Question about Ricoh 6513 Copier
Service code 551
Please assist, what does this code mean, how do we reset it and what else should we do? thx
  • Ricoh Master
  • 2,794 Answers
SC551 is an error with the fuser unit. The thermistor could be bad and need to be replaced or the press rollers are worn.
It should be looked at by an experienced technician to get problem repaired.
Posted on Jun 13, 2008
Ricoh 1813. Error code c551
The Ricoh copier error code SC551 / 551 is a fusing thermistor 1 error code.
It can mean:
1. The thermistor is not connected
2. The thermistor connector is bad
To reset this error try the code:
"Clear Mode"+107+"Clear/Stop" hold for 5s.
Turn ON and OFF the Main Switch.
If the problem persists you may need to contact a local service technician to take a look at your copier.
Oct 03, 2017 | Ricoh Office Equipment & Supplies
551 error 5950 daryview
The copier error code 551 is a fusing thermistor 1 error code.
It can mean:
1. The thermistor is not connected.
2. The thermistor connector is bad.
If the problem persists you may need to contact your local service technician to take a look at your copier.
Apr 16, 2016 | Office Equipment & Supplies
We have error 551 what this ..?? Ple. Ergant
It can mean:
What does error code "E39" mean?
Hello friend, thank you for your inquiry!
I see you are receiving an error code "E39" on your Electrolux range. I show that the error code "E39" is invalid. May I have you model number please? Typically you can locate your serial tag on the inside of the oven on the right hand side or on the storage drawer on the right hand side. With this information I can better assist you with pinpointing the issue.
In the meantime, I suggest resetting your dishwasher. You can do this by flipping the household circuit breaker for roughly ten minutes. If resetting the power does not correct the issue, could you please inform me of the new error code or if your dishwasher continues to display "E39". I look forward to assisting you. -Chris
Sep 05, 2014 | Electrolux Kitchen Ranges
Why is amy copier throwing a sc 49-1 code?
What do you mean yo cleaned the control board?? Did you remove it????? IF you did major problem a Will have to go back and remove each connector looking for a bend pin and ensuring each connector is properly seated. Never remove board unless required. As for the code: please check code could not find in the service manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
May 22, 2014 | Konica Minolta Minolta Di 650 Di 551 Di...
How to unlock
If you are asking for a network unlock, The best way to unlock a Samsung i5510 Galaxy 551 mobile phone is using unlock code. You can get the unlock code for a Samsung i5510 Galaxy 551 mobile phone from
ClassicUnlocking.Com at affordable cost.
UNLOCKING PROCEDURE FOR SAMSUNG i5510 GALAXY 551
1 - Switch ON your Samsung i5510 Galaxy 551 with a NOT ACCEPTED SIM Card.
2 - Compose : #7465625*638*CODE# (or *#7465625*638*CODE#).
NOT ACCEPTED: We mean, to use a sim card from a network other than the network your Samsung i5510 Galaxy 551 is locked to.
CODE: Its the unique Unlock Code for your Samsung i5510 Galaxy 551.
Apr 12, 2014 | Samsung Galaxy I5510 551 Unlocked For...
Restore factory security code? thx before
*#7780# please like and comment if it works.
Aug 10, 2011 | Nokia 1100
Erro sc 551
You have a Fusing temperature problem.
Problably because the hot roller are crusted whith tonner and the thermistors cant read the temperature.
If you whant you can reset that error code. However, if the error appears again, i advise you to call tecnical assistence.
Try this to reset the code:
1-Press yellow key
2-On the key pad press 107
3-Old down the red key at least 3 sec.
4-Press 1copy SP
Exit all the way out to the copy window.
Turn the main swith off and on.
Feb 19, 2011 | Ricoh Aficio MP1600SPF Copier
Ricoh 6513, service code 551
SC551 is thermistor pressure roller error. Check for paper jams in the fuser. It could need a new thermistor.
Make sure the fuser is secured and properly seated in the copier.
Jun 12, 2008 | Office Equipment & Supplies
About ricoh copier problem
sc541 is a fusing unit error code. Can you reset the code in service mode?
Apr 22, 2008 | Ricoh Aficio 450 Copier
Ricoh 6513 Copier Logo
469 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
