Question about Maytag LSE7806A Top Load Stacked Washer/Dryer
Replacing a siphone break
I have a stacked Maytag washer dryer unit (LSE7806ACE). In pulling it out of it's closet I cracked the elbow siphon break. How do I open up the washer to replace the siphon break?
  • 525 Answers
Disconnect unit from its power source before servicing!
The lower half (washer) can be pulled away from the upper section, allowing full access to the unit. Remove the front panel by taking out the 2-phillips head screws at the bottom of the front panel, pull outward at the bottom of the front panel to disengage the hanger clips from the top panel. Remove the 2-3/8"hex head screws from each corner of the side panels connecting to the top panel. The top panel can then be tilted up and back on its hinges, so that acces may be gained to the siphon break. 4-5/16" hex head screws secure the 2 halves of the siphon break to the back panel and are accessible from the outside of the back panel.
Follow the link below to see an image of the siphon break assy. along with ordering information.
http://www.repairclinic.com/SmartSearch/smartsearch.aspx?SearchText=%60BFrigidaire+%60AWashingMachine
Please rate my solution in accordance with your satisfaction of my job performance.
Thank you for contacting me at Fixya.com
Dave E. (Illeagle)
Posted on Jun 12, 2008
Maytag stacked unit LSE7806ACE. dryer is fine , the washer will not fill or run, if I manually turn the timer to drain the tub spins and the lid switch works fine. But the unit won't do anything f
You have a timer problem, the contacts are welded in spin mode.
This is almost always caused by advancing the timer by hand when the dial is pulled out in the "ON" position, causing arcing of the contacts.
Sep 22, 2017 | Maytag LSE7806A Top Load Stacked...
My machine will fill but it just constantly drains what do we need to do
Hi and welcome to FixYa, I am Kelly. Lift the end of your washer drain hose up as far as you can in the drain without pulling it out and tie it off so that the elbow it at least 2 to 3 inches higher than before. This sounds like your having a siphoning problem. The tub fills up... the siphon starts it may or may not agitate but will stop and fill often. If after you do this and perform testing / a normal wash you still have the problem; just respond here so we can troubleshoot further.
Kelly
Apr 24, 2011 | Frigidaire FEX831CS Top Load Stacked...
Have a maytag washer model lat9306aae and it will fill right the first time but when on the rinse cycle it wont fill up keeps running out ?
Check the drain hose behind your washer. If if is too low you will get a siphon and the water will run in and not fill up the tub. The drain hose is supposed to have an anti-siphon valve / kit on it if installed correctly but not always. Lift the drain hose until the end elbow is nearly even with the bottom of the top panel lip.
Any local appliance part center will have this Siphon Break Kit:
http://outlet.whirlpool.com/-[285834]-300125/285834/
There is a rubber diaphragm valve in the top of the "T" that opens to introduce air into the drain hose to prevent a Siphon. Installation is simple. Lift your drain hose up vertially, Make a cut 4 inches from the bottom of the top panel. Install the T with the rubber end UP and connect the elbow you cut off to the T oulet and drain.
Thanks for choosing FixYa,
Kelly
Apr 02, 2011 | Washing Machines
I have lse7806ace (stackable) and problem with water leak. I live in condo and this washer/dryer stackable in small closet. I can't reach locking tabs. This stackable is also on the pan (bottom). 'BTW,...
Remove the 2 screws which hold the lower front washer panel , lift out from the bottom and remove the panel.You can now run the machine and use a flashlight to see where the leak maybe. Usually the top tub seal under the plastic tub cover will leak. The other possibility is the main tub bearing and seal on the main tub where the transmission goes up through tub. Hope this helps.
Feb 11, 2011 | Maytag LSE7806A Top Load Stacked...
Top Load Stacked Washer / Dryer Maytag lse7806ace -- washer will not run, except in spin cycle
I believe there is a fuse on the left side front under the front panel about a foot from the top of the washer.
Nov 20, 2010 | Maytag LSE7806A Top Load Stacked...
Maytag stack unit Model LSE7806ACE leaks
It is most likely the tub seal. Take the two phillips head screws out of the front cover located low on the cover lift forward and remove. Set the machine two low level and fill with water only no soap or clothes when unit starts agitating look at the bottom center of the clothes tub if water is leaking here then you will need to replace the tub seal and tub bearing assembly.
Apr 06, 2009 | Maytag LSE7806A Top Load Stacked...
Washer won't agitate, drain or spin
quite possible that the fuse has gone bad again, if that s the case i would recommend replacing the fuse, and the lid switch.
Dec 08, 2008 | Maytag LSE7806A Top Load Stacked...
Maytag stackable LSE7806ACE - dryer wont run...washer is fine..
I had the same problem, take the easy rout first and check for obstructions in your venting. Mine was clogged and it shut itself down (to protect itself?)
Jul 06, 2008 | Maytag LSE7806A Top Load Stacked...
Maytag LSE7806A Top Load Stacked Washer/Dryer Logo
193 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
