Question about Canon LaserBase MF5630 All-In-One Printer
Images suddenly become faint
Our photocopy images have suddenly become faint. We thought the machine needed a new toner cartridge, but a new one hasn't made any difference. Unfortunately we can't find the manual! Is there a diagnastic mode or similar we can access. (By the way we are a UK charity, so unfortunately, cannot take up your great value extended warranty offer)
Regards,
Jan Jalovy
The Beit Trust
jyvibar
  • 148 Answers
SOURCE: Poor colour quality
usaully the problem is when using refill ink. It damages the ink cartrige
Posted on Mar 23, 2008
  • 33 Answers
SOURCE: Canon MP210 printer/scanner/photocopier - 5 E (error flashing)
replaced the colour new ink cartidge
Posted on Sep 15, 2009
  • 64 Answers
SOURCE: Faint copies, despite new cartridge.
Go to Additional Functions> Common Settings> Toner Saver Mode and make sure its off.
Posted on Dec 30, 2009
SOURCE: where is the waste toner cartridge in the Canon IR
canon photocopey the page is look dark and have line in the madeal of the page
Posted on Jan 14, 2010
Cogz
  • 1326 Answers
SOURCE: waste toner full prepare new drum on canon iR1570F
The waste toner is part of the drum unit. You need to replaced the drum unit with a new one.
Posted on May 24, 2010
I REPLACED OUR TONER CARTRIDGE IN KYOCERA 3530 COPIER AND THE IMAGES ARE STILL VERY FAINT. WHAT CAN I DO?
You can give cartridge adjustment from copier service mode. Try to gentle shake the toner cartridge.
Apr 10, 2018 | Kyocera Office Equipment & Supplies
Toner spills on papers, how do i solve it?
Is the toner still loose or is it fused to the paper?
If it's loose, you need to clean out the inside of the printer because toner was spilled inside. Don't use a regular vac, because you need a heppa type filter
If it's fused, there may be a couple reasons:
1) It could be a dirty fuser
2) It could be a failing toner cartridge, replace it
Based on your post, I would suggest replacing the toner cartridge first, as if the copies are faint, you are running out of toner.
May 10, 2016 | Office Equipment & Supplies
What's the cause of faint print on a photocopying machine?
The toner could be low. That is the first thing I would check.
Sep 24, 2012 | Ricoh Aficio 1018 Printer
Faint grey printing
According to the service manual for problems with light print image, the cause can be the Developers or High Voltage Power Supply (HVPS). Other possible causes are given as: Developer roller is stained when the toner or developer cartridge is almost consumed. Ambient temperature is below 10 degrees Centigrade. Bad contacts with the HVPS or abnormal output from the HVPS. To replace the Developers you would need to purchase a replacement Imaging Kit CLP-R300A. Any problems in the HVPS would require a factory repair.
Dec 13, 2011 | Samsung CLP 300 Laser Printer
I have a Brother 2170W printer. Worked well for years but suddenly had some blank columns down the center. Took it to a repair shop and they said it needed a new drum and printer. I purchased and installed...
Hi Len,
Thankyou for explaining you problem to me, it makes life a little easier when you have no hands but are equiped with the facts.
I too would normally think Drum/Toner or Carona but it seems you have covered those, the carona is in the drum but if you switch the drum and the marks dont change then that cant be the issue. Here is a LINK to the carona cleaning instructions and below I'll past a pic of the carona position.
If a good Brother branded toner doesn't fix it, and you have fitted a new sealed brother original drum and that doesn't fix it, there are only two possible things left, one is the fuser at the rear that melts the toner to the paper but I doubt that one because it usally leaves lumpy marks on paper surface, but you could get a touch and look at the two width of the machine rollers at the rear and see if the coating has come off the teflon roller.
What I think is your issue is there is toner dust on the laser lens, it is a **** 1-2cm wide running width of machine, it resides inside the machine about midway directly above carona slot, get a soft cloth and wipe the lens.
Let me know if the lens clean does the trick, otherwise it must be 2 lots of faulty toner but the image would change or two dirty carona's/worn drums but once again image would at least change.
Make sure you reset the drum counter, heres a (link) to how
Cheers Steve
Oct 19, 2011 | Brother HL-2170W Laser Printer
Printed copies have ghost images on them. I have never had this problem before., It looks like the image printed twice - once fine and then faint horizontal lines, sometimes some of the previously printed...
1) try doing a full clean from within the menu on the printer, or within the computer software
2) You need to perform a half test. Put a sheet of paper on the manual feeder and do a config page from the information menu on the printer. When the back edge of the paper enters the printer, quickly open the toner door to stop the printing. Now remove the toner cartridge and look at the image below. If the defect is present, then the toner cartridge is the problem 99% of the time. There is a slight possibility that during the conditioning stage of the print process the drum of the toner is not being fully discharged so when the next stage takes places part of the previous image gets put on the toner cartridge again. Very rare. If the defect is not present then the fuser has an issue.
May 04, 2011 | HP LaserJet 2420 Printer
16 toner low
A laser printer needs toner to print, when this runs out the printer will print either blank or very faint images.
You need to replace the toner cartridge with a new one or a re-manufactured toner cartridges. Re-manufactured toner cartridges are cheaper than new toner cartridges for your model printer.
You can get a few more prints out of your toner cartridge by removing the toner cartridge from the printer and giving it a few horizontal shakes then place it back into the printer.
Feb 03, 2011 | HP LaserJet 4 plus Printer
Samsung 4300 tonner exahust message
Feb 03, 2011 | Office Equipment & Supplies
My LaserJet 1020 is printing a faint after image. Any suggestions?
take out and shake the toner Cartridge and put it back
Dec 16, 2009 | HP LaserJet 1020 Printer
Despite new cartridge the black ink comes out very faint. Other colours are not affected.
34ffb5e.jpg If your printer prints like the above image, then the problem lies with the black developer blade. Each toner has a developer blade which is located in the imaging unit. As the printer is used, toner residue builds up on the developer blade causing the print to become faded. As the build up continues, the print almost becomes completely white.
This seems to be a very common problem with this printer judging by the number of complaints about samsung print quality problems that are posted here. The only way of fixing this is to buy a new imaging unit. This can get expensive typically around $100. Especially since the problem occurs way below the expected life of the imaging unit which Samsung said it is 20,000 images. Mine it started to fade around 5000 images.
If you are handy, you can clean the developer blades yourself. Go to this link http://losingambition.com/clp300imagefix/. It describes how to open your imaging unit and to clean the blades. It only takes about 15 minutes to do but you must be careful when you clean the blades and reinstalling them back into the developer. If you do it correctly, the image you get is as different as night and day. Hope this can help someone.
Feb 21, 2009 | Samsung CLP 300 Laser Printer
Canon LaserBase MF5630 All-In-One Printer Logo
44 people viewed this question
old marine
old marine
