Ricoh 6513, service code 551
Hi there, what does sc 551 mean, how do we reset and what else needs to be done? thx skb
  • 2,794 Answers
SC551 is thermistor pressure roller error. Check for paper jams in the fuser. It could need a new thermistor.
Make sure the fuser is secured and properly seated in the copier.
Posted on Jun 12, 2008
Hi there im also one of the copier champ coming with sc-551
Posted on Feb 14, 2012
Help me : Ricoh aficio MP 1900 Error code SC 551
This may help if you tru the following.
Try to reset this code with "Clear Mode"+107+"Clear/Stop" hold for 5s.
Turn OFF then ON at the Power Switch.
If the above does not clear it, then it may be time to get a service engineer in as it could be that a board has given up inside.
Good luck.
Jul 05, 2014 | Ricoh Office Equipment & Supplies
Mp 7000
Please refer to the authorised service support as it might need technical support with spares.
click on : http://www.ricoh.co.uk/support/index.aspx
Nov 21, 2011 | Ricoh Aficio 450 Copier
Ricoh 6513 Error Code Sc.387 Error Code Sc.457 Error Code Sc.350
1. Set SP3-125-003 to a value of
2 to enable Job End & Non-use
3 Self Check Mode.
fore more hrlp visit https://cbrtechsolutions.net
Jan 21, 2011 | Ricoh 6513 Copier
Ricoh colar 6513 cod sc 457
SC457 mean Image Transfer Belt Cleaning Unit Position
Error, try to clean the sensor in the transfer belt with a dry cloth.
Jun 21, 2010 | Ricoh 6513 Copier
Ricoh sc 551
This is a fuser temp. problem -- must reset and/ or replace thermistors.
Press clear modes button then 1-0-7 then hold down the clear stop button.
When display changes touch copy sp modes.
Turn may power off and wait about 30 sec.
Turn power on.
If the machine comes to ready you are ok for now.
If code returns you must replace thermistors.
If you need to replace thermistors, contact me and I will get you part numbers and instructions.
Jan 15, 2009 | Office Equipment & Supplies
Service code 551
SC551 is an error with the fuser unit. The thermistor could be bad and need to be replaced or the press rollers are worn.
It should be looked at by an experienced technician to get problem repaired.
Jun 12, 2008 | Ricoh 6513 Copier
Aficio 6513
the proplem solved by adjusting the the home position of the trans fare belt cleaning unit .
May 24, 2008 | Ricoh 6513 Copier
Ricoh 6513 error code PM CAll
Preventive maintenance.....
It's for a clean up, and sometime there's some parts to replace...
Apr 04, 2008 | Ricoh 6513 Copier
Ricoh 6513 streaking
Depending on your use IE lots of thick paper 150gsm plus.
The fuser rollers wear very quickly.
There is no Cheap fix for this.
These machines are very costley to run.
Ricoh Tech L3 22 years exp.
Mar 21, 2008 | Ricoh 6513 Copier
Ricoh 6513
A sc541 code is with the fixing ass'y did you try to reset it? Did it come right back? Is the fuser warm to the touch? If so it is most likly to be one or both of the termister in the fuser. If it is cold it may be the fuser heatting lamp or thermal fuse
Feb 08, 2008 | Ricoh 6513 Copier
786 people viewed this question
jasbo
jasbo
