Question about Nokia 3230 Cellular Phone
Nokia 3230 "Phone start up failed. Contact the retailer"
How can i do?
Please help me
  • Wutthikai Deepanbao Jun 12, 2008
    Thanks Supriyo DG I tryed to do this solution "Format the Mobile set, using 4 Keys combination : Press(1) *, (2)Dial Key, (3) 3 & hold it & press (4) power on switch.]"
    But it's same.
  • 58 Answers
May be
Battery damaged
Battery Connector Unsolded
Off/on switch is not working
Power Supply Controller IC not working
Contact a skilled mechanic immediately.
Supriyo DG
Posted on Jun 12, 2008
  • SUPRIYO DASGUPTA
    SUPRIYO DASGUPTA Jun 12, 2008
    Hi
    Your problem is THE HANDSET IS DEAD. So contact the company Service Centre ( provided the warrenty period is there ) nor check according to the suggessions given to you through a skilled mechanic.
    Thanks for respose.
    Supriyo DG
I have a problem with my NOKIA 3230. That z PHONE START UP FAILED CONTACT RETAILER. what can I do for It???....
Hi Hello your problem to your cellphone is contact retailer, try to my advice yyou need to check you network thru wireless center or you need to reprogram your cellphone thru using software reprogram.you need to check up the service repair.thanks and god bless.
Aug 28, 2011 | Nokia 3230 Cellular Phone
Phone start-up failed. Contact the retailer(nokia 3230) please help me!
my nokia mobil 5233 online updating but is failed and phone start up
Jul 02, 2011 | Nokia 3230 Cellular Phone
I'm not able to view any application on 3230 its giving msg software failed contact retailer Tel me how to reinstall nokia 3230 software without switching d mobile on.
Just format the phone by pressing * + 3 + greenbutton and power on the phone but remember the three button should not leave even if the phone has power on.
Jul 19, 2010 | Nokia 3230 Cellular Phone
My nokia 3230 failed to start up. when i turn-on the button it wll only show the phone brand which is Nokia then a message will appear on screen which is "phone start-up failed. Contact the retailer." can...
My nokia 3230 failed to start up.... Answer Failed: retry My nokia 3230 failed to start up. when i turn-on the button it wll only show the phone brand which... (More) (More) My nokia 3230 failed to start up. when i turn-on the button it wll only show the phone brand which is Nokia then a message will appear on screen which is "phone start-up failed. Contact the retailer." can you offer me solutions for this?
Apr 17, 2010 | Nokia 3230
Help please! My nokia 3230 failed to start up. when i turn-on the button it wll only show the phone brand which is Nokia then a message will appear on screen which is "phone start-up failed. Contact the...
Try this, it might work for you. First remove any extra memory card and sim card inside your phone. After doing that, turn on your phone without those things. If there is message "Please insert sim card" then your good to go. Put your sim card back to your phone and then turn it on again. If it is successfully start then next thing to do is to insert the memory card back to your phone and then start up your phone again. But if in this stage your phone failed to start, then the memory card it causing the problem.
If all fails, then you need to format or hard reset your phone. Hold the * + 3 + green call key and then start up your phone while holding those buttons until you see a screen that shows formatting. Make sure you have enough battery power to do this procedure. You can plug the phone charger to make sure that everything will be okay.
Please leave comments for further instructions. Thanks..
Mar 29, 2010 | Nokia 3230 Cellular Phone
Nokia 3230 start-up failed
have you tried reformatting it??
try this
12345 is a standard code and 00000, but if you change it and you have forgotten your unlock code, you'll just have to reformat it
key combination which is used to hard reset the phone (similar to #*7370). It is useful in some cases, for example when the phone cannot reboot.
The trick is
Switch off the phone.
Hold down the following three buttons: Green (call answer) button, * button, and ‘3′ button
While holding these buttons, press the power button and switch on the phone
When the message ‘Formatting’ appears on the screen, release all of the buttons...
reformatting your phone will delete all your data and also will restore all the defaults of your phone, and any corrupted application will be reinstalled, but if the formating doesn't work, you'll just have to re flash it, the safe way is to go to a near repair shop of your phone and have then to re flash your phone,
Aug 28, 2008 | Nokia 7610
3230 start up failed
u need to format it manually by pressing power on, call options, 3 & * simultainously tested and proven!
May 06, 2008 | Nokia 3230 Cellular Phone
Nokia 3230
how to flash up the phone
Apr 14, 2008 | Nokia 3230 Cellular Phone
Hi, Format the Mobile set, using 4 Keys combination : Press(1) *, (2)Dial Key, (3) 3 & hold it & press (4) power on switch.] bye sr99mobiles@yahoo.co.in
Sep 11, 2007 | Nokia 3230 Cellular Phone
Nokia 3230 Cellular Phone Logo
98 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
