Question about ASUS Striker Extreme Motherboard
Post codes with Striker 11
Love the new lcd display you attach that shows post codes, is there a guide that helps you understand what they actually mean. Mine goes CPU INIT, then to DET Ram, then goes back to CPU INIT. and doesn't go any further.
  • 1 more comment
  • jimconnell Jun 12, 2008
    Thanks, its a new build, Striker 11, intel QX9770, Evga 9800 GX2, Corsair 4x 1GB XMS3 1600 MHz,Adaprec Raid card ASR-5405.
    On boot LCD display goes from CPU INIT to DET Ram and then back to CPU INIT and back to DET Ram, keeps looping like this. Have tried one stick memory and reseating all sticks.
    Sound card is the supreme FX11 that comes with the board and I have the Evga 9800 GX2 video/graphics card. Also I notice that I do not get anything on the monitor which is plugged into the 9800.
  • jimconnell Jun 13, 2008
    Took the video card out and ran it in another motherboard and it worked fine.
  • 462 Answers
U need to be more clear.
Posted on Jun 12, 2008
  • Mohamed Ismail
    Mohamed Ismail Jun 12, 2008
    is sound card and display card built in...? or seperate additional card...?
  • Mohamed Ismail
    Mohamed Ismail Jun 13, 2008
    i guess u will have to try with a different display card... to see if there is anything wrong with the motherboard...!!! Please check n tell...
I have a glass cooktop Electrolux which is only 2 years. stopped functioning with a E-11 error code and cannot ulock. what can Ido?
Hello Gloria Padilla, thank you for your post!
I understand that your Electrolux cooktop is displaying an error code "E-11" and will not allow you to operate. The "E-11" error code stands for key sensor in cook place four. This could mean a possible issue with your flex cable, right board, or left board. I see you have completed a reset on your cooktop, at this point I would recommend having a professional technician for a proper diagnosis to be completed. I hope this information is helpful. -Matt
Dec 29, 2014 | Electrolux Cooktops
How do I remove the door striker that is glued to the door.
Good Afternoon Friend,
I understand that you are trying to replace the door striker on your Frigidaire washer, model# ATF6000ES. The door striker should only be held on with 2 screws. Take the 2 screws off and you should be able to replace the striker. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. Hope this is helpful.
-Best Regards-
May 27, 2014 | Frigidaire ATF6000ES Front Load Washer
My Acer AL1916W LCD does not show full color. The half of the screen show one color while the other half display normal color that am expecting. I don't know how to correct it. I have use the setting...
More likely to have failing T-CON board which is part of the LCD panel assembly, you can try reseating the ribbon cable attached to the LCD panel's T-CON board first, otherwise new panel will be needed.
Basic LCD monitor troubleshooting guide:
Failed TV and Monitors:
Capacitors kit: he can make you a set of caps for you.
Please post back what you find.
Oct 18, 2010 | Acer AL1916W 19" LCD Monitor
Damaged LCD, Low battery LED on, wont comunicate with PC.
Replace or Repair the display on the Sony K800i. If your k800i screen is cracked, this guide will help you. If your Sony K800i LCD is dead, then this video will show you how to disassemble and replace it. If your lcd screen on your k800i is smashed, then this post will help you fix it yourself for a very low cost.
Replace LCD Screen on Sony K800i Display
Feb 06, 2010 | Sony Ericsson K800i Cellular Phone
Asus Striker II Formula
try to boot up with minimum configuration ie: graphic card , and memory, check BIOS configuration
Sep 25, 2008 | ASUS Motherboard Striker II Formula
Hi im having problems with my new Asus Striker II Formula motherboard ive installed it all and when i boot up the LCD screen is came with shows a error code as M56 and wont boot up any devices can you...
Make sure your front panel wires are plugged into the header on the MB in the right position with the polarity correct. Will it POST test, beep on startup? Are you able to enter the Bios setup? Press "Del" before the POST test after power up.
Dec 01, 2017 | ASUS Computers & Internet
Hello Arua
I would suggest you get your hands on a 4 digit post card to diagnose the problem
heres one
  • Determine defects by difference sounds coding with build-in speaker.
  • It can diagnosis the motherboard signal which show the problem of CPU, Memory, video card, etc.
  • The POST code display is made up of a dual, dot matrix hexadecimal read-out that display's Power On Self Test (POST) status codes
  • Support the power source working indicator -- +5V,+12V,+3.3V and 12V(When indicator LED is on to indicate its respective power is fine, otherwise to indicate its respective power is failure.)
  • Fully compatible with any kind motherboards which has the PCI and ISA bus slot.
  • If this solution was any help at all please press accept or ask more questions with the other button.And if you need anything else let me know, you can ask me 24/7 by clicking
    on the ask me button, I will ansver in most cases within 24hours.
    Thanks and good luck!
    May 05, 2008 | Intel D845EPI (INTELKD845EPILPAK10)...
    Error 16
    Dear Rashid,
    I understand that this errors occurs in POST mode. You can always refer to service manual or troubleshooting guide of your machine upon purchase especially it displays error code. However not all error codes are not servicable for ordinary users due to risk. To give you an idea in solving the problem; present this error code to authorized service center and offer them to purchase the defective parts regarding this error, or you can troubleshoot by detaching or removing running parts one at a time. We'll see if the error changes. Contact me if there are progress, I can help you pin-point the problem somehow I can resell parts soonest with this type of printers.
    Best regards,
    Rosener Guyano
    Jan 27, 2008 | Epson DFX-9000 Matrix Printer
    ASUS Striker Extreme Motherboard Logo
    212 people viewed this question
    Top ASUS Computers & Internet Experts
    Alun Cox
    Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
