Question about Konica Minolta bizhub C450P Laser Printer
TCR adjustment When i initialize the konica bizhub 450 excute tcr adjustment appears on the screen and i can not copy. what should i do?
  • 24 Answers
This can only be executed in service mode and is the machine saying it has been starved of toner, i would advise that a technician carries this out as usually there is a problem that has caused it.
Posted on Jun 25, 2009
How to replace developer in konica minolta bizhub 500
First service mode to clear the counter, then remove the developer section, dump old developer replace with new developer then run TCR adjustment. recommend replacing the drum and cleaning blade at same time.
Nov 25, 2016 | Konica Minolta Bizhub 500...
How to clean the IDC sensor while the TCR is giving error 6
IDC requires removing the develope unit then the drum unit then removing the drum .
TCR is located under the developer unit, did you replace the developer , did you clear the counters first, then run the TCR adjustment
Nov 29, 2015 | Konica Minolta Bizhub 500...
Konica minolta bizhub 164 have Trouble service code c2558
Code: C2558
Description:
Abnormally high T/C ratio
- The T/C ratios detected by the TCR sensor board (TCRSB) are above the threshold for the detection of abnormally high T/C ratio for three successive times.
- The connector between TCRSB to PRCC is disconnected
Remedy:
1 Check to see if developer is available.
2 Check the connector between TCRSBrelay CN14-PRCB CN10 for proper connection and correct as necessary.
3 Change TCRSB. 4 Execute "TCR AUTO ADJUST. 5 Change PRCB.
http://www.printcopy.info/?l=en&mod=free&chap=erc&brand=Konica-Minolta&model=bizhub%20164&code=C2558
Jun 03, 2015 | Konica Minolta bizhub Office Equipment &...
Konica minolta bizhub 215 giving error c2558
C2558
Abnormally high toner density detected TCR sensor board
- The connector between MFPB to TCRSB is disconnected.
Error Codes Konica Minolta bizhub 215
Mar 07, 2015 | Konica Minolta Office Equipment & Supplies
What is m2 code how cani reset in Konica Minolta bizhub 164
Menu/Select
Quick Setting
Quick Setting
+ or - & FUNCTION Menu/Select
+ or - & TCR AUTO ADJUST.
Nov 20, 2014 | Office Equipment & Supplies
Konica minolta bizup c550 printing black copy what will i do?
The corona housing for the back drum need to be replaced. Get a new black image unit drum and developer units
Aug 15, 2014 | Konica Minolta Bizhub C 353, Bizhub...
How do l adjust ATDC gain on bizhub 500
You cannot manually adjust the ATDC gain in bizhub 500. Replace the developer and execute TCR sensor adjustment in service mode.
Mar 19, 2014 | Konica Minolta Bizhub 500...
Error code A255B and C255A appears when is switched on
C255A Magenta TCR sensor
adjustment failure
"A" code not valid
Jan 22, 2013 | Konica Minolta Bizhub C550
Error 2803 konica minolta 500
TCR output abnormality.Toner control ratio abnormality error code.Restart the machine if code removes then its OK otherwise simply replace the developer and execute TCR adjustment again.
Dec 11, 2012 | Konica Minolta bizhub 420
Konica Minolta bizhub C450P Laser Printer Logo
458 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
