Question about Samsung RB2155 Bottom Freezer Refrigerator
Samsung refrigerator the light is off, it beeps every few minutes, the fan inside the fridge doesn't run but has power getting to it according to the service man. The circuit board has been replaced and still the fan and light doesn't come on. The freezer is working but the fridge temp doesn't go lower then 9'C. The coil in the fridge is cold and working. It has been unplug a few times with no change except the light will work for 10 mins. then goes off again. The repair man is stumped and can't get any Samsung support. Please help! Gerhard
  • Anonymous Dec 08, 2008
    After conect the refrigerator its work for about two minutes and after that, a sound (beep) hear about 11 times every two minutes, and after 5 minutes the ligth of the refrigerator goes off. The model is RSH3KTRS
  • 1462 Answers
SOURCE: Samsung RS2555SL humming noise
don't know this model specifically, but have had loads of problems with these samsung fridge-freezers. the no water in drinks dispensor is probably due to the water bottle at the bottom of the fridge being frozen. this is endemic with samsung the noise you hear is ice hitting fan. samsung use two systems for fan. the one i think you have is separate fans for fridge and freezer and a separate evaperator for fridge and freezer. take of the back plate of the fridge and you will find the fan mounted in it. disconnect the plug and socket connection. you will probably find ice build up round the fan blade. melt off with hot water. the bar you had showing on the "8" is a fault code - the most common fault being the defrost termination sensor. unless you are experienced, this is not really a diy appliance
Posted on Apr 02, 2007
fridgetech
  • 473 Answers
SOURCE: Samsung RS2630AWW freezer works/fridge does not
Chances are the fuse in the evaporator section is bad and won't go into defrost automatically.  Samsung refrigerators are junk!  Good luck getting anyone to service this one.
Posted on Oct 17, 2007
SOURCE: Samsung RS2556 - Refrigerator side is not cooling - Freezer is fine
I have RS2555 in same problem.my warranty is expired and Samsung hooked me up to an technician who asked for 300.00 for labor plus parts and tax, what a rip off!!I I called my Canadian friend who's a technician and I was told to POWER OFF the RS2555 for 24 hrs.both doors MUST open and take out all drawers,he said ,it is 90% the ICE blocked the cool airflowing,so if ICE melted,all will return to normal.
It works after I did what he said.share this and hope can help some one with same problem!
Posted on Mar 26, 2008
tborn6
  • 700 Answers
SOURCE: samsung rs2533sw fridge not cooling
it sounds like the refrigerator evap is frozen up causing the compartment to get too hot. shut the unit off and let it thaw out. then take the screws out of the cover to check the stryrofoam on the back side of the cover to see if theres broken spots on it causing the air to bypass the evap causing it to freeze. Theres two screws behind the light cover and two at the very bottom of the cover and two behind the decorative plugs about 1/2 way
Posted on Dec 22, 2008
  • 5 Answers
SOURCE: Fridge not keeping cool RS267LASH
Hi Adshegern,
I think you have a fan problem. Your refrigerator mus have a bad fan or not working fan. I suggest you full out the refrigerator and open back lower cover. Two months ago, I have a problem like your. I fixed by replace a fan. You have to options to fix it.
Option 1. Check your refrigerator's fan with voltage. It think it should be 120VAC. If yes, you can buy a fan from electronics store (it cost about $12.00 to $17.00). they you remove the old fan and its motor out. Install the new fan in. Then you need to drill 4 holes to tie the fan. By doing this, you keep the fan running stable. The fan won't vibrate.
Option 2. You can go online to this website partstore.com and buy an exactly the one you need and replace the old one. It cost about $40.00.
Good luck
Posted on May 22, 2009
Why is my Samsung RF26XAERS refrigerator repetitively chiming, and how can I fix it?
NOISE? from the fridge inside? or from the outside compressor? In overstressed compressor or low freon level will make weird noises? a bad fan in freezer will? Even seen bad ice makers make weird noises? if the ice making is hindered by obstructions?
Aug 20, 2014 | Samsung RF26XAERS 26 Cu. ft. French Door...
Samsung Refrigerator RS261MDPN starts up when plugged in for about 10 seconds then stops. The center light of the freezer temp indicator blinks. compressor does not run in this mode. Also,is the...
