Question about Apple iPod nano
May have disconnected wrong from USV?
I disconnect my daughters Ipod nano before it was done charging last night and this morning my husband says it won't do anything. I didn't look to see if it said do not disconnect. Did I brake it? What should I do?
  • Apple Master
  • 2,794 Answers
Hold down on the middle button while holding down on the menu button and see if the Apple logo appears on the screen.
That should reboot the Ipod and get it back up and running again.
Make sure the lock switch isn't on before trying it.
Posted on Jun 12, 2008
My ipod was working no rpoblem last night. I left it on docking station overnight and this morning it is not working. It is like there is no power ? It wont sync either totally dead! Any ideas?
  • If an iPod appears not to turn on, check the hold switch on the device. If this switch is activated while the device is off, it will not power on again until the hold switch is turned off.
    If that is determined not to be the problem, the battery's charge should be checked. When the battery is no longer holding a charge, the device will not power on, but will show a battery icon on the screen for a few seconds. If you see this icon while trying to boot up the iPod, just connect it to the USB cable and allow the battery to charge, which can sometimes take up to 30 minutes before the iPod becomes operable again.
    If no battery icon appears when trying to turn on the device, try resetting the iPod. Once reset, the device should turn on, but if it does not, the battery may need to be drained first (by leaving the iPod disconnected from power for up to 24 hours), and the reset
Nov 26, 2011 | Apple iPod nano
I have apple iPod 2Gb. It doesn't start. it's display only busy icon. I think's it's frozzen how to sove this problem
How to Fix a Frozen IPod Nano
iPod Nanos will sometimes freeze up, sticking on one screen or not even turning on at all. If your nano is locking up, there are a few things you can try to get it working again.
1. Turn off the hold button. First of all, make sure that that wasn't the problem--don't worry, we've all done dumber stuff.
2. Cold boot. Assuming that wasn't the problem, flick the hold button on and off a few times, and then make sure it's off. Hold down the Menu button and the middle button button for about 15 seconds; this should reset the iPod nano, which may fix the issue. Make sure that the iPod nano is fully charged before attempting this.
3. Recharge. If that didn't work at all, try plugging the iPod nano into the USB port of a computer, using the adapter that came with it. Be sure to plug directly into the computer, and not through a USB hub. The USB needs to provide adequate power for the iPod nano to function, and it may be unable to do so through a hub. The iPod nano should be recognized by the computer; once it is, you simply need to safely disconnect it in iTunes, and it should be functional. If it doesn't show up on the computer at all, give it about 20 minutes, leaving the iPod nano connected to the computer, as the nano may be under-charged, which requires a few minutes to re-charge. If it's still not working, try plugging the iPod nano into a different computer.
4. Try again. If the Menu + Middle Button fix seemed to work, but just cycled the nano back to one of its starting screens (including the "do not disconnect" or the "loading Apple logo" screen), try that fix again. If it still doesn't work, try to charge it for a while, and then try it once more.
Feb 22, 2011 | Apple iPod nano
My daughter added several movies to her Ipod 30Gm
hi, you should long press the the menu and play button for a reset as show in picture below
hope that it will help and don't forget to rate ;)
Jan 19, 2010 | Apple iPod MA446LL/A MP3 Player
I need the instruction on how to set up my
here's the website: http://support.apple.com/manuals/#ipod
you can download the user manual from there.
Dec 31, 2009 | Apple iPod nano
Hi i charged my nano last night and whe i turned it on this morning the screen has froze and i cannot release it or switch it off now. Can you plz tell me what to do?
You just need to reset it, hold down the middle button and the "Menu" button for about 7-10 seconds, or until you see the Apple logo.
Hope this helps.
Dec 16, 2009 | Apple iPod nano
My daughter locked my ipod nano 2gb now i cant un lock it
Connect your iPod to the primary computer you use it with (the first one iPod synced with), and open iTunes. When you disconnect iPod from the computer, it will no longer be locked.
No big deal. you'll be all set
Sep 09, 2009 | Apple iPod nano
Ipod connceted thru usb to computer for charging - locked
i had the same the issue due to my ipod. the problem that i think is with you is that you may have done something. To get your ipod on again hook it to the computer (USB cord) and re format it. that means you would have to clean your drive completely.. dont worry!!! then you need to put songs all over again...
Aug 10, 2009 | Apple iPod nano
Ipod nano 2gb
Start with these five simple solutions: Reset, retry, restart, reinstall, or restore
http://www.apple.com/support/ipod/five_rs/
Mar 24, 2008 | Apple iPod nano
Charging ipod 4gb
Yes, the iPod will show that it is charging on its screen. Disconnecting without ejecting can cause data loss of whatever is stored on the iPod
Ejecting is when you remove the iPod from the desktop by dragging its icon to the trash or clicking on the down arrow next to the iPods name from within iTunes.
If you use the library computer, usually a Windows based OS, you'll need to click on the iPod icon from the task tray on the lower right of the screen. You can right click to select the remove option
Dec 21, 2007 | Apple iPod nano
MY IPOD NANO FROZE!!!!!!!!!
I think you bricked it. When it says Do Not Disconnect, it means it!! If you disconnected it while it said that, you bricked it! The motherboard can be replaced, however, and it should work again. Don't think its worth doing that though.
Sep 19, 2007 | Apple iPod nano
Apple iPod nano Logo
42 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
