and off the switch at camera mode if the iris is opening....if the iris is ok the second problem may occurs of your camera is the ccd image sensor....
Oct 31, 2007 | Sony Handycam CCD-TRV68 Camcorder
Can not see image - camera says cover is not open
Defective ccd imager!! Sony will replace this ccd imager free of charge. Year 2002 up to 2005 released unit has a factry defect ccd imager. the company recalled these unit and replaced with a stronger version of ccd imager. check it out.
Aug 31, 2007 | Sony Handycam DCR-HC36 Mini DV Digital...
Won't record picture
it probably is the ccd imager. call sony and tell them about the problem. since they had a recall for this issue the may fix it for free.
Jun 11, 2007 | Sony Handycam DCR-HC90 Mini DV Digital...
Sony Handycam DCR-TR7000 Digital Camcorder Logo
100 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
