Question about Bunn -O-Matic Corp. 2 Warmer Auto Brewer Black
Leak In my office we use an old Bunn model VPR 1660 watt. 2-warmer coffee maker. Recently a leak developed...water coming from the seam between the top part and the middle part on the right side. It happens about half-way through a pot brew...the water comes out gently, and it's room temperature. What comes out is about 1/4-1/2 cup of water. Otherwise it does not leak. I hope you can help.
  • 487 Answers
Your tank is leaking
Please Follow LINK for parts etc
Posted on Jun 12, 2008
Bad leaking bunn commerical VPR pour-omatic
You will need to replace it, parts are not made for repair except under warranty.
Nov 30, 2016 | Bunn Coffee Makers & Espresso Machines
How do I get the BUNN VPR coffee maker to brew a pot of coffee? There are two switches; one for the lower, and one for the upper warmer. Do I first have to fill the tank ALL the way before it brews? Please...
This brewer has a 2 1/2 pot reservoir. You should NOT plug in the brewer before the reservoir has been topped off. Pour 3 pots (one at a time, every minute or so) through the screen with a pot under the filter basket. Wait until the water flows from the basket and only then is it safe to plug in the brewer. The reservoir holds HOT water until you are ready to brew and then, by pouring in a pot of cold water, you will be able to brew.
Sep 15, 2010 | Bunn VPR Coffee Maker
Bunn Series VPR, pour water in, water comes out cold
Test that you have it plugged into an operating outlet.... Check that all of the switches are "on" (the warmer and the heater switches). If this doesn't help, you'll need to unplug the unit and test the switch and element for proper operation. Both can be tested for continuity. If they all test good, then I'd suspect the thermostat.
Good luck and best regards, --W/D--
Jul 18, 2009 | Bunn VPR Coffee Maker
Bunn coffee maker leaks water
There are 3 seals in your unit that could cause your problem. there is a silicon seal right under the pour-in tray, and two on the top of the tank. one of those is for the thermostat, the other is for the sprayhead tube. any of these could leak, causing water to come out the bottom of the brewer. One other thing that can cause this is a scale buildup between the pour-in tray and the tank.
Jan 12, 2009 | Bunn VPR Coffee Maker
BUNN Pour-Omatic
Most likely it is your tank heater, but look on the top of the tank heater, because sometimes the wire will burn off the top of the element
May 20, 2008 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
Warming tray too hot
You can either replace the warming element with a new one, or some people put 3 or 4 pennies on the top of the warmer tray. Don't laugh- this really does work!
Feb 08, 2008 | Bunn VPR Coffee Maker
I own a bunn and my brother's business owns 2 of these. The rule of thumb as he was told by the salesman is 2 oz of coffee grinds per 48 oz of water.
Jan 23, 2008 | Bunn VPR Coffee Maker
Coffee pot
I am having the identical probem, I plug it in, it starts to heat, but no brewing. I have removed the lid and the water pan underneath, and looked into the opening. When heating, the voltage on the main heater is 110 volts. It stars to steam, then the unit switches off.I think that for some reason,it's not allowing the temp. to rise to the boiling point. Anybody have any ideas? I'll check on that one way valve in the meantime.
May 30, 2007 | Bunn VPR Coffee Maker
Bunn -O-Matic Corp. 2 Warmer Auto Brewer Black Logo
205 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
Jim Y
Jim Y
pawnpower
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
