I recently changed my pc and now cannot find the software for this mp3 player to change/ add songs. can you help?
SOURCE: Write protection
Unfortunately the GPX M2104 manual is not available online(due to large size...), so all I can help with is some advice that might seem like the obvious, or some referals- 1. Make sure the HOLD is in off position. Slide the HOLD switch to the opposite side of the word HOLD. Then connect the player back and try to transfer/add/delete the songs you want. 2. If you have a digital form of the manual(please submit it here) search for "write protect" on it(shift+control+f on adobe), or look in the troubleshooting section which is generaly towards the end of the manual. 3. Try resetting the device. If you don't know how, again - it should be on the manual, and if it isn't then unplugging it and disconnecting it from all power sources for a few days sometimes does the trick. you can also try doing it on another PC, or another OS just to make sure it really is the GPX malfunctioning. Good luck
SOURCE: MP3 Player
u can d/ld mp3 player from the following link & ur problem will be resolved http://www.handango.com (its free of cost ) good luck
SOURCE: Sansa mp3 froze
IF the other solution doesnt work, you can try putting it into Recovery Mode, just to unfreeze it.
- Turn the device off (hold power for 20 seconds)
- Slide the hold switch into "hold" position.
- Press and hold the "record" button for a few seconds.
If you see Welcome to Recovery Mode, let go of the Record button and hold the power button to shut it off. Then restart it.
Best of Luck.
SOURCE: Phillips Go Gear MP3 Player Is Dead
have you tried resetting the player and reinstalling the software
SOURCE: how to add songs to Philips SA2310 GoGear Mp3 Player 1GB MP3 Play
U DO NOT REQUIRE ANY SOFTWARE TO ADD SONGS TO UR PHILLIPS MP3 PLAYER. JUST USE UR USB CABLE TO CONNECT WITH THE PC. THEN U SEE ONE DRIVE NAMED REMOVABLE DRIVE COMES IN MY COMPUTER. JUST DOUBLE CLICK ON IT AND ADD MP3 SONGS AND THE SONGS ARE ADDED TO MP3 PLAYER. ENJOY THE SONGS IN PHILIPS MP3 PLAYER. GREAT SOUND.....