Samsung fridge wont start compressor right away. There is delay, so when you plug fridge in it take 15 - 20 minutes to start.To check if fan is running, you need magnet. Place it on top of door hinge. Open door and if lights are out, you are in wright spot. Take magnet of to test if lights come on. Now put magnet back and if fridge fan is running you can feel it how it blow from different outlets inside of fridge .
Jul 23, 2011 | Refrigerators
Refridgerator beeps and upper section not working
First, the Samsung Refrigerator is the only fridge that has one compressor, but two different evaporators to operate the freezer and the refrigerator separately. Thus, you can have the bottom freezer working fine, while the fridge part will not.
The reason your fridge is not working is probably a faulty door switch in the refrigerator. The switch is malfunctioning, telling the computer that the door is open. Therefore you hear the door alarm go off in intervals, even though the door is actually closed. If the computer registers an open door, it will not pump cool air into the refrigerator, as that would be a waste of energy. All you need to do is replace the door switch. Until you get a new one, you can temporarily fix your fridge by simply removing the old switch altogether. You will not have any light in the fridge, however, it will cool again just fine until you are able to install the new switch (a simple plug-in contraption, by the way).
Hope this helps.
May 28, 2009 | Samsung RB2155SH Bottom Freezer...
Samsung model RS2556SH, refrigerator
Refrigerator temperaure gauge keeps blinking and fridge is only cooling to 35 degrees
Mar 13, 2009 | Samsung RS2556 Side by Side Refrigerator
Door ajar alarm ringing and refridgerator not cooling enough
it sounds like either a defrost problem or damper door problem it is very well worth fixxing
Dec 28, 2008 | Samsung RS2630SH Side by Side Refrigerator
Frigidaire refrigerator making beeping sound
Unplug your refrigerator from the ac outlet, and 0open theref door for approx. 5 minutes. Then plug it again, after you hear the beeping close the door. wallah it's fixed.
Dec 21, 2008 | Frigidaire FRS3R5EMB Side by Side...
Refrigerator temperature can't be set to cold - sensor light shows 9C and keeps on beeping. Samsung model RB1855SL
I had this exact problem with my 4 yr old Samsung RB1855SL refrigerator. BTW, the temperature display doesn’t display higher than 9C, even when its warmer inside. The fan wasn’t turning on to circulate the cold air, although the cooling coils were still cooling. There was no excess ice build-up. The freezer was working fine.
I thought perhaps the fan was toast or the temperature sensor. Then I noticed the interior fridge light was not turning off when closing the door (but the freezer light was). BINGO—thig light switch was the problem. A small piece on the inside of the fridge side of the switch was broken. When the door was closed, the broken switch didn’t let the fridge know that the door was in fact closed, causing the door alarm to keep beeping. This must shut the fan down in order to save energy when regularly opening the door.
DIY fix: I removed the switch (until I could get a replacement) which is located to the left of the lower door hinge (right hand side). Gently, with a flat nose screw driver, I pried it out.
The light no longer turned on when opening either door but that was a small price to pay compared to the incessant beeping and rotten food. The part can’t be very expensive and I can replace it myself. The local appliance repair shop will order it for me.
No expensive “internal brain” needed to be replaced or an expensive repairman needed to be called. Good luck!
Aug 17, 2008 | Samsung Heating & Cooling
Samsung Model RS2630SH
if fridge freezer sits down after power outage on a rs21dcns where interior lights are lighting but nothing else is working press power freeze and power cool buttons together for a few seconds should repower unit
Feb 09, 2008 | Samsung RS2630SH Side by Side Refrigerator
Control panel lights blink and beep, freezer fan cycles
The column between the doors being warm usually indicates that the compressor is running properly but the condenser fan at the bottom rear that cools the condenser and compressor is not running. Remove the cover from the back of the machine and verify this fan is running. It could have stuck from sitting for a period of time or something has gotten stuck in the blade during the move.
I am interested in what the fan inside the freezer is doing. You say 3-4 second pattern, is it running a few seconds then off a few seconds?
Please post back with the exact model number from the decal inside the fridge and I will look it up and see what I can come up with.
Nov 11, 2007 | KitchenAid Superba Architect KSCS25INSS...
Samsung RB2155 Bottom Freezer Refrigerator Logo
80 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
