Question about Hitachi 43FDX01B TV
Colour tv My tv picture is red red red how do i fix it what is it that i need to buy
  • 71 Answers
Problem cuold be red crt or red video output circuit or screen control set too high. Should have tv tech check it out.
Posted on Jun 12, 2008
Can see image but the screen is all red
Generally Tv screens use three different colours to make the picture, and if one or two of these colours don't show you will see the picture but in specially one colour (like looking through a red filter in your case).
If you are using an input into the TV (DVR or Games console etc) then I would firstly move the cable around in the back of the TV and the console to see if anything changes or flickers in and out of being correct. If this does happen I would recommend buying a new cable to fulfil the purpose.
If this does not happen and you are still seeing red then there may be an issue with the connection inside the back of your TV, this shouldn't be a very expensive issue to fix as you are still getting a picture but I would recommend getting a specialist to check it out if you are not confident in fixing this manually.
Thirdly and most unlikely is the settings inside the TV have changed, some TV's like yours will allow you to change colour settings on the screen. I would go into the menu and find the section that allows you to change the colours and have a check to see if any of the settings seem off.
Dec 14, 2011 | Sony KP-57WS500 57" Rear Projection...
Red colour picture on plasma TV
It might need the color to reclibrated, if that does not work, a gamma electronic board need to be replaced
Jan 06, 2010 | Samsung PS42C91HDX 42 in. Plasma TV
Sound but no picture!
This is a normal, input board defective (as switch module inside betwen tv signal and the AV1,2,...) normaly is video chip defective. You need to send tv to repair shop, to check and repair.
Note: Check for tv picture signal, for quality, normally this circuit when defective, changes the quality signal (first some colours level, sync and then totaly defective is a dark picture)
Dec 11, 2009 | Televison & Video
The colours on my tv have gone pink and green
Either your picture tube has gone bad or the transistor or IC on the crt board, on the picture tube, that feeds the blue gun has gone bad. You would have to test the transistor to see if its shorted or open with a multi-meter, or check the voltages to and out of it. The voltages are around 200v and dangerous if touched, best left to a proffessional. If its the transistor/IC it would be a cheap and easy fix by a repair shop, if its the tube, you may want to go tv shopping.
Aug 30, 2009 | Goodmans W280NS Television
Red, green and blue colours diveded on my TV
ok well "tube" tellys as they are called use an electro magnet to keep the picture stable and colours correct its called gaussing now if you have a speaker or something magnetic nearby it will stuff up the colors but only normally producing colors like purple,green, or white
if you have colors across the screen (that aren't caused by magnetic force) then you need to take it to a repairer or decide wether or not to buy a new one this issue can turn out to be quite hard to fix and can be expensive the different colored electron guns may be burning or burnt out causing pale color or it could be as simple as a power transistor in the H.V supply has shorted out..and causing power issues to the tube.
hope this helps,ben
Aug 13, 2009 | RCA 20F512T 20" TV
Sony Vega gone red
I'm having the same problem, red picture. Did you find a repair person and if so what was the problem and cost to fix it? My television is only 4 years old so I'd prefer to fix it if it's cost effective.
May 13, 2008 | Sony FD Trinitron WEGA KV-32FS100 32" TV
The picture is only producing the basic colours red green and blue
You can start with the make, model and age off the back of
the TV..........................T.
Dec 24, 2007 | Televison & Video
Phillips tv 32pw9544
it is 100% sure that your tube is ok.
there are few problems in different section like
  • sound section for no sound
  • video & crt base  due to low light in picture.
  • red video output circuit.
  • though problems are very easy & can be fixed at your house.but you need skilled technician.
Oct 16, 2007 | Televison & Video
My tv is picture is blue and green
Hi there my t.v has a similar problem, I turned it on and the colours arn't right, there the colours go out in three circles mainly mainly blue, green, red yellow, but depends whats showing on the t.v? Please help.
Apr 17, 2007 | Bush 5693D 24" TV
Hitachi 43FDX01B TV Logo
222 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
