Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
Creda t601cw condenser dryer
This dryer is still working with blowing out the warm air but the drum isnt going round, can you help?
  • 66 Answers
Hi sounds like your belt has snapped or drum has snapped from the shaft regards jason
Posted on Jun 14, 2008
When using my dryer i notice that my windows are steamed up why is this?
What is the dryer doing? drying your clothes right? so the clothes are wet and as the dryer goes round and round the fan which is attached to the drum ( which holds the clothes) is pushing hot air into it. the vent in the front or the lint trap sucks hair lint debris from going up the exhaust chute. so "steamy" windows is when the dryer exhaust is not vented to take the moist warm air out of the house and raises the humidity level to condensate on the windows giving the steamy look. which is a great way to heat and bring humidity into the house during the dry winter months.
Nov 17, 2015 | Dryers
Creda T601CW 6Kg Advance Condenser Dryer The belt
Creda I don't know from. Sorry
Nov 20, 2011 | Dryers
My dryer drum is rotating and the heater is working, but condensation is building up in the drum instead of dispersing. No matter how long the cycle, the clothes don't dry. I've checked the filter, vent...
Can you feel air blowing out the vent on the dryer itself? The reason I ask is if you dont feel any air blowing out your blower fan isnt working and wouldn't matter if vent was clear if you dont have any air movement.
Jan 21, 2010 | GE Profile Harmony DPGT750EC Electric...
Creda T622CW condenser tumble dryer drum wont turn
You need to check if the belt is o/k.
Remove top cover, and grasp belt, it should be firmly wrapped around drum.
If o/k, then could be a motor problem, or programmer fault
Once you have got the drum turning again, it is possible the filter light will go off,if not, then you have another fault
Hope this helps.
Dec 16, 2009 | Dryers
Creda t522vw has topped spinning but still
Could be the belt has failed, you need to remove tho top cover, and check to see if the drive belt is intact, grasp the belt and see if it is o/k.
Another way to check is turn the drum from inside and it should go round., if not, then it is probably the belt.
Hope this helps.
Dec 06, 2009 | Dryers
Creda advanced t601cw leaking from back
this could be a pipe of or the condenser is blocked but this might be helpful as well thermostats or heater
ForAll Your Appliance Video Help Visit Apart4u video tutorials
see other tumbledryervideos here
You-Tube video "ymXmpyVkxIE" placeholder (do not delete)
Common faults -
1 The heating elements can fail(meaning open circuit)
2 There are cut-outs (T.O.C's) thatmight need resetting
3 The thermostats (stats) can tripout or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehaveprograms that can fail and circuitry although most should produce an errorcodeshowing you were the fault is.
5 Faultyconnections and burned wires may also bethe fault.
Nov 06, 2008 | Dryers
How to fit a belt to a creda tumble dryer
open case
loop belt around bits
close case
more particularly
Unplug dryer
pull dryer away from wall
remove 1 screw each side at back of top plate
slide top plate backwards and lift off
undo 1 screw each side of front kickplate
tlit front panel up
unplug door switch
set front panel aside
careful of control panel its V.fragile
(I lay the dryer on its back)
pull out old belt and bits of belt
loop new belt round drum at wear marks
pull tensioner to end of travel against spring
loop belt round motor pulley & both tensioner wheels(most creda) 1 wheel (old)
relax tensioner
rotate drum by hand to make sure belt wont jump off
reassemble in reverse order
creda uses hotpoint parts
Oct 30, 2008 | Dryers
Drum wont turn on my creda t622cw tumble dryer
my tumble dryer drum wont go round
Nov 15, 2007 | Dryers
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
222 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
