Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
No juice. What's up people!?! So, got a RCA D52W20... when turning on set.. power green light comes on three seperate times. All 3 seem to be attempts at the TV powering up but nothing happens. What say the masses?
  • thechad42 Jun 12, 2008
    Thanks for the QUICK responses. I'm not a "fix 'em" up kinda guy, unfortunately! Can a repair shop in my area fix the problem "in house" or will I expect that they will want to take the tv to their respective place of business?
    Thanks again for all the feedback. I had a repair guy out from a local company today and he fixed the problem. He said it was a manufactoring error by the engineering team of RCA. Something in the power supply area. He said he replaced "it" with the part that should've been there all along. I got home as he was finishing up and did see a soldering iron.. so maybe ahhsoo69 had it from the get-go. He charged me $280 for an hour's worth of work and the part. As long as the thing works another 4 years.. I'd say it's well worth it.
    Scholar:
  • 167 Answers
Hello. sound's like u have a power supply problem.it could be a blowen fuse. or a dry socket.!.on the power supply bored.! some tec's. call it a cold solder jonit.or socket.? check for a blown fuse first. then if you know how to use a soldering iron. one that not over 40 watts.and some rosin core flux 60/40. u can soldering over the power supply bored connection's.then try it .? good luck
Posted on Jun 12, 2008
  • MICHAEL WALLACE
    MICHAEL WALLACE Jun 12, 2008
    HI. WELL AVTECH IS ON THE RIGHT TRACK . ABOUT THE HORIZONAL OUT PUT TRANSISTOR.! THAT'S WHAT FEED'S THE FLY BACK TRANSFORMER AND IF I WHERE YOU . I WOULD CALL AROUND AND FIND OUT WHO HAVE A FREE DIAGNOSTIC TEST. AND FIND OUT WHAT THEY WANT TO CHARGE YOU.? AND IF THEY DO HOUSE CALL'S AND WHAT THEY CHARGE FOR THEM.& IF THAT HOUSE CALL CHARGE WILL APPLY TO THE BILL IN THE TOTAL COST TO FIX IT.
  • MICHAEL WALLACE
    hay. "Am" glad i coud help u. i have worked on tv"s 4 over30year's + .!!! and the tv tec that came to your house and fixed your set .!!! I think he did not over charge u . !!! the price was about right on.!!! for the work he did for you.!! i won't do a customer wrong.!!! allway's make the customer happy. !!! and they know they spent there money wisely. !!! for the work u have done 4 them. !!! Good luck.
    Scholar:
  • 146 Answers
There are many, many, many, things that can cause this. I even just discovered a new at this time, on a set I have here in my shop. However, the most comond problem is in the horizontal output section. This is not the kind of problem for a cunsomer. You need to take it to a repair shop. You can also listen (with your ear to the bottom, back of the set) to the set when you turn it on to see if you can here a small squeal or staticy sound the 3 times it tries to come on. If it dose the horizontal output and/or flyback transformer is bad (comond problem).
Rca d52w20 blinks 3 times, wont turn on
The set has a three strikes and you are out rule---tries to come on three times and then if fails, shuts down.
A short exists inside the set.
Mar 17, 2012 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 HDTV TRIES TO TURN ON 3 TIMES BUT WONT POWER UP
remove all the electrical wire connections from the back of the tv .remove the power plug from the electrical outlet and wait for two minutes and replug the wire and then ckeck.it should work.
reply.
Oct 29, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
My tv wont stay turned on. It comes on then turn of comes on the turns off
I press the power button it blinks green and attempts to come on three times but it never comes on
Aug 27, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA HDTV - problem turning on
It's on but you are on the wrong input. check your connections from your sources ( i.e. dvd, vcr or satellite/cable box) try pressing source or input button on tv remote
Jul 25, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca d52w14 hit power green light blinks three times wont come on
could be power supply problem or high voltage problem. check caps in main power supply first.look for caps that have tops puffed up ususlly three or four.....
Feb 24, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Tv's green light comes on then off three times
Check capacitors cp150 ,114, 120 ,if cp150 is puffed up on top it is bad.2200uf 16v and the other 2 are 220uf 35v.
Feb 11, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 tv
3 capacitors On Deflection board cp150 2200uf 16v see if it is puffed up on top if so it is bad also replace 2 more caps in same circuit cp114 cp120 both are 220uf 35v they are green with gold writing.For Parts 1-800-223-3205. www.electronix.com
Dec 27, 2008 | RCA D52W19 52" Rear Projection Television
Wont come on green light comes on three times
Check hori output Transistor if it is shorted set will not come on Part # NTE2324 if it is ok CK second ribbon connector on the deflection board going to board on right. make sure it is in good if it isnt set will make noise and not come on,
Dec 27, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52 in. Rear projection hdtv problems
Check 3 capacitors on Power supply/deflection board cp150 2200uf 16v if it is bad replace 2 other caps in same circuit cp111 cp114 220uf 35v
Dec 01, 2008 | RCA D52W19 52" Rear Projection Television
can you tell me if the light blinks when you press power? If so let me know and I can help you diagnose the problem.
Jun 29, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
Top RCA Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
