Question about Gateway MT6705 Notebook
Dosen`t work my laptop when i turn it on and work but dosent show nothing on the desktop i cant see nothing the screen is black
  • ankur_j Oct 15, 2008
    it does not switch on
  • 655 Answers
If you are not able to see any thing on the screen after power on it means that your monitor has problem, if you can see some text after powering on and it goes black after loading windows/Operating system indicates that you have currepted drivers.
If the first is your case then you need to have a tour to service centre.
In second case you can boot your system in safe mode, then re-install driver for your display. After that make re-boot normal.
Thanks
Iqbal
Posted on Jun 12, 2008
I have a asus -model-k55v Windows 7 Core i7 When I turn laptop on it comes up with a black screen- which shows nothing on the screen - I have done the battery by pulling it out along with the power cord...
I bought the same laptop myself about a month ago and had a similar problem: mine worked ok since installing win 7, after the second restart, it showed only black screen..
To make the story short, my problem was the led panel behind the lcd - it didn't turn on BUT the lcd was active (you can tknow this if you look in some angles, you should see some graphic elements on the screen - such as a window)
To know if you have this problem, plug an external display - such as a tv or a monitor on your vga pot an it should display fine
If this is the case for you too, it's a hardware fault, send it back to your store - i returned it and after about 2 and a half weeks, I got my money back
I hope this helps you
Cheers
Sep 04, 2012 | Computers & Internet
The screem dosen,t work
You may try: turn off the brake cable detection of your Car DVD player in setting;check your screen;check power supply of screen
Jul 17, 2012 | Pioneer AVIC-N2 Car DVD Player
How do i turn on the blue tooth in my acer 5742 laptop?
Hi upch505,
Probably your laptop dosen't have bluetooth hardware in it.
Follow these steps:
1. Right click on My computer and click Manage
2. Then click on device manager on left panel
A list will appear which shows the hardware content of your laptop. If the list dosen't contain bluetooth device then it is confirmed that your laptop dosent have bluetooth hardware.
Try using external USB bluetooth device for your laptop.
Hope it helps.
Thank You for using Fixya.
Sep 09, 2011 | Acer Aspire 5742Z-4200 Notebook
My Dell Latitude D620 Screen is Black and the keyboard dosent work when I turn on the computer. The only LED light that shows is the power light, the wifi or the little cylinder light dosent work. I can...
remove all attached devices like printers or flash drives. remove battery and power on using ac adapter only. if it still wont work, try another good ac adapter. make sure ac adapter light is on. if it still shows the power light on and nothing else, replace motherboard.
May 15, 2010 | Dell Latitude D620 Notebook
Turn on the pc and the blue lite dosen come on all the cooling fans turn on but nothing else.
That machine is having fault coming from your VGA test the system with an external monitor first and follow the CRT/LCD key by pressing down your Fn key down and press the carrying the CRT/LCD key to switch the screen to the monitor so try that and if nothing is showing then you will have to change the VGA on your system or probably if its on the motherboard you will have to change the board completely thanks
Mar 06, 2010 | E-Machines eMachines Desktop PC
When i turn on the laptop nothing shows on the screen the screen is black
is it splining the fans,u cn tok to me on masadzala@yahoo.com
Aug 16, 2009 | Acer Aspire One PC Notebook
Acer 9410z screen is black
u have to remove extra memory and put that original then power if dosent work try to reset bos battery
Jun 09, 2009 | Acer Aspire 5500 5570-2609 Laptop
Powers up but black screen shows
1st - Try pressing <Fn> + <BrithnessUP> keys a few times, (on HP <Fn> key is between <Ctrl> key and <Windows> key, <BrightnessUP> key is <F8> key and <BrightnessDown> key is <F7> key. If nothing happens try the 2nd one.
2nd - Plugin external monitor, (type and size doesn't matter). Turn on your laptop. If you can see desktop on the external monitor, your drivers are o.k., The problem is your laptop display, NOT the graphic chip.
Oct 21, 2008 | Microsoft HP Pavilion DV6276US Notebook PC
Black screen
my presario v6000 laptop doesnt starts it shows desktop
Apr 11, 2008 | HP Compaq Presario V6000T Notebook
Screen dosent display
if your laptop still turns on but doesnt display. change out the fl inverter. if that doesnt fix it then its your lcd screen. but i suggest first changing the inverter.
Nov 01, 2007 | Toshiba Satellite P25-S607 Notebook
Gateway MT6705 Notebook Logo
90 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
